Old 04-19-2012, 01:13 PM   #1
legacy420
Member#: 297319
2003 liberal
swine resurrected
Default A/C leak...part number for gasket or o ring?
Well, summer is coming up and thought I should fix my A/C. I've done a few charges to see how bad the leak was and it's holding a can of 134a for about a week and a half. Finally did a dye test this morning, and found the leak was coming from the top side of the compressor where the hard line goes to.
is this just an o ring or gasket or will i have to replace more?
Part numbers would help as well! Thanks so much, and please do add any information to make this fix legit. Thanks!
legacy420 is offline   Reply With Quote
Old 04-19-2012, 04:29 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Your dealer has part numbers, that's their job. Unless you want to save 9 cents by part number shopping this across 32 dealers on an o-ring whose full retail value is $2.12. To make it legit, you'll need to take it to a pro and have them suck, swap, then refill.
Old 04-19-2012, 06:31 PM   #3
legacy420
Member#: 297319
2003 liberal
swine resurrected
i have a pro ready to do the fill as he did the dye test (i supplied the can). He's just chargin a few bucks for labor. Got a part number from the dealer just now, thanks! Its just under two bucks...but i have to drive 43 miles to get it. Ack
Old 04-20-2012, 09:06 PM   #4
awdtoy
Member#: 152728
2006 WRX TR
isn't it just an O-ring? Pull it out. Take to local store to match up.
awdtoy is offline   Reply With Quote
Old 04-21-2012, 02:21 PM   #5
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Pulling it out vents the system. Freon is expensive and I'm 99% sure its "illegal" to do it that way.
Old 04-21-2012, 02:27 PM   #6
kakdaman
Member#: 245117
2005 wrx
aspen white
Had the same symptoms as you, only holding pressure for a week or so. Did the dye test and found a dry rotted o-ring! Works beautifully now!
kakdaman is offline   Reply With Quote
Old 04-21-2012, 02:42 PM   #7
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
technically if all the freon has already leaked out, he's not going to be discharging anything in the atmosphere if he takes it off to replace the o-ring.
amirite?
z is offline   Reply With Quote
Old 04-21-2012, 05:23 PM   #8
kakdaman
Member#: 245117
2005 wrx
aspen white
amirite?
If he failed the pressure test, the yes that is correct.
Old 04-24-2012, 09:19 AM   #9
billzebub
Member#: 40248
2003 WRX
Midnight Pearl (black)
Driving around with a leak is technically illegal, too, but who is issuing EPA citations for this?
billzebub is offline   Reply With Quote
Old 04-24-2012, 02:31 PM   #10
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
You are right, my cause was mainly having to pay for more freon as if you do a full service, they would suck the freon, swap out the oring, fill will freon and you'd be out the door for the normal $49.95 service fee rather than the $49.95 service fee + $25 for 1.2 lbs of freon or whatever it is.
Old 05-02-2012, 03:36 PM   #11
soobydo
Member#: 24716
1996 Outback Sport
Dark Blue
You can get R134a O-ring assortment kits at just about every auto parts store this time of year. they're green in color and there are about 4 different sizes. You won't be able to put the wrong sized one on there.
soobydo is offline   Reply With Quote
Old 07-28-2012, 01:05 AM   #12
oaklandish_WRX
Member#: 267339
2002 0[[XXXXoXXXX]]0
MBP LongRoof
sorry for bump...
trying to replace the high pressure hose - got a good shape used one with o rings. Also, to be cautious I got OEM o rings (P/N 73039AA030 or PT751093) but the OEM rings are WAY different in size. Well, different enough to make me suspicious. The ID seems too large, and the thickness too small.
guess I can try the sampler kit from AZ or oreilly/kragans.
halp...
oaklandish_WRX is offline   Reply With Quote
Old 08-01-2014, 09:22 PM   #13
SLOMatt
Member#: 5040
2002 WRX Cobb Stg2
Platinum Silver Metallic
For future reference here are the part numbers for the o-rings on the compressor side of the A/C hoses (for a 2002 WRX 5spd).
high side A/C hose o-ring: 73039FA100
low side A/C hose o-ring: 73039AA300
- Matt
SLOMatt is offline   Reply With Quote
part number for cam angle sensor o ring methaddict Built Motor Discussion 4 04-20-2009 09:14 PM
Part number for Sidefeed Injector O Rings? GeorgeRex Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 10-18-2005 11:11 AM
Help! Part numbers for uppipe/downpipe gaskets? RimRockaz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 08-05-2002 04:50 PM
need part number for those gaskets when changin uppipe WRxednEffect Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-04-2002 11:33 AM
