Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 04-19-2012, 09:44 AM   #1
jonclarke
Member#: 289159
2007 Impreza 2.5i SE
CGM
Default Doing 07 2.5i gaskets at 87k
Aside from switching to mls gaskets off the sti... What else should I do while I'm in there.
Ive heard some suggest
Engine mounts - not too sure about this one. I have a but of noise already and I hear these can add a lot.
Arp head studs. Not too sure what the benefit would be on an i but... Weigh in please.
Clutch. How do I measure the clutch wear?
jonclarke is offline   Reply With Quote
Old 04-19-2012, 10:06 AM   #2
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
I feel like just getting to the clutch to inspect it would be a hell of a job. I'd wait until it starts to slip.
chazly413 is offline   Reply With Quote
Old 04-19-2012, 10:08 AM   #3
skep18
Member#: 214971
2014 WRX
wait, what gaskets are you replacing? and why? 87k seems pretty low mileage...
skep18 is offline   Reply With Quote
Old 04-19-2012, 02:09 PM   #4
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
On my former bugeye the HGs blew at ~110 k (170 000km) . Replaced the clutch since the engine was yanked out. Clutch wear? Compare the thread dept with respect to a new one, it will be fairly obvious. You could also do the timing belt and pulleys, since the TB is out anyways. Alltogether, it's one massive maintenance bill, but will give you another 160 000 km free of worries...
Old 05-03-2012, 08:29 AM   #5
fabiosugitani
Member#: 285398
2010 2.5i Premium WG
Spark Silver Metallic
I had to do my headgaskets at 43.000 last month
Was out of warranty but SOA offer to pay for the parts.
But in my case, the reason is probably because has been hit in the driver front fender.
Even if the damage was minor.
So far I had to do headgasket in EVERY Subaru I've own.
96 Legacy with 136.000
97 Legacy Wagon with 132.000
03 Baja with 108.000
07 Impreza with 43.000
fabiosugitani is offline   Reply With Quote
Old 05-03-2012, 09:41 AM   #6
scarney1988
Member#: 317760
Will the engine be coming out of the car?
if so
  1. clutch, pressure plate, and TOB
  2. Reseal kit (head,intake, exhaust,valve, etc...)
  3. Timing belt/WP/rollers/tensioners/ serp belt
  4. 2 cans engne degreaser (clean that bad boy up)
  5. Tune-up (Air filter, Plugs, PCV, etc..)
  6. Soap and water (clean out engine bay while you have nice opening
  7. If coolant and oil got mixed, ide do a coolant flush (prestone kit or something) to flush gunk out of all coolant passages
Above all, do what you can afford, and get yourself on the road again. If engine is staying in car, just do gaskets and and TB/WP and call it a weekend or two.
scarney1988 is offline   Reply With Quote
07 2.5i 88k leaking head gasket sittinsideways Normally Aspirated Powertrain 6 04-14-2011 09:17 AM
Do 4 pots and stock 07 2.5i wheels fit? Nitrous Newbies & FAQs 2 11-06-2010 01:24 PM
Help with 07 2.5i AT Engine Management djrasta Other Engine Management 0 04-27-2010 11:41 PM
EM options for 07 2.5i AT djz05 Normally Aspirated Powertrain 8 01-28-2010 04:26 PM
WTB: 2.5i Midpipe / 06/07 2.5i CAI Setup / Exhaust Shield deviantek NWIC Private Classifieds 3 08-17-2007 02:21 PM
