Welcome to the North American Subaru Impreza Owners Club Wednesday January 28, 2015
Old 04-22-2012, 11:35 PM   #1
davis10
Member#: 70011
Default Learning view y-axis
Does anyone know where learning view pulls the y-axis scale from? I can't figure out why it goes upwards of 10k rpm. The only things I have changed in the map are the DBW, radiator fan modes, DTCs, and OL-CL delay tables. I'm guessing the DBW tables would be the culprit, but I can't figure out what is wrong with them.
Learning view:
DBW Tables:
davis10 is offline   Reply With Quote
Old 04-23-2012, 03:03 AM   #2
idipskoalmint
Member#: 169716
2005 WRX STi
WTF Tuned
On the '05 STI ROM:
Ignition Timing - Knock Control > Fine Correction Rows (RPM)
idipskoalmint is offline   Reply With Quote
Old 04-23-2012, 08:48 AM   #3
quazimoto
Member#: 70395
/\ What Matthew said. Same for 06 WRX.
quazimoto is offline   Reply With Quote
Old 04-23-2012, 12:16 PM   #4
davis10
Member#: 70011
Thanks, I forgot to mention that this is a 06 WRX. I'll have to check that, I guess my "stock" map must have gotten changed at some point
Old 04-23-2012, 06:12 PM   #5
idipskoalmint
Member#: 169716
2005 WRX STi
WTF Tuned
I didn't think about the fact that he posted the LV screenshot, which lists the make
Old 04-23-2012, 09:16 PM   #6
quazimoto
Member#: 70395
I caught it as I was closing the tab after looking at it. I almost missed it as well.
Old 04-25-2012, 12:12 AM   #7
davis10
Member#: 70011
Are those actually the stock ranges?!
Old 04-25-2012, 12:20 AM   #8
davis10
Member#: 70011
to answer my own question .. yes
Old 04-26-2012, 01:58 AM   #9
davis10
Member#: 70011
Anyone have any ideas why my cars are knocking so much??? This is a stock WRX motor swapped into a GC chassis. It has a RS hood scoop so the intercooler is probably not getting as much air. Also the intake ducting before the air filter is gone.
The first Learning View I posted was only from about a day of rallyX. This is what it looked like from the few months of driving before that:
(I need to change my air filter)
Old 04-26-2012, 11:27 AM   #10
quazimoto
Member#: 70395
What octane? Could be lots of things. Dirty injectors/fuel filter, dirty MAF, crappy gas, loose knock sensor.
Old 04-26-2012, 02:45 PM   #11
davis10
Member#: 70011
Gas is 91. I run injector cleaner pretty often, so I doubt it those. I'll check out the other stuff, thanks. I'm a little hesitant to try cleaning my MAF though.
learning view questions on learned afr's my02turboWRX Open Source Reflashes 7 08-31-2009 05:51 AM
Accuracy of learning view Kastley85891 Open Source Reflashes 6 04-17-2008 10:50 AM
Analyze my Learning View Output bcblues Open Source Reflashes 10 04-17-2008 09:16 AM
Romraider learning view table question...... BBBsti LTD Open Source Reflashes 19 04-09-2008 06:29 PM
Learning view - scan - FB if you could Kastley85891 Open Source Reflashes 16 03-24-2008 11:42 PM
