Old 04-23-2012, 10:24 PM   #1
tenchu
Member#: 64147
1993 STi RA V LTD
Green
Default HELP! JDM wiring guru's
I am currently attempting to swap over my wiring bulkhead. It appears (with some conversation and picture swapping with Supermoose) that I have gotten a SUPER old (~1992) bulkhead harness. And while MOST of the plugs I need are here, some are not. Keep in mind this harness is about 75% installed, and the old harness is only good for parts.
Heres where I realized the differences:
Old bulkhead had 3 main grey plugs that connected to engine harness. One coming through firewall to back of engine. 2 coming through fender under engine fuse box to side of engine.
New bulkhead has only the 2 wires coming from under engine fuse box.
Where the old bulkhead harness came through the firewall with 3rd main grey engine harness plug, it also had this 6 pin transmission plug:
(dark grey is transmission connector, light grey is 3rd engine plug (OLD BULKHEAD))
That connected to top of transmission here:
New bulkhead does not have EITHER of these plugs.
Does anyone have any ideas? Suggestions? Wiring diagrams? Anything that would help? I'm sure there are more differences that I haven't noticed yet. I haven't even gotten the motor in the car yet. I'm thinking I am going to have to cut that transmission/engine plug off the old bulkhead and splice to new bulkhead, but I would like a diagram to know where these wires run.
tenchu is offline   Reply With Quote
Old 04-24-2012, 01:30 AM   #2
tenchu
Member#: 64147
1993 STi RA V LTD
Green
Update, after further inspection, this is what appears to be my new bulkheads version of the above 2 connectors. Instead of a 6 wire trans plug, it has a 4. Instead of a 8 wire (in 12 slot connector) plug for engine, it has (2) 3 wire connectors and (1) 1 wire connector. This:
Here is the only diagram I could find, though it appears this is for an even NEWER GC, as this diagram shows a VSS, whereas mine is cable.
So, for "B92" (trans plug) on OLD bulkhead I had the following wires (tab facing up, looking into side of connector that wires enter):
Black/Yellow || Light Green/Yellow || Red White
Brown/Yellow |....| Black/Red |....| Green/Black
And on the new bulkhead (same orientation):
Brown/Yellow | Black/Red
And for the engine plug "B93", old bulkhead same orientation:
open || Red (with silver dots?) | Cream | open
cream | ......... Green ........... | Black | open
Grey ..| . . . . . .Grey . . . . . . .| Grey | open
And new connectors:
Dark Grey connector:
Grey | Black | Cream
Light Grey connector:
White | Cream | Black
Single wire connector:
Cream or possibly white (hard to tell)
Possibly this could help someone help me? I have no clue, but I am trying to put forth as much effort as possible to make it as easy as possible for someone to lead me in the right direction.
Old 04-24-2012, 03:16 AM   #3
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
its probably because your car is an RA so it has DCCD and so the wiring to the transmission is different. the harness you got is either not an RA/DCCD or it is, but its a completely different iteration and they changed the wiring.
ive seen a lot of harnesses and ive never seen those flat 3-wire connectors before (in your last picture)
elislider is offline   Reply With Quote
Old 04-24-2012, 09:50 AM   #4
suberdave
Member#: 101865
88 GL-10 STi
the last picture is your Cam Crank and Knock sensor. (like what is found on some EJ22ts) i did a 93 RA and it had the same connectors. all other EJ20Gs i have done have had them all togther in one plug.
-=Suberdave=-
www.suberdave.com
suberdave is offline   Reply With Quote
Old 04-24-2012, 10:19 AM   #5
tenchu
Member#: 64147
1993 STi RA V LTD
Green
-=Suberdave=-
www.suberdave.com
So the (2) 3 pin connectors and (1) 1 pin connector for cam/crank sensors instead of the (1) 8 wire / 12 pin connector?
I can swap engine harnesses and cam/crank sensors on the engine to the newer style. But my question is how to go about getting the 8wire/12pin engine plug and 6wire trans plug in place of the current 4 connectors
Old 04-26-2012, 07:58 PM   #6
elislider
Member#: 133923
03 Legacy GT wagon
the single pin is probably for the temp probe in the coolant crossover pipe. or its for the oil pressure sender?
ATTN: Wiring guru's!! Help diagnose window/door lock issue D Money Car Audio, Video & Security 9 05-28-2011 02:47 AM
Wiring Guru's NEEDED! powerneedy Subaru Conversions 4 10-12-2008 03:46 PM
All you wiring guru's merge! fx35 wiring dillema skingfreak Electrical & Lighting 15 06-27-2008 10:04 AM
Wiring Guru's.. Well, maybe not even Guru's. FederalAuditor Subaru Conversions 2 01-04-2005 06:55 PM
Help my wire my JDM wiper, plz! (xpost) boneriffic Electrical & Lighting 5 10-08-2004 03:05 PM
