Old 04-22-2012, 07:13 PM   #1
4Warned
Member#: 66092
2011 2011 STi sedan
11.665 @ 116.51
Default 2011 Sti, Stg.2, 93oct. pump gas 12.05 @ 112.14
Event: Quarter mile
Ambient Temp: 50 degrees
Elevation: 919'
Weather: Perfect. 43% humidity, 30.05 baro pressure, NE wind at 12mph
Track and Conditions: Asphalt, good prep, flat
Tires: Factory 245/40/18 Dunlop SP Sport 600
Car: 2011 Sti Sedan
Tuner: Junior via E-tune
Dyno Info: Virtual dyno 327hp/357tq
Transmission: Stock 6 speed with slipping clutch
Gear: 1st/2nd/3rd/4th
Peak HP at RPM: 327 @ 5116rpm non-SAE corrected (virtual dyno)
Peak Torque at RPM: 357 @ 4603rpm non-SAE corrected (virtual dyno)
Baseline stock 1/4mile: 13.356 @ 100.12 1.760 60'
Target Boost: 20psi
Target AFR: 10.8 - 11.0
Fuel: 93 octane unleaded from Amoco(BP)
Engine/Power Modifications: Cobb catted downpipe, Cobb SF intake, Grimmspeed 3-port ECBS, Nameless axleback muffler deletes, PTP turbo blanket, Saikou Michi dual oil catch can
Driveline Modifications: None, stock slipping clutch
Suspension Modifications: None
Other Modifications: Removed spare tire, jack, & subwoofer. Full interior.
Launch control @ 4600rpm
Flat foot shifting NOT USED
DCCD in AUTO
T/C OFF
Shift light @ 6100rpm
Car will go 11s once I replace the beat stock clutch
Passes were backed up in both lanes.
4Warned is offline   Reply With Quote
Old 04-22-2012, 07:22 PM   #2
Junior2JZ
Member#: 64908
10.8 XT+ Real stock
turbo record holder 11.4
Very nice work D!! Great driving as usual
I think the next round of mods should get us easily into the 11s on 93 and then see how far into the 11s we can go on e85.
It has been my pleasure to help you reach your goal!
Jr
Junior2JZ is offline   Reply With Quote
Old 04-22-2012, 07:28 PM   #3
4Warned
Member#: 66092
2011 2011 STi sedan
11.665 @ 116.51
Jr
We are not done yet, you know that.
I love that out of 5 passes made today these 4 were back to back looow 12's. Worst of the day being a 12.42 @ 111.30 lol
Old 04-23-2012, 08:45 AM   #4
achavez
Member#: 139320
2006 RA 1-4 5mt
wrx obp needs a e85 tune
Great launches and driving. Good job op and junior
achavez is offline   Reply With Quote
Old 04-23-2012, 08:48 AM   #5
patrick10
Member#: 234145
2012 SWP STi
Wow, very good driving and very good tuning!
patrick10 is offline   Reply With Quote
Old 04-23-2012, 09:14 AM   #6
CatfaceType-R
Member#: 81102
VERY impressive. Great job fellas, note the good 60 on stock suspension.
Time for more more mods e85 and a retune. If u want a hand let me know, look up hybrid boost control and ask jr about it, gain a couple hundred rpm spool. (install in series)
Buy a bov(like a tial) and compare logs to see if the stocker is leaking
A fmic would be killer
As u can tell I am in Michigan and am super hyped about your times and your tuning support, if I can help let me know. Let's bring the record to Michigan!
Carmi
CatfaceType-R is online now   Reply With Quote
Old 04-23-2012, 01:09 PM   #7
Junior2JZ
Member#: 64908
10.8 XT+ Real stock
Well I have the P&L goodies we spoke about and a set of id1ks whenever you are ready.
11s on pumpgas with a full weight STI, then we move to e85
Carmi
Carmi,
I totally agree with the low end pick up of the hybrid. On this car I am using the strategy that you and I both know works.. Just proved it again
I am staying away from the 10000000 TQ for 500rpm hit and maintaining a smooth boost level the whole way through. We are going to stick with that, this car "only" makes like 350wtq, but holds a flat solid curve, hence the great results.
Through my own RD I have come to the conclusion that a stock crushed BOV will be perfectly fine for the task as hand. We dont plan on running more then 21-22psi. Last week I was making over 500whp with a 2011 stock motor, TMIC stock BOV and 35r, looking through the logs it held 26-27psi, although I know judging by the WGDC that the bov was leaking past 24psi. So I think we will be fine for now with the OEM bov.
I think the bigger thing here is Darius's driving skills, I was laughing every time he text me a slip, all withing .02-3 of one another. He has the driver mod!
Old 04-23-2012, 01:13 PM   #8
b1aze
Member#: 284003
2010 Alpine 135i
would love to see an airboy giraffe for this :P
b1aze is offline   Reply With Quote
Old 04-23-2012, 01:17 PM   #9
subiefinest
Member#: 310715
2011 WRX
Satin White Pearl
nice! that thing is quick for DD
subiefinest is offline   Reply With Quote
Old 04-23-2012, 02:38 PM   #10
FCmaniac
Member#: 142029
2013 Fozz
2004 STi, 1991 Miata BRG
Wow, and on 93!! Great driving. Great tune. Congrats!!
