Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Closed Thread
Old 04-19-2012, 03:02 PM   #1
Rev Works
Vendor Sales Rating: (12)
Member#: 305656
05 STi
Cool Best Suspension Prices! BC Racing | Megan Racing | Whiteline | GTSPEC | Eibach+More!
Rev Works is your Subaru Specialist shop and we aim to provide the best possible customer service and support you can find. We will not be beat on price, so if you find it somewhere cheaper we will do our best to match or beat the price!
Ever wonder if being a NASIOC member had any benefits? Well with us it does! Enter the coupon code NASIOC at checkout to receive and extra 5% off your order!
BC Racing Coilovers - All BC's come with FREE ground Shipping!
Mono-tube shock design
30 levels of damping force adjustment, adjust compression/rebound
Pillowball mounts and adjustable camber plates included (where applicable)
Adjustable rear camber plates available
Separate full length height adjustable
One year warranty
Rebuildable
Megan Racing Coilovers- Free Shipping!
- 32 Levels of Damper Force Adjustment
- Pillow Ball Upper Mounts
- Rubber Dust Boots
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
Eibach Sway Bar's and Sway Bar Kit's
Reduce body roll and fine tune your WRX or STI's handling characteristics with a set of Eibach Anti-Roll-Kit front and rear sway bars. These sway bars are manufactured from cold-formed, high-strength aircraft-grade steel and or sold as an entire kit or as individual front/rear kits. The front & rear combo kits include end links, bushings, all necessary mounting hardware and instructions for easy installation. End links are included where noted.
Click here or PM for Pricing!
GTSPEC Suspension Arms and Chassis Braces
Trailing Arms
Differential Mounts
Fender Braces
Ladder Brace
Subframe Brace
Whiteline Suspension
Whiteline Bumpsteer Kit's
Whiteline Sway Bars
Whiteline Adjustable Arms
Roll Center Kit incorporates 2 steering arm tie rod ends and 2 ball joints and is designed to raise front roll-centre geometry after lowering the vehicle and also improve on the original bump-steer geometry. Changing front suspension geometry by raising roll-centre, results in substantial increase to roll resistance and significant reduction of suspension compression of outside front wheel during cornering through improved weight transfer distribution. Whilst bump steer correction via extended tie rods aids in minimizing steering angle input during suspension articulation.
Whether you need just a little more control over your cars alignment or a lot, Whiteline has a set of adjustable rear suspension arms to suit your needs. If you only need to make minimal adjustments beyond the OEM settings the Whiteline KTA107 Adjustable Lateral Link should fill the bill. The Adjustable Lateral Links includes the front lateral links and upgraded bushings for the rear control arm. These Adjustable Lateral Links will enable you to fine tune your 02-07 WRX/04-07 STI's toe.
Looking for something and didn't find it here or on our website? We are constantly updating out website and carry tons or product lines. Send us a PM or email us at [email protected] with any and all questions!
We look forward to earning your business.
__________________
[COLOR=Red][I][B]
-[/B][/I][/COLOR][COLOR=Red][I][B] We will not be beat on price![/B][/I][/COLOR][COLOR=DimGray][COLOR=Black][U]
Phone[/U][/COLOR]-407.542.7[COLOR=DimGray]863[/COLOR][/COLOR]
[COLOR=DimGray][COLOR=Black][U]Email[/U][/COLOR]
[/COLOR]
Rev Works is offline
Old 04-19-2012, 05:17 PM   #2
Rev Works
Member#: 305656
05 STi
ISC N1 Coilovers:
ISC N1 Coilovers offer a great ride, quality construction and excellent fitment. These coilovers offer real adjustment that allows you to dial these in to fit your exact needs and driving style.
The N1 coilover can be lowered approximately 3 inches lower then standard ride height, this along with a spring rate setup to suit your car improves handling and stability dramatically. we make packages for track/rally/drag and of course street, to help our customers out even more we give them the option to pick there own custom spring rates at no extra charge.
Spring Rate:
8kg / 448lbs Front
6Kg / 336lbs Rear
32 Step Damper Adjustable
Precise control dampening valve
Operates smoothly on all road surfaces
Expansion/Suppression of shock adjustment
Pillowball Uppermount
Adjustable camber allows more/less on road track for all conditions
Piston Rod Design
High rigidity steel piston rods
Meets with race/sport standards
Sports Spring
Made from high quality SAE9254 steel
Tested over 500,000 times on compression inspection with less than 5% deformation.
