Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 04-24-2012, 09:54 AM   #1
ehiddenidentity01
Member#: 279169
2004 impreza wrx sti
wrb
Default scaling a maf for blow through setup
so i have an 05 sti im working on. thinking about re locating the maf to the bend right before the throttle body so the bov venting to atmosphere wont effect the reading.
i have rescaled for different intakes and filters and things like that but never moved one to the pressure side. how does the psi effect the readings or does it?
i have heard that doing this will kill your driveability but i feel like if you spend enough time on it u can get it to work smoothly. does anyone have any experience with this and or any advice before i approach this?
i would appreciate not seeing"take it to a professional" or "if you have to ask this you shouldnt be doing it"
mods:
aps fmic
dw 850 injectors
k&n short ram intake n filter
street light fly wheel
south bend stage three clutch
walbro 255 fuel pump
tial bov
and custom 4in tbe
ehiddenidentity01 is offline   Reply With Quote
Old 04-24-2012, 10:02 AM   #2
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
The stock MAF is not a "blow through" design. You would be better off with a recirculating system, or speed density.
Black94Snake is offline   Reply With Quote
Old 04-24-2012, 11:04 AM   #3
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
http://forums.nasioc.com/forums/show....php?t=2196695
Doesn't answer your question, but a lot of good info.
Jubert69 is offline   Reply With Quote
Old 04-24-2012, 12:11 PM   #4
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
If you can rescale for a bigmaf or different size intake you should be good to go. Its not hard at all. Things you should know.. you want the maf sensor at the end of a nice straight piece so the air doesnt swirl much. Second thing is that you will have no idea if you have a boost leak anywhere before it so you have to be aware of how fast it is when you know there are no leaks. I have done it on just about every car that comes through my shop with minimal issues.
Issues include leaky turbo spraying mist of oil... blow by that mists... but thats it.. if you clean the maf once a month with maf cleaner you will be golden. Good luck and PM me if you have any questions!
Bamofo is offline   Reply With Quote
Old 04-25-2012, 08:44 AM   #5
ehiddenidentity01
Member#: 279169
wrb
can you do speed density on the stock ecu?
Old 04-25-2012, 09:06 AM   #6
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
I wouldn't have said it, if it couldn't be done.
Maf location for blow through kaane Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 10-06-2010 12:41 PM
FS: 3" Blow Through Setup for SSAC FMIC STIBungy Engine/Power/Exhaust 6 05-11-2008 03:59 AM
Wont start after blow through setup TurboDXsti Built Motor Discussion 8 07-01-2007 11:10 PM
My STI: GT30R Blow Through Setup STIBungy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 27 04-02-2007 04:12 PM
The TXS blow through setup... almost 2phless UTEC 7 08-12-2006 10:16 AM
