Old 04-19-2012, 12:17 AM   #1
carlck19
Member#: 249890
1995 Impreza L wag
white
Default ej20g robs knock light
Hi guys,
So i have an ej20g v1 with robs tune on stock injectors.
Every possible maintenance has been done on the motor save for removing and cleaning/flowtesting the injectors
mbc at 15psi
full 3" catless
v2 sti slanty
coilpack conversion
In short the motor runs great and I hear no audible "knocking" at any time but often when I get on it the knock light flashes a significant amount, but I don't hear or feel anything out of the ordinary.
Are my injectors maxed out? Do I need to upgrade to the 550's? Is my knock sensor just overly sensitive/going bad?
In addition, whenever I go on the highway and come off my fans kick on immediately as if the car is running somewhat hot, but the temp needle doesnt actually budge at all. The car is closed deck so maybe it just runs somewhat hot??
Input much appreciated,
Alex
carlck19 is offline   Reply With Quote
Old 04-19-2012, 12:22 AM   #2
eg33GC
Member#: 206851
56 Belair
Pro Street
any codes?
have evoscan?
It is likely bad gas, a faulty knock or ect sensor.
eg33GC is offline   Reply With Quote
Old 04-19-2012, 12:30 AM   #3
carlck19
Member#: 249890
1995 Impreza L wag
white
no codes. What is evoscan?
Old 04-19-2012, 12:37 AM   #4
carlck19
Member#: 249890
1995 Impreza L wag
white
I have read that the ect sensor is only bad if the fans kick on automatically before even starting the car, with the ignition just turned to the "on" position. Is this true? do you have a p/n for the ej20g knock sensor and do you know where it goes?
Old 04-19-2012, 12:42 AM   #5
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
If you free rev does it flicker? I would recommend trying to lower the boost and see if the frequency drops. You can also run the tank low and put in 1/4 tank of race gas to see if it goes away. My custom code will flicker the CEL once the ECU has determined a real knock event has occurred and is taking action to counter.
One other important note is that one side effect of my code is that when the CEL comes one for a real code, the light does not stay on solid, it flashes real fast (almost looks dim). If you are getting an intermittent CEL, it might look like sustained, severe knocking. In that case you would be able to connect the black diag connectors and have it flash a code as normal.
-Rob
rob is offline   Reply With Quote
Old 04-19-2012, 12:47 AM   #6
carlck19
Member#: 249890
1995 Impreza L wag
white
free revving hardly makes it flicker, very rare. I will try lowering the boost and see what happens, I was going to try octane booster because i dont have easy access to race gas. Is it possible that my knock sensor is messed up in some way?
The car has no codes, btw.
Also, Rob, when will the z32 tune be ready?!?
Old 04-19-2012, 12:54 AM   #7
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
Another comment I will make is the stock temp gauge is near useless. The needle will basically stay parked in the same "normal" spot between 160-220F.
Old 04-19-2012, 12:55 AM   #8
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
How dare you.
Old 04-19-2012, 12:55 AM   #9
carlck19
Member#: 249890
1995 Impreza L wag
white
if turning down the boost fixes the knock light issue, do you think I should upgrade injectors?
Old 04-19-2012, 12:56 AM   #10
carlck19
Member#: 249890
1995 Impreza L wag
white
Originally Posted by rob View Post
How dare you.
Old 04-19-2012, 12:56 AM   #11
eg33GC
Member#: 206851
56 Belair
Pro Street
no, figure out why youre knocking.
I assume you NAW YAWKAs don't get the creme de la creme of fuel.
Old 04-19-2012, 12:58 AM   #12
carlck19
Member#: 249890
1995 Impreza L wag
white
i suppose not. but I don't hear the motor knocking and it runs fine, I don't see what there is to figure out...
Old 04-19-2012, 01:02 AM   #13
eg33GC
Member#: 206851
56 Belair
Pro Street
you can't hear knock inside the vehicle while driving. it is not rod knock, it is pre detonation in the cylinders.
knock has a few causes:
fuel
air temp
oil reducing octane
timing
exceeding mechanical limits, ie too high boost, too lean, too much timing, too much fuel
faulty equipment- faulty maf/tps (that are the load basis of the ecu), ect (dictator of fuel and timing allowances)
We also have a very lean throttle tip in value, so it is not coincedental this happens right when you get on it
Old 04-19-2012, 01:09 AM   #14
carlck19
Member#: 249890
1995 Impreza L wag
white
fuel
air temp
oil reducing octane
timing
thanks for explaining the difference, I appreciate it. I do believe that "oil reducing octane may be partly to blame for this and I am going to do a catchcan setup asap to see how that does.