Choose from Street Comfort, Street/Sport or Track/Race (spring rates vary depending on application, for specs check the application guide or ask us when you order, custom spring rates are free).
Ride Height Adjustable
Full length height adjustable
Bound adjustable with separate spring locks
High quality T6061 aluminum alloy used for all adjustment locks to provide a lightweight design that holds spring and vehicle down force.
Aluminum Bracket
Made from T6061 aluminum alloy by organic shaping to lighten weight and increase handling performance
Specifically anodized surface to prevent inside corrosion and surface rust
Camber can also be adjusted via the bracket as well as the camber tops
Single Cylinder Design
Larger cylinder and piston design to advance driving stability and dexterity
http://www.revworksinc.com/ISC-N1-Co...STi_p_479.html
We've got these and much more available on www.revworksinc.com!
WE WILL NOT BE UNDERSOLD OR BEAT! LET US KNOW HOW WE CAN EARN YOUR BUSINESS[/size]
Tanabe Springs
The ultimate in performance and styling, the Tanabe Sustec GF210 lowering springs are designed to add better handling and performance to your vehicle in addition to reducing wheel gap with a clean sleek look. GF210 lowering springs will function great with your stock shock absorbers, though performance can be enhanced to an even higher level when installed in conjunction with set of performance shocks. GF210 springs feature Tanabe's Sustec 210 technology, a unique manufacturing process designed to produce superior strength and durability. The GF210 adds a 20-30% more aggressive spring rate, providing an extreme reduction in body roll and geometric pitch through tight cornering. If performance is what you want, the Tanabe Sustec GF210 lowering springs are what you need!
02-03 Drop: F: -1.5 / R: -1.0
02-03 Spring Rates: F: 3.0kg/mm R: 2.8kg/mm
2004 Drop: F: -1.3 / R: -1.0
2004 Spring Rates: F: 4.3kg/mm R: 4.0kg/mm
05-07 Drop: F: -1.0 / R: -0.5
05-07 Spring Rates: F: 5.8kg/mm R: 4.4kg/mm
KW Variant 3 Coilovers
If you require the absolute pinnacle of suspension technology, the KW Variant 3 coilover system is for you. Variant 3 coilovers take KW innovation to an even higher level, integrating 14-way adjustable compression with infinitely adjustable rebound control in conjunction with custom ride height flexibility. Featuring patented two-stage valve technology, V3 coilovers provide handling enhancement that will function dynamically at both low-speed and high-speed driving. External shock reservoirs are implemented to increase oil capacity for longer life and more consistent damping. V3 drivers are treated to an unmatched performance experience with more responsive and predicable handling at every corner. If you need to run on a professional level, look no further than KW Variant 3.
Spring Rate (F/R): 340lbs/in / Prog
Drop Rate (F/R): -0.8-2.0in / -0.8-2.0in
GTSPEC Bump Steer Kit
[/u][/size] GTSPEC Roll Center/Bump Steer kit is a must on all lowered vehicles. Lowered vehicles that are not equipped with this kit are prone to poor alignment geometry. With the GTSPEC Roll Center/Bump Steer kit install, correct alignment geometry is regained and stress on the suspension components will be reduced. Our roll center kit will also produce a reduction in bump steer, re-alignment of camber/caster, increase stability, improvement in steering feel and response, and reduction in under steer. While other kits on the market are cast, the GTSPEC Roll Center/Bump kit is FORGED; known to last under harsh driving conditions.
$359 Shipped to your door!!
Stance Coilovers
  • 15-Way Damping Adjustable
  • Adjustable Camber Uppermount
  • Pillowball Uppermount
  • Cold Wound Linear Spring
  • Inverted Monotube Shocks
  • Dustboot
  • Aluminum Collars & Upper Mounts
  • Height Adjustable Lower Bracket
PM FOR PRICING!!!
GTSPEC Rear Control Arms With Camber Adjustment 08+ WRX \ STI
The GTSPEC rear control arm replace the stock control arms and allow you to dial in custom rear camber settings according your driving style. GTSPEC rear camber arms also incorporate a +30mm bend to compensate for the added stress that the control arms endure when lowering the body of your vehicle, a feature unmatched by any similar products on the market. The GTSPEC rear control arms are the first WRX arms on the market that are built with forged 7075 aluminum end joints for unprecedented strength and durability.
