#1 |
Member#: 311480
AKIC
Vehicle:2002 WRX Blue |
On 23 Feb 2012 I bought my first Subaru. As soon as I bought it I started to go through the previous modifications and fixing it up. Here is the process.
For More Pics or to follow up with the project you can view them here : http://s46.photobucket.com/albums/f1...Impreza%20WRX/ Ground Zero (Day 1) ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#2 |
Member#: 311480
AKIC
And the Modifications Begin:
#3 |
Member#: 311480
AKIC
Just a rundown of what is all inside
As of 22 April 2012APS DR550 Front Mount Intercooler Blouch Performance 2.5 Dominator 'Polka' Turbo HID Retrofitted Headlights Deatschwerks WRX 650cc Fuel Injectors Custom Parallel Fuel Rails Turbosmart Fuel Pressure Regulator Walbro 255 LPH Fuel Pump APS 3" Turbo Inlet Pipe APS High Volume Twin Vent Blow Off Valve Tomei Expreme Unequal Length Exhaust Manifold COBB 3" Turboback Exhaust OpenSource Tuned GM Boost Control Solenoid Custom Ported and Deleted TGV’s COBB SF Intake (Perrin big MAF on its way) ACT Street Clutch Tein Front Strut Tower Brace Tein Rear Strut Tower Brace AEM EUGO Digital Wideband Gauge AEM Digital Boost Gauge Dual Gauge Bezel Mount HELLA Supertone Horn Set Optima Red Top Battery Last edited by DaBlueSquirrel; 05-15-2012 at 01:30 AM. |
#4 |
Member#: 68709
AKIC
Vehicle:2012 WRX red |
Very nice! How's the lag with that turbo?
#5 |
Member#: 299648
Vehicle:05 Sti Cgm |
Nice! almost running the same setup
#6 |
Member#: 311480
AKIC
The turbo itself isnt too bad, now the ridiculous size intercooler however plays a big role. LOL with the current tune ill have full boost by 4500 but I am working on that
![]() Thank you, how do you like your setup? |
#7 |
Member#: 299648
I like it but the boost does kick in later but pulls good to the end...A good tune will definitely make it run smooth
#8 |
Member#: 160040
AKIC
Vehicle:2002 Bugi / 1993 L Symmetry Tuning |
get 2.5s under those heads and you guys will be in good shape.......
#9 |
Member#: 311480
AKIC
Just a little update on a few new toys.
Mishimoto Aluminum Radiator ![]() Front mount Removed and a Large Top Mount was installed. To include a HKS SSQV BOV. ![]() |
#10 |
Member#: 276443
AKIC
Vehicle:2005 Wrexy OBP |
Whats full boost at now? rpm?
#11 |
Member#: 311480
AKIC
#12 |
Member#: 311480
AKIC
Received and installed my VIS Carbon fiber STI Scoop.
![]() ![]() ![]() ![]() Last edited by DaBlueSquirrel; 05-29-2012 at 12:02 AM. |
#13 |
Member#: 276443
AKIC
Ohhhh all carbon like and stuffs
#14 |
Member#: 156712
AKIC
Vehicle:1991 Legacy SS Pearl White |
Looks great. Let me know if you want to get rid of your stock scoop.
#15 |
Member#: 311480
AKIC
LOL replied to the other post. Ill bring it out this weekend if you want to take a look .
#16 |
Member#: 311480
AKIC
#17 |
Member#: 156712
AKIC
Sounds good... On both counts... or all three counts. lol
When this weekend? I'm not up to date with my meet-up schedule. |
#18 | |
Member#: 311480
AKIC
![]() I have no idea how I missed this post, Had a long day yesterday and diddnt make it out to the meet. You can call or text me if you want and we can arrange a time for you to see it. 334-470-1967 (Scott) |
#19 |
Member#: 156712
AKIC
^^ No worries man, I was pretty busy this weekend too. Maybe next weekend we could meet up at Riverview or something for a sec. I live right near there, so it would be ideal.
If you can PM me what you think you would want for it, that would be awesome. I'm going to repaint it and have it ready to put on Kelly's car, since the paint on her's has peeled pretty bad. |
#20 |
Member#: 311480
AKIC
PM Sent
#21 |
Member#: 311480
AKIC
New Wheels, I just need my suspension to come in so I can close up the Gap up front.
