#1 |
Member#: 100353
Hey guys. I'll keep this short and get to the good stuff quick. I bought the car (2006 STI) in stock from a friendly older man, the original owner, about three years ago. Since then, I've been daily driving the piss out of it, autocrossing it regularly with varying levels of success, and having a grand old time. As usual, the car has slowly evolved. At first, the usual 'Stage 2" stuff, then coilovers and swaybars, then e85, all on the stock turbo. Anyway, after a summer of 326whp/403ftlb, I felt like it was time to take the next logical step.
With the stock motor still holding strong, I decided to park the car for the winter and dig in. Long story short, drop-in pistons, a moderate stock location turbo and upgraded top mount snowballed into new built motor, twin scroll BW 83-75 and a substantial fuel system. I'll keep this post updated with my current setup and this thread updated with pics as I finish up the build and drive the car through the summer. Now, I know I won't hit 600whp on this turbo, or maybe even this motor, but it's a goal for the future. I'd be very happy with 500whp this summer. Engine: - Fresh 2.5L shortblock - Fresh balanced/lightened crankshaft - Manley 99.75mm forged pistons, moly coated - Manley Turbo Tuff I-Beam rods - ACL main/rod bearings - heads ported and rebuilt - BC springs w/ Ti retainers - GSC S2 cams - ARP/MAP H11 head studs - 11mm oil pump (undecided) - Gates racing timing belt - Borg Warner twinscroll 83-75 - Fobia twinscroll headers/uppipe - dual Turbosmart Compgate 40mm external wastegates - Turbosmart Race-port 50mm BOV - GrimmSpeed MBC/BCS hybrid - Treadstone 28 x 10.5 x 4.5in sti core - GrimmSpeed ported intake manifold (rotated) - GrimmSpeed phenolic spacers - GrimmSpeed gasets all around - Custom 2.75in charge piping Drivetrain: - ACT XT-SS Clutch, 6-puck sprung disc - Factory STI 6spd Short Shifter - Torque Solution Tranny Mount - Torque Solution Engine Mounts - Torque Solution Pitch Stop Mount - ACPT Carbon Fiber Driveshaft - Street: BBS w/Hankook R-S3 255/40R17 Fuel: - Five-O 1600cc top feed injectors - DW300 in-tank pump - 3L+ surge tank in engine bay - Aeromotive 1000hp A1000 stealth pump - Aeromotive billet fuel pump speed controller - Aeromotive top feed fuel rails - Aeromotive A1000 -6 FPR - more AN fittings than you can shake a stick at Misc: - omni 4bar MAP sensor (converting to speed density) - odyssey pc680, relocated to trunk - rotated intake manifold (AC delete?) - new ported top feed TGVs - countless other random bits
#2 |
Member#: 100353
First day.
![]() Winter. ![]() After coilovers, different set of BBS and tires. ![]() BW 83-75 next to vf39. ![]() Prepping the bay for paint. ![]() |
#3 |
Member#: 278870
SCIC
Vehicle:2005 Stage 2 WRX Obsidian Black Pearl |
the turbo size comparison is awesome, good luck
#4 |
Member#: 126696
SWIC
Vehicle:2002 Fatbody bugeye 03 R1 09 Raptor 700R |
The BW looks massive compared to the VF39
#5 |
Member#: 141754
Vehicle:04 stock wrx ;) z31 project, passat dd |
the turbo might suck in a baby or two lol. if your planning on still driving the car on the street a decent amount id try to keep the A/C unless you dont mind the summer heat. thick phenolic spacers drop the alt as low ans it can go and some people shave down the cover on the alt to give a bit more clearence for the pipe.
#6 | |
Member#: 100353
![]() ![]() ![]() ![]() Last edited by TickTack; 04-19-2012 at 08:01 AM. |
#7 |
Member#: 167244
TXIC
Vehicle:2k3 WRX MBP black & gold is pimpin' |
subscribed.
#8 |
Member#: 141754
One other thing i would see done is putting the fans on the front of the radiator so the can run a larger one like the koyo one.
#9 |
Member#: 315863
subscribing
#10 |
Member#: 100353
#11 |
Member#: 313952
Vehicle:2006 STi SGM |
thats a big ass turbo!
