Old 04-20-2012, 09:51 PM   #1
monkiboy
Member#: 202958
2008 wrx
Cool monkiboy's borg efr 7064 full-race build
hi. figured i'd post up on here to reach folks that might be interested in the build for reference or mere curiosity.
this isn't a build journal. i have one of those here, if anyone cares for more detail but i will upload some random photos of the steps i've taken to get here just to create a basic idea of where the car is at.
so, this will likely just be information as it relates to this build as things are beginning to come to their conclusion and i wanted to share my excitement, up/downs, etc with nasioc for ideas, motivation, and adding to the reference base.
so on tuesday (24th) the car heads over to IAG to "finalize" the build.
they will be installing the full-race kit, the efr turbo, rotating my jdm v8 intake manifold, fabricating fmic piping and intake, finishing the install of the aquamist hfs-4 meth/water system, fabbing endtanks and a core for FMIC use, fabbing a bumper beam, installing and creating a basic new fuel system, and hopefully not dealing with too many headaches along the way.
boris at IAG will be snapping photos along the way and hopefully uploading directly here (if he has time) or providing to me so i can upload, accordingly to share the progress they make.
thanks for reaching and look forward to sharing my build with you folks!
here is the partial mods list:
engine:
- built short-block:
manley pistons (standard bore)
manley h-beam rods
nitrited crankshaft
acl race main/road bearing set
arp head stud kit
oem oil cooler retrofit
- full-race twin-scroll kit
- bw 70/64 IWG twin-scroll turbo
- aquamist hsf-4 meth injection system
- jdm powdercoated long-runner intake manifold
- kstech MegaMAF cai w/ heatshield
- kstech 6.5mm phenolic spacers
- kstech air pump delete set
- kstech air injection delete
- gs ebcs
- beatrush pitch stop
- perrin turbo inlet
- txs fmic
- killer b optimal oil pan
- killer b ultimate oil pick up
- killer b ultimate baffle windage tray
- walbro 255lph fuel pump
- id1000 injectors
- ngk "one step colder" spark plugs
- cobb crank pulley
- crawford AOS
- perrin single piece dp
- invidia q300 dual exit resonated cbe
transmission & drivetrain:
- 05 sti 6 speed transmission swap
- dccdpro (spiider) universal dccd controller w/ oem sti controls
- act xtreme performance street disk/pressure plate
- act streetlite flywheel
- dss custom carbon fiber driveshaft
- cobb 6mt short shifter
- beatrush 6mt transmission mount
- group n motor mounts
- group n crossmember transmission bushings
- whiteline rear differential mount inserts
- cobb front/rear shifter bushings
braking:
- sti brembos (front/rear)
- stoptech performance pads
- 04 wrx master cylinder/booster
- goodridge ss brake lines
- dba slotted rotors
suspension:
- ast 4100 coilovers
- perrin subframe lockdown system
- whiteline anti-lift kit
- whiteline rear diff mount inserts
- whiteline gearbox mount bushings
- whiteline roll-center & bump-steer kit
- whiteline upper control arm rear camber kit
- whiteline front inner control arm bushings
- whiteline rear trailing arm bushings
- whiteline rear adjustable lateral/toe arms
- avo steering rack bushings
- megan rear lower control arms
- perrin f/r endlinks
- perrin f/r "hard" sways
- cusco type II lower bar
- cusco front member power brace
- cusco rear member power brace
- cusco rear lower power brace
- cusco front strut tower bar
- paranoid fender braces
monkiboy is offline   Reply With Quote
Old 04-20-2012, 10:28 PM   #2
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Builds looking sick!
wrxsubiemod is offline   Reply With Quote
Old 04-20-2012, 10:39 PM   #3
monkiboy
Member#: 202958
2008 wrx
thanks a ton, sir!
Old 04-20-2012, 10:49 PM   #4
Layvon
Member#: 195711
STi 04/05/06/07
Another EFR Build... At least you have your turbo...
PMing you a question right now. Looks like a fun one!
Layvon
Layvon is offline   Reply With Quote
Old 04-20-2012, 11:01 PM   #5
monkiboy
Member#: 202958
2008 wrx
Old 04-20-2012, 11:02 PM   #6
monkiboy
Member#: 202958
2008 wrx
Old 04-20-2012, 11:02 PM   #7
monkiboy
Member#: 202958
2008 wrx
Old 04-20-2012, 11:02 PM   #8
monkiboy
Member#: 202958
2008 wrx
Old 04-20-2012, 11:13 PM   #9
monkiboy
Member#: 202958
2008 wrx
Layvon
yeah, i waited about a year or so but put my bid in way early so was one of the first if not the first to receive their IWG 7064 - it was a great day, haha!
replied to your PM, thanks for the comments and questions.