FCmaniac is offline   Reply With Quote
Old 04-23-2012, 09:40 PM   #11
JoeTX
Member#: 83069
2007 STi 302/350
UGM Wingless
^^^What he said. You drove the crap outta that thing. Stage 2 on 93oct?! And very little weight reduction. Way to go.
What's the Stage 2 record?
JoeTX is offline   Reply With Quote
Old 04-23-2012, 09:48 PM   #12
jasv11
Member#: 117862
2006 STi 10.85@129.4
96 impreza 9.55e.t.146mph
Very Impressive!!
jasv11 is offline   Reply With Quote
Old 04-23-2012, 10:13 PM   #13
C J
Member#: 132587
2006 JrTuned STi
E85 GT3582r/10.83@126mph
Crazy on 93, nice!
C J is offline   Reply With Quote
Old 04-23-2012, 11:51 PM   #14
Junior2JZ
Member#: 64908
10.8 XT+ Real stock
I am pretty sure this car is the record holder for the GR platform. As for over all stg2, probably the record as well for 93.
I know I only managed a 12.2@108-109 on 93 with a straight stg2 sti swap in my XTi.
Old 04-24-2012, 12:58 AM   #15
RancerEvorution
Member#: 235190
2011 STi
i pulled of a 12.4 at 108 with my GR STi with a not so good 1.8 flat 60 foot. if i can cut a 1.6 ill be moving just as quick i think. just need more practice
RancerEvorution is offline   Reply With Quote
Old 04-24-2012, 01:08 AM   #16
STi Mikey
Member#: 114631
2007 11.5 @ 118
Stock Turbo Record Holder
Mo,
I told you your car was cable of bottom 12's when you got off the dyno bro, just have to get it there.
Congrats guys,
Always love seeing vf cars go fast
STi Mikey is offline   Reply With Quote
Old 04-24-2012, 12:23 PM   #17
GrimmSpeed
Member#: 136396
2012 wrx
white
Very nice results for a stock turbo! can't wait to see if you can hit 11's!
Mike
GrimmSpeed is offline   Reply With Quote
Old 04-24-2012, 01:18 PM   #18
BDP
Member#: 275256
Nice times. How does one go about getting an e tune from p&l? When I called they said they don't do them.
BDP is offline   Reply With Quote
Old 04-24-2012, 01:51 PM   #19
Junior2JZ
Member#: 64908
10.8 XT+ Real stock
Haha, yea in house we don't do them.
I will do them on my own though often. Just message Jrtuned@gmail.com
Old 04-24-2012, 01:58 PM   #20
wgr73
Member#: 232458
2008 STi (OBP)
CAMTuned
Wow, very nice!!! Great driving!! I'm impressed with the setup and what you did with it!!
wgr73 is offline   Reply With Quote
Old 04-25-2012, 12:21 PM   #21
Junior2JZ
Member#: 64908
10.8 XT+ Real stock
Wait til you see it on e85.
Its a typical 40-50whp gain once we switch to e85, with a much broader power band
Old 04-25-2012, 12:52 PM   #22
PerformanceAutoSolutions
Member#: 853
2011 STI Sedan
Satin White Pearl
damn...thats awesome guys..
PerformanceAutoSolutions is offline   Reply With Quote
Old 07-20-2012, 10:29 AM   #23
4Warned
Member#: 66092
2011 2011 STi sedan
11.665 @ 116.51
Clutch has since been replaced with a South Bend stage 2 "endurance" clutch
Bought a set of RPF-1 wheels which dropped 19.8 pounds of rolling weight. The car is now 3370# with me(170#) in it. Still with the full interior.
As soon as we get some good weather 11s will be happening
Old 07-20-2012, 10:38 AM   #24
FCmaniac
Member#: 142029
2013 Fozz
can't wait to see you run 11's on 93!!
Old 10-26-2012, 12:42 PM   #25
Plasmabluewrx
Member#: 318280
You need to go to test n tune tonight! This weather is awesome today. Looks like your about the same as my neighbor to the north! Go go go.
I also would be absolutely happy with that power and you've got! Flat as can be!
Plasmabluewrx is offline   Reply With Quote
604whp @ 24.5-25psi on straight 93oct pump gas bertune Proven Power Bragging 187 05-16-2013 06:08 PM
catted 2011 sti stg 2 ap smell funny truwrxtacy Factory 2.5L Turbo Powertrain 7 08-23-2011 06:18 PM
10.7 @ 125 • BUILTSTI's 05 STI • THESHOPCT • 93oct Pump Gas • Full Weight - 3400lbs BUILTSTI Proven Power Bragging 395 11-28-2010 06:13 PM
2.0 with small 16G pump gas 12.73@110 69subaru360 Proven Power Bragging 24 10-11-2008 12:02 PM
How much power is the stock STI turbo worth on Pump gas?? 93oct WRBLUEWAGON Factory 2.5L Turbo Powertrain 8 10-20-2003 10:07 AM
Message Board Statistics All times are GMT -4. The time now is 07:41 AM.