Old 04-19-2012, 01:11 AM   #15
eg33GC
Member#: 206851
56 Belair
Pro Street
I noticed a bit of icky getting into my G inlet system, but I am not using a fuel succeptable to any octane loss of significance
Old 04-19-2012, 01:15 AM   #16
carlck19
Member#: 249890
1995 Impreza L wag
white
^what fuel is that haha
Old 04-19-2012, 01:17 AM   #17
eg33GC
Member#: 206851
56 Belair
Pro Street
ethanol
Old 04-19-2012, 01:19 AM   #18
carlck19
Member#: 249890
1995 Impreza L wag
white
nice; shouldve noticed from yr vehicle info lol. yeah i notice the knock light mostly on throttle tip in i would say. how concerned should i be about this?
Old 04-19-2012, 11:17 AM   #19
carlck19
Member#: 249890
1995 Impreza L wag
white
filled the tank up halfway with gas from a diff station and turned the mbc down half a turn and no more knock light! does this just mean i was exceeding mechanical limits (i.e. fuel) by having the boost too high and maxing out the injectors?
-Alex
Old 04-19-2012, 12:30 PM   #20
DonnIefnoker
Member#: 294590
2004 Wrx sti
You would have to try the gas with the boost up to know which one was the problem lol but id be afraid to turn up the boost if i was getting a significant knock. up to you haha i would stick w what works have fun get bigger injectors or get yours modded crank up that boost
DonnIefnoker is offline   Reply With Quote
Old 04-19-2012, 01:14 PM   #21
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
There are actually a couple of unasked obvious questions.
First:
What octane are you actually running. Where is the fuel from? Are you consistently running fuel from the same station?
Second:
Have you installed any actual gauges or are you trying to diagnose the issues only operating with information from Rob's knock lite and the Factory water temp gauge which really isn't actually a gauge as it is a needle that gives you a thumbs up/thumbs down on water temp with no useful data in between.
Third: The water temp sensor on my EJ20G was quite screwy. The idle and fan operation completely changed when I replaced mine. There are actually two water temp sensors; one for that useless gauge and one for the ECU. It cost me $18 to replace to water sensor that goes to the ecu. Totally worth it.
Fourth more useful gauges: oil temp, real water temp, A/F ratio(even if its a cheapo non wideband). Do you have any way to tell if you perhaps have a clogged injector causing one cylinder to run lean and therefore hot? What is your fuel pressure @ right now? Low fuel pressure can result in a lean condition in all cylinders.
TommyAtomic is offline   Reply With Quote
Old 04-19-2012, 08:36 PM   #22
carlck19
Member#: 249890
1995 Impreza L wag
white
First:
Second:
thanks for the advice!
1. im running 93 octane, the bad appearing gas was from a mobil station, and i just filled up at a 7 11 and their gas is the one i get most and don't have any issues with generally.
2. I have not monitored with actual gauges but my next purchases will be catch cans and an aem wideband so i should be able to feel things out better.
3. Should I replace the ect temp sensor? Where is it located on the motor?
4. I do have a walbro in the car but how would i measure fuel pressure?
Since The knock light activity has gone away maybe it was just too much boost to handle on this injector setup, but I will continue to work towards fixing this issue anyway.
Old 04-19-2012, 10:35 PM   #23
DonnIefnoker
Member#: 294590
2004 Wrx sti
Advanced auto sells a $40 fuel pressure test kit which doesnt really mate up to the car so i bought 2 5/16 hose barbs that mate up to the t block the kit came with cut ur fuel inlet line put it in line good to go give me ur email i can semd u a pic if ur not completly sure what i mean
Old 04-21-2012, 07:43 AM   #24
steveomiami
Member#: 309883
Can you send me a pic of it too? I'll pm you my email
steveomiami is offline   Reply With Quote
Old 04-21-2012, 04:26 PM   #25
carlck19
Member#: 249890
1995 Impreza L wag
white
FS : (VA) ej20g stuff(inj, pfc, lights+more) Subbiespeed Engine/Power/Exhaust 15 05-10-2012 08:22 PM
FS : TurboXS KnockLite - stealth flat black - knock light and shift light TROLL Engine/Power/Exhaust 0 02-03-2012 12:17 PM
ej20g rod knock renegado Pre-2002 Factory Turbo Powertrain 6 04-28-2011 06:03 AM
knock light on tuner hondaeater69 Engine Management & Tuning 19 10-27-2004 03:33 PM
Knock light at very light throttle? mr2guru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-10-2004 12:43 PM
