South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 04-23-2012, 08:09 PM   #1
03.dub.r.x
Member#: 307997
1996 Impreza
Glacier White (230)
hey guys so took my gmc sierra for emissions and it failed they quoted 250 for repairs anyone can help me out wth the trouble codes are how to go about it
P0446 Evap Emission Control System Vent Control Circuit
P0452 Evap Emission Control System Pressure Sensor Low input
P0453 Evap Emission Control Syetem Pressure Sensor High Input
P1258 Engine coolant overtemperature above 268???F -protection mode active.
check engine light is on its a year 2000 v8 4.8 vortec can someone dumb this down for me and suggest what may be needed to have repaired?
if its minor i believe i can do it. how do i clear these codes?
thanks
03.dub.r.x is offline   Reply With Quote
Old 04-24-2012, 01:26 AM   #2
WRX357
Member#: 224249
2002 Subiworx built/
Soulless tuned Bugeye
Stop a few blocks short, unplug your battery, step in the brake a couple times, plug back in battery, drive to emission test place, take test, pass, go on with life.
WRX357 is offline   Reply With Quote
Old 04-24-2012, 01:32 AM   #3
Erik
Member#: 168774
No. That doesn't work.
Erik is offline   Reply With Quote
Old 04-24-2012, 01:45 AM   #4
yman
Member#: 199051
04 sti
psm
It would be good to invest in a scantool; you can plug it in, reset the codes, drive until the minimum amount of codes are "ready" and no CEL's are on, then drive to your nearest DMV and get it tested before the code comes on again. That's what I did with the Forester.
yman is offline   Reply With Quote
Old 04-24-2012, 01:47 AM   #5
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
You will fail.
Old 04-24-2012, 02:09 AM   #6
03.dub.r.x
Member#: 307997
1996 Impreza
Glacier White (230)
thats exactly what i did before hand but in the test it came back on.
would you happen to have a scantool u could help me with? or recomend one versus the usual ones from the vatozone
Originally Posted by kpluiten
You will fail.
Agreed wasnt even worth the wait. So i have my free retest so i want to do everything possible to gey this done.
Old 04-24-2012, 02:54 AM   #7
Erik
Member#: 168774
You already know the codes so there's not much point in the scan tool. Google those codes for that car, figure out what is broken, and then fix it. Drive the car for a while so you pass the readiness check and to make sure the CEL doesn't come back on; then go back to redo emissions.
Old 04-24-2012, 03:00 AM   #8
yman
Member#: 199051
04 sti
psm
This is the smartest plan. If it was a single code for like, the rear o2 it would be a much simpler thing but it sounds like you've got some maintenance items to take care of. The only reason I did the scantool thing was because I bought a vehicle from Cali and it needed to get registered ASAP since I was ridin' dirty with no 30 day tags.
BTW the autozone scantool that's like $250 should do the trick. I know its expensive but thats the one I'll be getting. I don't have one for you to use at this time though, still haven't gotten around to ordering it (gonna go through amazon). The main reason I would suggest getting it would be to check if your vehicle's ready or not, since you only get to go to the DMV a couple of times before you have to drive downtown and have them reset it in the system. I drove like 500 miles once and the codes still weren't ready, which is my reasoning for suggesting finding a friend with the tool.
Old 04-24-2012, 03:04 AM   #9
Infantry209
Member#: 266895
1988 Legs
White/CF/Titanium
I have a scanner if you need codes read or reset also.
Infantry209 is offline   Reply With Quote
Old 04-24-2012, 11:20 AM   #10
SpectoRex
Member#: 100590
2002 bugeye
red rock red
the 3 first codes seem to all be related, there is a vent valve on the car that may be plugged. if the car sat for a long period of time, these hoses going to the vent valve can get clogged with spider webs and dirt and cause issues with vent valve. Seen it many times on subaru's, and other vehicles.
For the temp code, check your t stat, if that is not working properly your fans will stay on, the car will not cool down, and the temp sensor will throw a code.
You can also google to see if there are any tsb's for your car that deal with these codes for some easy fixes.