Old 04-20-2012, 11:34 PM   #10
albersondh
Member#: 196882
08 WRX
Wow its come a long way. Looking great man. Ill stay tuned for pics of the finshed setup.
albersondh is offline   Reply With Quote
Old 04-21-2012, 10:34 AM   #11
erik11876
Member#: 275888
2011 WRX Limited
Absolutely sick, I followed your build thread on 3gwrx too, the JDM folding mirrors is a baller mod! Power and style, good job man.
erik11876 is offline   Reply With Quote
Old 04-23-2012, 11:39 PM   #12
monkiboy
Member#: 202958
2008 wrx
thanks a lot!
JDM power folding mirrors and the open/close action via key fob is honestly one of my most favorite mods. it's great! if you need a set imported, let me know!
Old 04-24-2012, 12:45 PM   #13
erik11876
Member#: 275888
2011 WRX Limited
Originally Posted by monkiboy
thanks a lot!
Curiosity has the better of me, how much did the set run with button installed on the switch panel?
Old 04-24-2012, 01:39 PM   #14
monkiboy
Member#: 202958
2008 wrx
i'll shoot you a PM here soon!
Old 04-24-2012, 09:27 PM   #15
Garrek11
Member#: 227747
2006 STI (BW S363)
SGM
Love the green.
Garrek11 is offline   Reply With Quote
Old 04-29-2012, 01:55 AM   #16
monkiboy
Member#: 202958
2008 wrx
Originally Posted by Garrek11 View Post
Love the green.
thanks! yeah i took a chance on it and it worked out great. wait til you see everything done under the engine bay!
Old 04-29-2012, 01:58 AM   #17
monkiboy
Member#: 202958
2008 wrx
JJ and Boris sent over some great pics of progress so far!
Old 04-29-2012, 01:58 AM   #18
monkiboy
Member#: 202958
2008 wrx
i'll keep the photos coming! thanks for all the PMs of interest and support - it's great having folks along for the ride!
Old 04-29-2012, 07:20 PM   #19
lieutenantcolumbo
Member#: 259016
2005 LGT Stg 3.5
GRP
Nice! I actually dropped my car off at IAG the week before for a full motor / heads build and your thread reassures me that my car is in good hands.
lieutenantcolumbo is offline   Reply With Quote
Old 04-29-2012, 07:26 PM   #20
brutnus
Member#: 257195
2004 WRX
2.1L
drool....
brutnus is offline   Reply With Quote
Old 04-29-2012, 09:26 PM   #21
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Love the colors and love the build. Keep the updates coming man. Good luck,
KG
Old 05-02-2012, 02:07 PM   #22
monkiboy
Member#: 202958
2008 wrx
fantastic selection - you are definitely in very capable hands!
Originally Posted by brutnus View Post
drool....
KG
thank you, sir. following your thread as well. i know you'll do the community right once you get yours! the wait is killer, i know but when you see that box on your front porch, man oh man, how exciting is that day!?
Old 05-02-2012, 02:09 PM   #23
monkiboy
Member#: 202958
2008 wrx
Old 05-02-2012, 09:02 PM   #24
Garrek11
Member#: 227747
2006 STI (BW S363)
SGM
Paint the IC piping black?
Old 05-02-2012, 09:49 PM   #25
monkiboy
Member#: 202958
2008 wrx
i got something a bit more creative in mind
they'll be going to my powdercoater with a few other suspension and drivetrain goodies for a proper job that will compliment the bay and the colors already in play!
The Foos's BW EFR 7064 build thefoos Custom Fabrication, Welding & Tools 158 02-26-2013 01:15 PM
EFR 7064/7670 and 8374 picture previews armyssoldierboy General Community 2 12-29-2010 10:38 AM
EFR 7064/7670 and 8374 picture previews armyssoldierboy News & Rumors 2 12-29-2010 09:08 AM
a new turbo option for rotated guys... Borg EFR Series. thirdlobe Built Motor Discussion 10 11-01-2010 11:47 PM
Borg Warner S256 Rotated Build UpSideDownDesi Proven Power Bragging 122 08-09-2009 01:32 AM
