Old 04-24-2012, 10:07 AM   #1
Wicked Performance
Member#: 265606
Default Wicked Innovation Blouch 20GXTR 398/431
Facility: Dynotech Tuning
Tuner: Wicked M@ / Wicked Innovation
Type of Dyno: Mustang AWD-500
Baseline # for a stocker at the dyno: 215-225/240-250
Boost: ~28 Psi tapering to 26
Fuel: 93 octane
Gear: 4th
Target AFR: 11.2:1
SAE Corrections: .960
Peak HP at RPM: 398 (382) @ 5720
Peak Torque at RPM: 431 (414) @ 4600
Relevant Power Mods:
Stock EJ257 w CP Drop ins
Perrin FMIC
KSTech Big MAF Intake
DW 850cc Injectors
Wicked Parallel Fuel System
Perrin EL Header
Invidia TBE
Blouch 20GXTR 10cm 3" Inlet
Apologies for the lame graph with no boost plot, I will update this when I get back on the dyno.
Wicked M@
Wicked Performance is offline   Reply With Quote
Old 04-24-2012, 10:43 AM   #2
AuthenticAMD
Member#: 212239
2008 Legacy Spec B
QSM (stage 3.5)
That is crazy power!. It's like E85 power on 93. Is it generally safe to run 28 psi on pump?
AuthenticAMD is offline   Reply With Quote
Old 04-24-2012, 10:47 AM   #3
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
I'm starting to think you've got a faulty boost collection device; you consistently run a TON of pressure on 93.
Great power though!
Zee Biker is offline   Reply With Quote
Old 04-24-2012, 11:00 AM   #4
Wicked Performance
Member#: 265606
I come from a different school of tuning. Boost makes torque. I do my AVCS and timing different from most that Ive seen.
The cars I post in here are also very well setup. I tune many that make less power that are deficient in one way or another mechanically. Any deficiency will kill power.
I mostly post these for the sake of the owners to get them some exposure for doing there cars correctly. They are the ones that committed the time and money.
Wicked M@
Old 04-24-2012, 11:18 AM   #5
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Looks great! I'm glad I'm not the only one running the 20G XTR with the much boost
xluben is offline   Reply With Quote
Old 04-24-2012, 11:50 AM   #6
kakarot09
Member#: 182375
08 Sti
Wrbm
What were egt's like on this?
kakarot09 is offline   Reply With Quote
Old 04-24-2012, 12:09 PM   #7
Wicked Performance
Member#: 265606
This particular car does not have an EGT gauge yet, but generally with similar setups I see mid 1500s on the dyno and upwards have about 1600 on sustained highway pulls. I believe this to be safe.
Old 04-24-2012, 12:37 PM   #8
kakarot09
Member#: 182375
08 Sti
Wrbm
Where are you measuing egt's? In the up pipe or a header primary? How far are you personally comfortable with pushing it? Assuming you don't mind sharing anyway. If you do mind no big deal
Old 04-24-2012, 02:59 PM   #9
Android287
Member#: 180861
2005 cammed Hybrid
2.5xtr E85
does this car have the stock inlet and tgv still?
Android287 is offline   Reply With Quote
Old 04-24-2012, 03:34 PM   #10
AuthenticAMD
Member#: 212239
2008 Legacy Spec B
QSM (stage 3.5)
3" Inlet means it's no longer stock.
Old 04-24-2012, 03:44 PM   #11
Wicked Performance
Member#: 265606
Perrin 3" Inlet and Wicked TGV Delete.
Normally we install In a primary. On the dyno I dont like to see more than 1600 or so. On the street im ok with anything up to 1700 on a sustained pull in high gear but really less is better.
Ill share pretty much anything, no secrets or mysteries lol.
Wicked M@
Old 04-24-2012, 04:15 PM   #12
Ongbak
Member#: 253376
2005 Lgt
wow...nice power! I'm leaning towards this turbo
Ongbak is offline   Reply With Quote
Old 04-24-2012, 04:59 PM   #13
Wicked Performance
Member#: 265606
This is the highest power 20G car Ive ever tuned. normally they make less than this.
Old 04-24-2012, 06:44 PM   #14
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
Wicked M@
Wicked M@
Care to share any info how you are different at tuning timing and avcs? This amount of power makes me curious as to what you do different.
bswilmington is offline   Reply With Quote
Old 04-24-2012, 07:58 PM   #15
Wicked Performance
Member#: 265606
Ive got some PMs on this.