#22 |
Member#: 311480
AKIC
Alot has changed so I figured I would update list of whats all going on with it. As of 28 MAY 2012
Tuning: • Open Source Tuned (ECU Flash, RomRaider) Engine: • Blouch Dominator 1.5 XT-R Turbo • Turbo Blanket • 20 x 11.5 x 4.5 Bar & Plate Top Mount Intercooler • HKS Super Sequential Blow Off Valve • Custom Ported and Deleted TGV’s • NGK BK6EIX Plugs • AMSOIL 5w30 Full Synthetic Engine Oil Fuel System: • Deatschwerks WRX 650cc Fuel Injectors • Custom Parallel Fuel Rails • Turbosmart Fuel Pressure Regulator • Walbro 255 LPH Fuel Pump Cooling: • Mishimoto Aluminum Radiator • Samco Radiator Hoses Intake: • APS 3" Turbo Inlet Pipe • COBB SF Intake Exhaust: • Tomei Expreme Unequal Length Exhaust Manifold (Heat Wrapped) • COBB Tuning Stainless Steel 3" Turboback Exhaust Electronics: • GM 3 Port Boost Control Solenoid • AEM EUGO Digital Wideband Gauge • AEM Digital Boost Gauge • Relocated Optima Red Top Battery Drivetrain: • ACT Street Clutch • ACT StreetLite Flywheel • AMSOIL 75w90 Full Synthetic Gear Oil Interior: • Dual Gauge Bezel Mount Exterior: • HID Retrofitted Headlights • HELLA Supertone Horn Set • VIS Carbon Fiber STI Hood Scoop • Wingless DeBadged Trunk Suspension: • TEIN Front Strut Tower Brace • TEIN Rear Strut Tower Brace • TEIN S. Tech Springs (En Route) Wheels • Summer: 17x7 5 Zigen FN01R-C • 225/45/17 Sumitomo HTR Z II |
#23 |
Member#: 311480
AKIC
Tuning:
• Open Source Tuned (ECU Flash, RomRaider) Engine: • Blouch Dominator 2.5 XT-R Turbo (Polka Pickle) • Turbo Blanket • 20 x 11.5 x 4.5 Bar & Plate Top Mount Intercooler • HKS Super Sequential Blow Off Valve • Custom Ported and Deleted TGV’s • Gate’s Racing Timing Belt • NGK BK6EIX Plugs • AMSOIL 5w30 Full Synthetic Engine Oil Fuel System: • Deatschwerks WRX 650cc Fuel Injectors • Custom Parallel Fuel Rails • Turbosmart Fuel Pressure Regulator • Walbro 255 LPH Fuel Pump Cooling: • Mishimoto Aluminum Radiator • Samco Radiator Hoses Intake: • APS 3" Turbo Inlet Pipe • COBB SF Intake Exhaust: • Tomei Expreme Unequal Length Exhaust Manifold (Heat Wrapped) • COBB Tuning Stainless Steel 3" Turboback Exhaust Electronics: • GM 3 Port Boost Control Solenoid • AEM EUGO Digital Wideband Gauge • AEM Digital Boost Gauge • Relocated Optima Red Top Battery Drivetrain: • ACT Street Clutch • ACT StreetLite Flywheel • AMSOIL 75w90 Full Synthetic Gear Oil Interior: • Dual Gauge Bezel Mount Exterior: • HID Retrofitted Headlights • HELLA Supertone Horn Set • VIS Carbon Fiber STI Hood Scoop • Wingless DeBadged Trunk • CURT 1 ¼” Reciever Suspension: • TEIN Front Strut Tower Brace • TEIN Rear Strut Tower Brace • TEIN S. Tech Springs (With 06 Rear Tophats) Wheels • 18 x 8.5 Rota Grid’s (Bronze) • 225/40/18 Kuhmo Ectsa SPT”s ![]() ![]() ![]() ![]() ![]() Last edited by DaBlueSquirrel; 06-27-2012 at 12:11 AM. |
#24 |
Member#: 311480
AKIC
Took a little road trip with the wife, 320 Miles of Mud/Rock roads.
#25 |
Member#: 301431
AKIC
Vehicle:2010 Subaru WRX OBP Hatch |
looks pretty clean sir
| Thread Tools | |
| Display Modes | |
| U.S. running out of ADHD drugs ? SQUIRREL ! | Wagon Of Fury | Off-Topic | 36 | 01-03-2012 02:24 AM |
| I am a proud representative of the Solar Squirrel | incorporeal | Off-Topic | 10 | 09-15-2006 09:54 PM |
| The fruits of my labor, a day in the life of a chef | boosted84wagonmonster | Off-Topic | 31 | 08-27-2006 01:40 AM |
| The Story of Gimpy the Squirrel and his beloved WRX | Impreza01 | Off-Topic | 19 | 10-16-2004 10:05 AM |
| No, that chirpping is not the sound of a rabid squirrel trapped under the bonnet | PURE EPI | Mid Atlantic Impreza Club -- MAIC | 6 | 08-11-2001 07:22 PM |
