Old 04-19-2012, 09:03 AM   #1
abond2014
Member#: 295730
2008 impreza OBS
obsidean black
Question 2011 Rockford Fosgate P3's or Alpine type R's
hey guys so i had alpine type r's for a couple of months but they blew okay but for my next subs i am looking for even more powerful and or louder subs that are durable and was recommended the P3's and was told they are better and louder than the R's so do you guys recommend any others? and what do you think about the 2011 P3's vs R's Thanks guys for your help!
abond2014 is offline   Reply With Quote
Old 04-19-2012, 10:41 AM   #2
Faalin
Member#: 316660
2012 WRX limited
What amp are you running for those r's, also which ones were they dual 2ohm or dual 4ohm?
I ran two dual 4ohm 12" r's each with their own 1000watt alpine v-power amp and never blew one. I have since upgraded to 12" x's with 2000w v-power amps, have had these for 3 years now and still going strong.
Faalin is offline   Reply With Quote
Old 04-19-2012, 11:24 AM   #3
speakerpimp
Member#: 241673
2011 WRX
Spark Silver
+1 Shouldn't be blowing type-r, somethings wrong.
speakerpimp is offline   Reply With Quote
Old 04-19-2012, 11:55 AM   #4
RSXtoWRX
Member#: 213683
2007 WRX TR
UGM
abond2014: It is all about the box design. You cannot go wrong with either brand. I have worked with both companies and designed custom boxes for them and they both sound phenomenal. You can make a lower powered sub sound like it has more than what it is or a high powered sub sound like doo doo.
RSXtoWRX is offline   Reply With Quote
Old 04-19-2012, 02:59 PM   #5
SQ Dreamer
Member#: 317253
^Looks like this guy has this thread covered. Excellent. OP, I'd give this post another look. Amplifier? Space? ...etc?
...."I have speaker "X" & they sound great. Go with Speaker X" is not going to do you any good.
cough, cough, t-line lol
SQ Dreamer is offline   Reply With Quote
Old 04-19-2012, 05:36 PM   #6
speakerpimp
Member#: 241673
2011 WRX
Spark Silver
The type R has more xmax as well as power handling than the P3. You really shouldn't be blowing them, either acoustically or electrically you are doing something wrong...
Old 04-19-2012, 09:41 PM   #7
abond2014
Member#: 295730
2008 impreza OBS
obsidean black
the amp is an hifonics brz 1200 the subs were dual 4 ohm and the box was sealed at 1.5 cu ft total 7.5 per sub
Old 04-19-2012, 09:43 PM   #8
abond2014
Member#: 295730
2008 impreza OBS
obsidean black
do you think they were factory defected?
Old 04-19-2012, 10:14 PM   #9
speakerpimp
Member#: 241673
2011 WRX
Spark Silver
Did they both blow? Give every detail, did all four voice coils blow? Were the cones frozen in place? Did they blow at the exact same time? Were there funny noises or complete silence??
The setup is great, shouldn't have had any problems, and Hifonics makes their gains idiot proof(not calling YOU an idiot...) so it should have been very difficult to blow that setup.
Old 04-19-2012, 10:45 PM   #10
Faalin
Member#: 316660
2012 WRX limited
if you wired these to a 1 ohm load your amp would only put out 1200 watts, if your running ether a 10 or 12" sub they should handle this with no problem.
One problem might be is that you have the gain set to high and it is clipping the amp causing excessive heat in the sub coil causing premature failure of the sub.
This all comes down the the sub size. The only type r sub to worry about is the 8" that can only handle 350/1000 watt then you would have to wire the pair of subs to 4ohms for them to be ok.
Old 04-19-2012, 11:18 PM   #11
djinn
Member#: 212818
2010 Impreza 2.5i
Satin White Pearl
Yeah, those Type R's are able to handle 1000w each without a problem.
Must be tuned wrong.
djinn is offline   Reply With Quote
Old 04-20-2012, 12:05 AM   #12
abond2014
Member#: 295730
2008 impreza OBS
obsidean black
they make a weird rattling noise occasionally, and one might stop for a bit then start back up, i am going to get more detailed about it tomorrow and let you know what is going on
Old 04-20-2012, 04:42 PM   #13
RSXtoWRX
Member#: 213683
2007 WRX TR
UGM
I am assuming you have 2 12s. .75 is enough for sealed enclosure for tight bass. From what I understand you want louder than the previous set up go ported but you will end up sacrificing a lot of space in your trunk. Keep in mind the type of music you are into as well. I know everyone says I listen to everything, but break it down to what you listen to the most. What is your end goal? I noticed your are in MA too. State is cracking down on noise pollution
In all honesty and my 2cents. Stick with one high wattage sub in a ported box
Alpine R 600w RMS or Rockford P3 400w RMS. I'd recommend Arc Audio Black series.
