Welcome to the North American Subaru Impreza Owners Club Tuesday March 31, 2015
Old 04-23-2012, 02:00 PM   #1
aberg
Member#: 20184
2002 Impreza WRX
Default Gates AC Belt
Hello,
I recently replaced my AC and alternator belts (which were squealing badly) with Gates Racing belts. When I got the AC belt on it never seemed to get tight enough. I tightened it almost all the way at first, leaving a little bit of play, but that wasn't tight enough and it started slipping within a few days. I then tightened it all the way, the belt is still looser than I would like and is making some noise still.
Am I doing something wrong?!? Has anyone else seen this with the Gates belt, or is there another way to get it a little bit tighter?
Thanks for your help, I'd searched around first but it doesn't seem like this has been discussed before.
Andy
aberg is offline   Reply With Quote
Old 04-23-2012, 04:47 PM   #2
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
You got the wrong belt is the only answer unless your tensioner is busted.
Old 04-23-2012, 08:41 PM   #3
aberg
Member#: 20184
2002 Impreza WRX
Thanks for the response and input, Unabomber. Sorry I'd posted in the wrong area.
I'll have to look into what part I actually received, it is close enough that it seemed like it was gonna work ok at first - as far as you know the Gates belts usually fit ok? Tensioner seems fine...
Thanks again.
Old 04-24-2012, 05:46 PM   #4
wrxl98
Member#: 101244
2003 wrx sportwagon
silver cobb stage 2.5+
wrxl98 is offline   Reply With Quote
Old 04-24-2012, 07:20 PM   #5
aberg
Member#: 20184
2002 Impreza WRX
That's the belt that I ordered, slightly different part number but I think its the same thing (GAT040353RB not GATE-K040353RB), I don't know for sure that it's what I received...
I need to take a look at the belt to verify, will the part number be on the belt itself? Maybe I just need to order this one from Oakos and be done with it...
Thanks for the help!
Old 04-25-2012, 08:18 AM   #6
EdHilario
Member#: 137398
2004 Impreza 2.5RS
Platinum Silver Metallic
When I ordered my AC and PS belts from SGP, they were branded Gates if I recall correctly.
Fresh belts may need to be readjusted after some driving but after that it was pretty much set it and forget it.
Like Unabomber said, just make sure it's the correct length and check your tensioner. It shouldn't be slipping so often.
EdHilario is offline   Reply With Quote
STI timing belt, or gates timing belt? matt.nbg Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-03-2011 09:44 PM
wtb the two front belt ac belt and crank belt blackstidriver123 Private 'Wanted' Classifieds 2 12-12-2009 05:46 PM
Broke the ac belt tensioner, but ac belt is still tight. Am I safe? garface Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-12-2009 04:18 PM
AC Compressor+Bracket+Bolts+AC Belt Tensioner JeffrWRX Engine/Power/Exhaust 8 07-28-2008 08:32 PM
AC Compressor+Bracket+Bolts+AC Belt Tensioner JeffrWRX SCIC Private Classifieds 7 05-20-2008 01:05 AM