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 04-20-2012, 10:57 AM   #3
Rev Works
Member#: 305656
05 STi
Weekends almost here!
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 04-20-2012, 05:22 PM   #4
Rev Works
Member#: 305656
05 STi
Off to go play racecar down in Sebring! We will respond to all PM's and inquires when we are back from the track. Have a great weekend!
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 04-23-2012, 11:33 AM   #5
Rev Works
Member#: 305656
05 STi
Happy Monday Bump!
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 04-23-2012, 12:27 PM   #6
ragejed
Member Sales Rating: (27)
Member#: 76817
2005 WRX
Price shipped on BC coilovers for my05 wrx to 06824
ragejed is offline
Old 04-23-2012, 12:30 PM   #7
Rev Works
Member#: 305656
05 STi
^PM'ed
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 04-23-2012, 04:59 PM   #8
Rev Works
Member#: 305656
05 STi
Thank you for the orders and all the inquiries! Keep 'em coming!
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 04-24-2012, 10:45 AM   #9
Rev Works
Member#: 305656
05 STi
All PM's replied to!
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 04-25-2012, 12:32 PM   #10
Rev Works
Member#: 305656
05 STi
Weeks halfway over
Bump!
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 04-25-2012, 08:57 PM   #11
Rev Works
Member#: 305656
05 STi
Bump!!
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 04-26-2012, 11:50 AM   #12
Rev Works
Member#: 305656
05 STi
Happy Thursday Bump!
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 04-27-2012, 12:13 PM   #13
Rev Works
Member#: 305656
05 STi
Friday bump!
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 04-29-2012, 04:54 PM   #14
Rev Works
Member#: 305656
05 STi
Weekend PM's replied!
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 04-30-2012, 01:34 PM   #15
Rev Works
Member#: 305656
05 STi
Just finished replying to the PM's over the Weekend.
Bump!
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 05-01-2012, 11:22 AM   #16
Rev Works
Member#: 305656
05 STi
Bump!! Thanks for the Orders!
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 05-02-2012, 10:35 AM   #17
Rev Works
Member#: 305656
05 STi
Good Morning Bumping
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 05-03-2012, 11:18 AM   #18
Rev Works
Member#: 305656
05 STi
PM's replied
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 05-04-2012, 10:18 AM   #19
Rev Works
Member#: 305656
05 STi
Its Friday! Who wants an amazing deal??
PM me!
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 05-05-2012, 02:26 PM   #20
Rev Works
Member#: 305656
05 STi
Weekend PM's returned!
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 05-07-2012, 11:29 AM   #21
Rev Works
Member#: 305656
05 STi
Replied to everyone from the weekend.
Start of a new week
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 05-07-2012, 08:47 PM   #22
Rev Works
Member#: 305656
05 STi
Thanks for the orders!
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 05-08-2012, 01:37 AM   #23
WRX_Impreza07
Member Sales Rating: (2)
Member#: 155317
07 WRX Impreza
obsidian black pearl
price shipped on BC COILOVERS for my07 to 77049
WRX_Impreza07 is offline
Old 05-08-2012, 10:49 AM   #24
Rev Works
Member#: 305656
05 STi
PM's sent!
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 05-08-2012, 07:02 PM   #25
Rev Works
Member#: 305656
05 STi
Bump!!
__________________
[COLOR=Red][I][B]
[/COLOR]
Closed Thread
Slowboy Suspension super sales!!! D2/Ksport/BC/ISC/Megan Racing Built Industries Suspension/Brakes/Handling 3 06-16-2011 04:50 PM
WE HAVE THE BEST DEALS On BC Racing | KW | Whiteline | Kartboy | TiC | Megan & More! Circuit Motorsports Suspension/Brakes/Handling 418 02-28-2011 06:11 PM
Hot German Girls Inside - Kw Coilovers Best Suspension Pricing Ever Super Gb!!! TH motorsports Vendor 'Group Buy' Classifieds 77 05-21-2010 01:16 PM
BC Racing, Whiteline, Stoptech, Hawk, Perrin, megan racing, Tein and so much more! IMPORTIMAGE Suspension/Brakes/Handling 1698 10-06-2009 12:50 PM