#12 |
Member#: 100353
#13 |
Member#: 313952
Except your gas pedal
#14 |
Member#: 284247
RMIC
Vehicle:2002 Wrx MBP! |
holy moly, the 39 makes the td04 look tiny and now the 39 looks like a little dwarf haha
#15 |
Member#: 100353
#16 |
Member#: 115774
SCIC
Vehicle:03 Subaru PSM |
Nice build!
#17 |
Member#: 100353
Well, there was a little bit of a delay on the motor, so I've been just plugging away at getting some other things done. It's always bothered me that the engine bay was a different color/finish than the rest of the car. I felt like it really cheapened the whole thing. Anyway, with everything out of the engine bay, I felt like I should take the opportunity to go the extra mile. With that, I started scrubbing and scuffing and last night we finally got paint down. I good friend of mine is a very well respected body/paint guy around these parts, so a few of us made a day of it and he shot it. I'm really happy with the way that it turned out, despite the fact that most of it will be buried once the motor/turbo/charge piping/etc are back in.
Masking ![]() Tony doing more masking ![]() Ready for a final wipedown ![]() We decided to do the fenders off the car to get better coverage ![]() Mixing sealer ![]() More mixing ![]() Shooting primer/sealer ![]() Primer/sealer down ![]() Fenders were backmasked to hide the tape line in the paint ![]() |
#18 |
Member#: 100353
We've got color. Went with PPG and tony went to pick out a chip that matched the 83k mile paint on the car.
![]() More color. Ended up doing about 4 coats. ![]() It was a cold day here in MN but I had the garage cooking to help with quick flash times to minimize the amount of dirt and dust that can find its way onto the paint while it's still wet. ![]() Painted the hinge and and fender bolts. ![]() Started shooting clear. This is when I GTFO of the garage. Got pretty nasty in there. ![]() We've got clear. Fun to see that go down, really pulls the gold and metallic out of the base. Sorry for the flurry picture, I'll snap some better ones now that the garage is clear of overspray. ![]() ![]() ![]() ![]() All things considered, I'm really happy with how it turned out. I don't think I'll be wet sanding or buffing it, as the clear went down really nicely. There are some specks of dirt and dusty here and there, but that's to be expected with an engine bay like this being shot in the garage in a day. Lots of snooks and crannies! |
#19 |
Member#: 100353
Also managed to find a daily driver this past week. I've been keeping an eye out for a clean LGT that I liked and one finally popped up. 2005 Legacy 2.5GT LTD, 1-owner Arizona car, never seen winter. Anyway, it's nice to have a smooth, comfortable car to commute in. It came with the 'gangster tint' option, so I'll probably be having it all removed and redone in a more manageable and less suspicious tone.
#20 |
Member#: 100353
So tired of unmasking!
#21 |
Member#: 240500
Vehicle:2006 STI SGM |
Subscribed
#22 |
Member#: 275798
NESIC
Vehicle:2005 Monster 2.61L Imola Gray/red pearl |
You sir practically have the same build going on that I do! So far it really is fun knowing that you car will be more your personality and not like every other subaru out there. Good luck with the build!
#23 |
Member#: 303165
Vehicle:2012 WRX SWP |
subscribed
#24 |
Member#: 100353
#25 |
Member#: 100353
Finally getting somewhere!
| Thread Tools | |
| Display Modes | |
| New Drop in fuel pump for 600whp | AZScoobie | Built Motor Discussion | 318 | 06-26-2007 11:49 AM |
| NJ: '02 WRX, 23K miles, STi 2.5 drivetrain BUILT, VF30, ready for 600WHP! | staticrex | Private Vehicle 'For Sale' Classifieds | 14 | 08-18-2006 01:18 AM |
| Fuel lines and pumps for 600whp+ | AlanG | Factory 2.5L Turbo Powertrain | 49 | 05-11-2006 03:24 PM |
| Pics of my goal for 600whp | MrH00nel2 | Factory 2.5L Turbo Powertrain | 135 | 01-15-2006 03:32 PM |
| Kings Quest I & II an Quest for Glory remade + free dl! | soundwave | Off-Topic | 19 | 09-15-2003 05:56 AM |
