Old 04-23-2012, 11:22 AM   #1
jjasonn
Member#: 208653
2004 V-Limited
Spec C
Default KW Variant 3 Clunking
I just installed the KW Variant 3 and the rears, They clunk the hell outta me when they go pass any bumps. I have tried to find out exactly where did it came from but still I couldnt find it.
Does anybody have any idea where is that clunking coming from?
jjasonn is offline   Reply With Quote
Old 04-23-2012, 03:04 PM   #2
Feal Suspension
Member#: 227414
I would first suspect top mounts. Check for oil leaking where the chrome shaft sticks out of the shock. Sometimes KW's crack where they bolt to the upright, check for oil around the bottom of the shock.
Good luck.
Feal Suspension is offline   Reply With Quote
Old 04-23-2012, 03:30 PM   #3
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
are they new or used?
BlackFighter is offline   Reply With Quote
Old 04-23-2012, 03:38 PM   #4
jjasonn
Member#: 208653
2004 V-Limited
Spec C
Brand new. Never used at all.
Old 04-23-2012, 03:41 PM   #5
jjasonn
Member#: 208653
2004 V-Limited
Spec C
And there's no leaking or whatsoever. Checked everything already. Also I forgot to mention, the previous stock suspension too clunked but it wasn't as loud as this. As you people know, kw came without top mount and u had to reuse it. Does it have anything to do with it?
Old 04-23-2012, 03:43 PM   #6
stamlon
Member#: 303792
04 2.5RS
make sure the strut bolt on top is tightened all the way down
stamlon is offline   Reply With Quote
Old 04-23-2012, 03:47 PM   #7
jjasonn
Member#: 208653
2004 V-Limited
Spec C
They are tightened all the way down. I'm very sure of that.
Old 04-23-2012, 06:22 PM   #8
teiva-boy
Member#: 22825
If it clunked before, why would you blame the KW coilovers?
teiva-boy is offline   Reply With Quote
Old 04-23-2012, 08:40 PM   #9
jjasonn
Member#: 208653
2004 V-Limited
Spec C
Learn to read. the stock OEM shocks clunked thats why I spent over 2.5k to buy a KW because I got so ****in pissed at the sound.
Old 04-23-2012, 09:48 PM   #10
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
i think what he's getting at is that maybe it wasn't the shocks that clunked and something else in the suspension
gsrcrxsi is offline   Reply With Quote
Old 04-23-2012, 11:52 PM   #11
teiva-boy
Member#: 22825
I know how to read just fine.
Again, if it clunked before, what makes you think it's the coilovers?
Have you went over other pieces of your suspension? How do you know your installation didn't exacerbate the issue further?
You're obviously asking because you don't know.
I actually could suggest a few things right now, but I don't feel like it anymore.
Old 04-24-2012, 03:26 AM   #12
jjasonn
Member#: 208653
2004 V-Limited
Spec C
Then too bad you don't have to. Obviously I have checked everything possible. Bolts on sway bar everything but it's ok. I just wanted to ask but no worries. There's nothing unsolvable in this world with mr green bills.
Thanks for your time and don't bother to reply. I will pay a visit with the shop soon with mr green bills. Let's see if I need your "advise" or not again.
Old 04-24-2012, 08:47 AM   #13
growling_boxer
Member#: 165744
2000 LGT
2007 STi
Obviously
growling_boxer is offline   Reply With Quote
Old 04-24-2012, 09:09 AM   #14
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
How low are you? Is there enough preload on the springs?
Old 04-24-2012, 10:58 AM   #15
jjasonn
Member#: 208653
2004 V-Limited
Spec C
yes everything is set nicely. i didn't lower it alot. there's enough clearance, coilovers not rubbing.
Old 04-27-2012, 09:24 AM   #16
jjasonn
Member#: 208653
2004 V-Limited
Spec C
ok certified KW Variant 3 to be a complete bull****. im gonna throw this garbage away once i get a replacement coils.
apparently no matter what we do, the clunk is there. we even removed all of the sway bars to test it to see if thats the problem but hell no. the problem lies with the coilovers itself.
we tried so many top hats to test it.. cusco ones, oem sti ones, group n all of them were giving out this bull**** noise. i can say accurately that i have spent more time on this piece of garbage over other coilovers that i've owned before. even taiwan made coilovers didnt give me this kinda bull**** clunk. im done with this..
