Old 04-21-2012, 02:41 PM   #1
lokijibber
Member#: 196725
2005 Impreza OBSP
Default Need Outrigger Bushings... help please
Wife's 2005 Impreza Outback Sport
Driver side rear bushing is shot. Lots of play and a horrible rattle. I've been searcing all morning, and still don't know what I'm looking for. The DIY's I've found don't look like the bushings just go on top and bottom, but don't mention removing the old one... am I missing something? Do they get pressed out? I just dropped one side and I certainly can'y just get them out by hand.
I want to get urethane, and I need them soon. I have a bushing removal tool (cup, adapters and thrust bearing) made for the BMW, but it's borrowed and I need to return it next weekend. I'd like to get something shipped here this week so I can install them before I return the tool (especially if they need to be pressed out).
So:
How do I remove and replace these?
What bushings can I order so I know they fit and they can be overnighted or express shipped?
lokijibber is offline   Reply With Quote
Old 04-21-2012, 03:59 PM   #2
Big-E
Member#: 123843
2006 SGM WRX S2
Let LED's light your way!
If the OEM outrigger bushings are not deteriorated, then you can purchase the upper and lower urethane insert bushings that sit between the bushing and the body/plate.
Otherwise, if you want you can press out the bushings and install a sleeved urethane bushing.
Inserts by Kartboy: http://www.oakos.com/Merchant2/merch...gory_Code=1215
Sleeved bushing by Noltec: http://www.oakos.com/Merchant2/merch...gory_Code=1215
Contact the vendor directly about having either shipped to you.
Old 04-21-2012, 04:29 PM   #3
lokijibber
Member#: 196725
2005 Impreza OBSP
Perfect!! I'll be ordering the full bushings when I get home.
Thanks!
Old 04-21-2012, 07:55 PM   #4
lokijibber
Member#: 196725
2005 Impreza OBSP
Sorry to keep up with the questions, but are these bushings the same throughout the "Impreza" line?
The link above shows 02-07 WRX and STi, but doesn't mention our lowly Outback. Is there a good site for OEM part #s and diagrams that I could cross-reference? I know of a few for the other cars, but not one for Subarus.
Old 04-22-2012, 05:01 PM   #5
subi400
Member#: 216984
1996 Impreza outback
Green
Hey,
I would personally go with the bushings from Kartboy, the soft version which will still be firmer than stock
On a side note, they do not have to pressed out, just take the old ones out and replace with new. Make sure to tighten the bolts to the right specs.
subi400 is offline   Reply With Quote
Old 04-22-2012, 06:46 PM   #6
lokijibber
Member#: 196725
2005 Impreza OBSP
Thanks! I ordered the noltec bushings as wanted a full replacement. Should be here early this week!
Thanks for all your help everyone.....hopefully I don't need to put up any "help, I'm stuck posts" this week!
need a little help please blue-ej20 Factory 2.0L Turbo Powertrain 3 03-31-2002 04:35 AM
('93-'01) WRX owner in need of some helps....Please Dat Impreza Forum 7 06-21-2001 07:58 AM
Need some Linux help please. JGard New England Impreza Club Forum -- NESIC 8 06-11-2001 10:23 AM
Need Some Tire Help Please... (not what u think) Xscreamer Brakes, Steering & Suspension 4 04-18-2001 09:23 PM
I need a little help, please read! Boom New England Impreza Club Forum -- NESIC 3 05-30-2000 01:26 PM
Message Board Statistics All times are GMT -4. The time now is 01:05 PM.
