Old 03-18-2013, 10:53 AM   #1
bugeyed2003
Member#: 321103
Default Broke bleeder screw brembos help!
Hey guys, i was doing my pads saturday night on my 05 sti and i went to bleed the front right caliper on the outside bleeder screw and it snapped clean off. I tried the extractor and heated it up and everything you think i could do to get it out without drilling it, i did. My question is, is it ok to drill and tap a new bleeder valve? If so has anyone done it or have advice?
bugeyed2003 is offline   Reply With Quote
Old 03-18-2013, 11:38 AM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
that's not the way to do it as you'll end up screwing up the mating surface inside.
you need to take it to a brake shop that can handle that.
Old 03-18-2013, 07:08 PM   #3
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
keep trying the extractor and get that piece out, and fyi you dont need to touch the bleeder when only changing pads
PARANOID56 is offline   Reply With Quote
Old 03-18-2013, 07:31 PM   #4
nhsilversti
Member#: 50895
. www.48hrs.info
donation chairman
last time i tried to drill or extract at broken bleeder i ended up with a new caliper. if it didnt loosen and just broke off, dont touch it. be sure to check that it's not seeping fluid, if not then you are good to go for now.
nhsilversti is offline   Reply With Quote
Old 03-20-2013, 08:08 AM   #5
bugeyed2003
Member#: 321103
Thanks for the advice guys! Im taking over to my local machine shop and see if they can get it out i dont want to mess anything up. Oh and i got them powder-coated so thats why they needed to be bled, i just put new pads on cause i had them laying around