Old 04-20-2012, 10:31 PM   #14
CSVT_2004
Member#: 182213
1999 Contour SVT
Should be about a perfect match. Assuming the subs were all wired correctly and in parallel to make a 1ohm load.
I used to do car audio, every "bad" sub I had come back was always user error.
Correction they handle 600watts RMS a piece. Max power is not a rating to go by by any means! Tuning is a highly likely suspect for this issue. Lots of new installers don't notice when there speakers are clipping and they end up frying out their new equipment. Also it's good to go through a break in period with new subs.
Also the P3's and the Type R's handle the same amount of power (600 watts RMS) Someone stated earlier they were different.
CSVT_2004 is offline   Reply With Quote
Old 04-20-2012, 10:37 PM   #15
RSXtoWRX
Member#: 213683
2007 WRX TR
UGM
oops I was looking at the shallow p3 Yes both are 600w RMS. Thanks for the correction
Old 04-21-2012, 12:16 AM   #16
djinn
Member#: 212818
2010 Impreza 2.5i
Satin White Pearl
Yes, RMS is 600w but having been in car audio for a while, I have seen people put 1000w RMS to it without a problem. All depends on the tune and box hertz/frequency
Old 04-23-2012, 08:39 PM   #17
abond2014
Member#: 295730
2008 impreza OBS
obsidean black
is one more loud or durable than the other ?
Old 04-23-2012, 10:39 PM   #18
djinn
Member#: 212818
2010 Impreza 2.5i
Satin White Pearl
I personally like the Type R much better because of the construction. The Rockfords have plastic cones which can break very easily.
As for the being loud part, that would depend on your setup (box, tune, power, and car). Hatches are usually louder than sedans because of the box being in the same cabin space as the driver.
Old 04-24-2012, 07:28 AM   #19
speakerpimp
Member#: 241673
2011 WRX
Spark Silver
TypeR=
bigger voicecoil
more excursion
more power handling in the 10"(still don't know what size we're talking about OP!!)
stronger magnet
better constuction
Old 04-24-2012, 05:48 PM   #20
abond2014
Member#: 295730
2008 impreza OBS
obsidean black
We are talking 12" but when i play the subs one of them goes in and out of playing and they make this really weird muffling noise
Old 04-25-2012, 09:05 AM   #21
guygettnby
Member#: 298231
2011 WRX
IMHO the type R's are better and you shouldnt have blown that sub with the setup you had unless you did something wrong.
i have a single 12in type R running 750w rms at 1 ohm in a tuned slot vented enclosure right now. it is very loud in my 11 wrx hatch and i couldnt see needing anything more then that in my car unless you need it louder for shows or what not.
guygettnby is offline   Reply With Quote
Old 04-25-2012, 12:19 PM   #22
CSVT_2004
Member#: 182213
1999 Contour SVT
Probably a blown voice coil. How did you wire your subs?
http://www.rockfordfosgate.com/rftec...2&woofer_imp=4
Old 04-25-2012, 05:27 PM   #23
abond2014
Member#: 295730
2008 impreza OBS
obsidean black
im not sure best buy wired em
Old 04-25-2012, 06:19 PM   #24
bpang1
Member#: 67225
2015 Audi S4
Red
^^^Well that could be your problem.
bpang1 is offline   Reply With Quote
Old 04-25-2012, 09:35 PM   #25
big_mac127
Member#: 315999
Not all best buy installers are bad
big_mac127 is offline   Reply With Quote
I just got two alpine type r's and a alpine m1000 amp 07STi TX Car Audio, Video & Security 47 04-02-2011 09:31 AM
WTS Alpine Type R's (12 Inch) w/ box Scooby89 Interior/Dressup/Audio & Security 3 09-19-2007 08:38 PM
Alpine Type R's Scooby89 Interior/Dressup/Audio & Security 8 09-07-2007 12:59 PM
2 Alpine Type R's in a sealed box -=Ice-T=- Private 'For Sale' Classifieds 1 06-28-2006 09:41 PM
FS: 2 alpine type r's and mtx amp kedrin Private 'For Sale' Classifieds 1 11-19-2003 06:29 PM