Hope this helps
SpectoRex is offline   Reply With Quote
Old 04-24-2012, 12:26 PM   #11
03.dub.r.x
Member#: 307997
1996 Impreza
Glacier White (230)
Is there a certain timeframe your aware of to drive perhaps?
500?! holy crapola. but ouch going to hurt to purchase tool and do repairs. would the 250 to make it pass be a better option?
awesome man! can you let me know when you have some spare time?
Hope this helps
Does help!! So in reference to valve try to locate it and clear it out?
And there seem to be issues with the dash lights in general was like that when i purchased it. Seems like the gauges always flicker never really steady not sure if they are accurate or maybe electrical failure (did have alarm system and jacked up the electrical so took it out being that the truck was left on anti-theft protection mode and wouldnt start)
Old 04-24-2012, 12:46 PM   #12
SpectoRex
Member#: 100590
2002 bugeye
red rock red
your electrical issue sounds like a ground i problem. loose ground most likely. vent calve shoule be towards rear of car by cannister.
Old 04-24-2012, 01:45 PM   #13
03.dub.r.x
Member#: 307997
1996 Impreza
Glacier White (230)
its a truck. but ill check. grounds today flush coolant and top it off and do a tune up and see of that helps with anythn.
Old 04-24-2012, 02:20 PM   #14
yman
Member#: 199051
04 sti
psm
The scantool won't make it pass, it will just reset the codes and your car's monitors will show "not ready" when you go back to the DMV. A good scantool can tell you when the monitors are ready though, and there is either 1 or 2 monitors that are allowed to show up as "not ready". I knew the rear o2 was going to throw a code when it was ready, so I showed up to the DMV before it showed ready and it passed.
In your case though, since you've got 4 codes I would follow the advice from people in this thread who are trying to help you fix your vehicle, I just wanted to say if you have the extra cash a scantool is a good tool so you don't waste your trips to the dmv.
Old 04-24-2012, 02:43 PM   #15
03.dub.r.x
Member#: 307997
1996 Impreza
Glacier White (230)
yeah your right and thanks to everyone flr quick responses. after work will flush the coolant make sure i top it off with a 50/50 mixture due anyway for a tune up and check all my grounds to be sure nothin is loose and go from there ill update once i get home again thanks guys
Old 04-24-2012, 03:05 PM   #16
fige
Member#: 312924
ENGINE Temp sender & Thermostat
fige is offline   Reply With Quote
Old 04-24-2012, 07:35 PM   #17
03.dub.r.x
Member#: 307997
1996 Impreza
Glacier White (230)
happen to know location?
Old 04-24-2012, 09:13 PM   #18
03.dub.r.x
Member#: 307997
1996 Impreza
Glacier White (230)
thermostat done
coolant flush done
still on >={
Old 04-24-2012, 09:16 PM   #19
03.dub.r.x
Member#: 307997
1996 Impreza
Glacier White (230)
also engine temp sender? uhm where is it?!
Old 04-24-2012, 09:30 PM   #20
03.dub.r.x
Member#: 307997
1996 Impreza
Glacier White (230)
quick note serpantine belt did come off recently (pulley broke couple weeks back) and did overheat.
just did a tune up as well to me feels lik its runnin like shet not really sure how to take off the CEL which i think is the first code. your thoughts?
Old 04-25-2012, 09:22 PM   #21
03.dub.r.x
Member#: 307997
1996 Impreza
Glacier White (230)
thanks everyone again. got fed up and went to pay 150 else where and was fuel temp sender i believe but is fixed now and passed with flying colors
Emissions FAIL purduephigam Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 03-10-2011 01:14 PM
Front o2 sensor tool in MA? Emissions FAIL! segerton New England Impreza Club Forum -- NESIC 10 03-15-2010 05:59 PM
emissions fail ct alphagoose New England Impreza Club Forum -- NESIC 11 05-12-2009 11:22 AM
Emissions failed O Stylee Off-Topic 12 06-05-2006 12:58 AM
Girlfriend's car failed inspection for NOx emissions LUME Tri-State Area Forum 5 05-26-2001 09:56 AM
