Old 11-07-2012, 06:23 PM   #51
BradX978
Member#: 334143
2008 WRX
Vin Diesel.
Originally Posted by bswilmington
I believe you are thinking of E85. Nitrous is self contained kit and doesn't go through your fuel tank or injectors.
I'm sure I am. I'm clueless on e85 and nitrous. And so the research begins
BradX978 is offline   Reply With Quote
Old 11-08-2012, 08:29 AM   #52
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
Nitrous is pressurized gas that is held in bottle and is basically another form of forced induction.
When spraying nitrous you have to add fuel with it whether that is dry (injectors spray the fuel) or wet (the nitrous system has additional injector). As with any forced induction timing is generally lowered when spraying nitrous and on boosted cars it is most times used to spool large turbo and shut off in high rpms. But it doesn't have to be, you can spray it up top also. It is usually sprayed for only short periods of time.
E85 is high octane fuel. When using it compared to gasoline you use approx 30% more. It allows car to run more boost and timing. Car run 100% off of it as it is your fuel source
Meth is fuel octane adder, basically like having race gas or E85 except when needed. You store it in separate tank and mix it with water, general ratios are 50/50 to 100% meth. System is generally toggled by hob switch (boost switch) or MAF controlled. System has its own pump (~120-250 psi). When spraying meth it allows you to run more timing and since it cools some run higher boost with it.
bswilmington is offline   Reply With Quote
Old 11-08-2012, 12:30 PM   #53
Rexxyou
Member#: 110816
USMC Semper Fi
GT35
Originally Posted by Skrane View Post
I want a nitrous intercooler spray kit. Any opinions on that?
Gimmick
Rexxyou is offline   Reply With Quote
Old 11-08-2012, 12:41 PM   #54
Rexxyou
Member#: 110816
USMC Semper Fi
GT35
Originally Posted by raggedoutsti View Post
Call me lame but I'd like the idea of having a good 30r sized turbo with the ability to have 35r power.
Nitrous is about two grand once you purchase a window/wot/fuel pressure/bottle warmer/automatic bottle opener etc
and expensive to refill, doesn't last long, and cant use it on the track for any type of sanctioned events.
a 30R doesn't need nitrous, maybe if you had a bigger turbo or a slower spooling turbo a wet 35 or 50 shot would help
also keep in mind, the more boost you run, the faster your turbo will spool. if you did meth, your turbo would spool faster also.
Whos running nitrous on their subies? v_dubs37 Water/Methanol Injection, Nitrous & Intercooler Cooling 34 06-27-2006 11:47 PM
What's the widest tire that i can use on my Subie? vicdeng Tire & Wheel 4 02-13-2006 07:49 PM
is there any laws in canada saying you can't use nitrous oxide on street cars? inpreza kid Canada Region Forum 19 01-19-2004 12:20 PM
Looking for Opinions on Diameters for nitrous use Mr. Rogers Normally Aspirated Powertrain 8 10-24-2002 10:07 AM
what jets sizes to use on my nitrous oxide wet kit STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-22-2002 09:29 AM