Old 04-27-2012, 10:27 AM   #17
hakira
Member#: 74211
SSM WRX 4DR
I bet its preload
hakira is offline   Reply With Quote
Old 04-27-2012, 10:34 AM   #18
jjasonn
Member#: 208653
2004 V-Limited
Spec C
Originally Posted by hakira View Post
I bet its preload
nope it's not the preload. i know the ride height you set it for affects preload. I have kw's recommended height range right now and nothing seems to work.
Old 04-27-2012, 12:30 PM   #19
littlewhitewagon
Member#: 103068
11 STI sedan
Where in Japan are you? I've had 4 sets of KWs now, never a clunk when installed properly. All of the top hats you tried were new? What nut are you using for the top? How are you tightening the nut for the top hat? I've used them with stock and CUSCO top hats, neither to make a clunk.
I get this feeling because you have an 04STI that your rear wheel bearings are worn...
littlewhitewagon is offline   Reply With Quote
Old 04-27-2012, 12:34 PM   #20
hakira
Member#: 74211
SSM WRX 4DR
Okay, just sayin because most people complain about coilovers clunking because they didn't preload correctly and/or they don't know how to properly preload that model
Old 04-27-2012, 12:42 PM   #21
jjasonn
Member#: 208653
2004 V-Limited
Spec C
I'm in Tokyo. The first top hat i used were used from my Arai suspension. Then I went to buy the cusco ones and the sound is still there, then i went to car do tachikawa and bought a oem sti top hat and a group n top hat brand new.
We used a strap wrench as recommended by Tom Edge from KW. tried 2 torque specs, which is 26lbs and 41lbs and nope nothing is working. Tried removing the sway bars , retorque the end links and nope nothing is working.
Also, the rear wheels bearing were done when I went for my last inspection. Changed all of the wheel bearings and it's not even 100miles. So I don't think its a problem with the bearings.
I have spent well over 8hrs per day x 3 day worth of labour with the parts purchased and it gets on me really alot to see that nothing is working..
Im sorry for venting but hope you people can understand that, after spending 2.4k on these coilovers and almost $800 on the brand new top hats and $75x8x3= 1.8k on labour for 3 days to figure out this problem. I don't really feel like continuing rectifying this problem no more especially after spending 5.8k on these coilovers alone..
Old 04-27-2012, 12:45 PM   #22
jjasonn
Member#: 208653
2004 V-Limited
Spec C
thanks for your advice anyway. this is not my first set of coilovers so most of the reasons for clunk has been went thru by me already.
Old 04-27-2012, 12:52 PM   #23
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Asks a question.
Gets answers/suggestions.
Attacks people providing answers/suggestions.
That's a great way to solve your problem
Psychoreo is offline   Reply With Quote
Old 04-27-2012, 12:54 PM   #24
jjasonn
Member#: 208653
2004 V-Limited
Spec C
Originally Posted by Psychoreo View Post
Asks a question.
tell me. how do i attack people proving answers and suggestions? most of the things they asked have been posted if they even bother to look around.
Old 04-27-2012, 12:56 PM   #25
mav1c
Hoodbridge!
Member#: 560
I've had 2 sets of KWs and never a clunking issue. Maybe you just got a bad set, or you have some other issue you haven't found yet.
Testing the waters: KW Variant 3 coilovers Flaps VIC Private Classifieds 4 08-19-2006 12:22 PM
Testing the waters: FS KW Variant 3 Coilovers Flaps Canada Region Private Classifieds 0 08-17-2006 02:56 PM
KW Variant 3 Coilovers purduephigam Brakes, Steering & Suspension 1 06-25-2006 02:03 AM
whiteline G4 or KW Variant 3 coilovers gooder77 Private 'Wanted' Classifieds 4 04-09-2006 11:33 AM
KW Variant 3 Coilovers Zahnster Brakes, Steering & Suspension 1 03-04-2003 06:47 PM