First I want to express again, that these cars are some of the best to come through here. They have healthy motors, done right, with proper AOS, fuel distribution, etc.
Most Subaru pump fuel tuners seem to get the fuel to 11:1, raise the boost up to some level they like, and then go nuts with the timing until it knocks and back it off.
I get the fuel sorted, adjust the AVCS for spool, resort the fuel. Then I increase the boost till I get the torque curve where I want it without knock, I try to get as much boost in it as possible. I then work on the timing and AVCS in tandem to keep the car out of knock and sort out how I can make the most power. You can use the cam timing to help you.
Since most people use some sort of preconceived avcs map, dont touch it, or use something off the internet they might not get the torque I get sometimes.
I did not start tuning with subarus, and I didnt really look into what other people did. I do it my way based on experimentation and good results.
I believe if I used some sort of E85, C16, or other limitless fuel that I wouldnt be able to do much better than anyone else in terms of maximum power.
M@
Old 04-24-2012, 09:11 PM   #16
raggedoutsti
Member#: 255714
2005 STi
psm
These number look more realistic for a 20g, well still pretty high don't get me wrong, but I've seen some other pretty high numbers lately on these Blouch 20g's. I bet this is 122-124 trap if not faster.
Keep up the great work!
raggedoutsti is offline   Reply With Quote
Old 04-24-2012, 09:17 PM   #17
Franko
Member#: 193628
2010 STI
SSM
Please take a screenshot of the avcs tables! OHH GOD PLEASE! What do you want?! Money? My blood?! Take my blood!!! just show the AVCS tables.. PLEASE!
Franko is offline   Reply With Quote
Old 04-24-2012, 10:09 PM   #18
bswilmington
Member#: 217563
M@
Thanks for sharing this info. Glad you went to the effort of it. Alot better than some on nasioc but not all, some tuners will give out info, some not.
I love this guys post but what are the odds that you will share it
Old 04-25-2012, 11:21 AM   #19
Wicked Performance
Member#: 265606
The AVCS tables for this specific car wouldnt help anyone. Especially not anyone with a '10 STi.
I have no problem giving my ideas out, or things I have learned. Just not specifics because they are not universally applicable.
Im willing to say that I dont subscribe the the 0 avcs by full spool rule. Thats enough to go on that anhyone that can do testing with their setup should be able to figure out. Its all about adjust and test, and trying different combos of avcs, timing, and boost.
Old 04-25-2012, 01:58 PM   #20
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Who runs 0 advance at full spool
There's no magic in making this kind of power on 93 Octane... just run lots of boost like you are
Looks like a good aggressive tune to me. I wish we could push turbos this hard on our 91 and be comfortable with it.
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 04-25-2012, 02:45 PM   #21
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
-- Ed
I agree 24 PSI is pushing it right now on 91, **** if I could run 28 psi on pump.
Cory
renosubby is offline   Reply With Quote
Old 04-25-2012, 03:10 PM   #22
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
I could see it on 93.... that stuff is almost race gas when you're used to our 91
-- Ed
Old 04-25-2012, 04:54 PM   #23
Wicked Performance
Member#: 265606
Ed, Ive heard all sorts of wacky theories out here. And yes 93e10 is much better than the fuel elsewhere in the country. We are also at 0 elevation.
M@
Old 04-25-2012, 09:22 PM   #24
Franko
Member#: 193628
2010 STI
SSM
If your not running 0 advance by full spool then what kind of numbers do you run?
I have no awd dyno within 2000km so I have to tune by seat of my pants and it isnt easy to tune something as subtle as cam timing this way. Ive tried the Airflow/VE method and I just cant get consistent readings.
I am more or less looking for tables to compare to what I have come up with on my own. The car pulls very very strong but I just always think there is more to be unlocked via the avcs. Give me some insight please. Id love to see avcs tables that were dialed in using a real dyno.
Old 04-25-2012, 10:11 PM   #25
BlackEyeII
Member#: 65140
2007 STI Limited#213
05 STI (rip) 03 WRX (rip)
What do you think of the 10cm housing? Do you think it made a big difference on hp over the 8cm?
BlackEyeII is offline   Reply With Quote
Wicked Innovation DOM3XTR 416/426 Wicked Performance Proven Power Bragging 4 04-24-2012 03:48 PM
FS : NJ: Blouch 20GXTR, Spearco, GS uppipe/header/44mm MVR GoodKnight Engine/Power/Exhaust 8 10-25-2011 11:16 AM
Anyone going to the Wicked Innovation meet on Sunday? DJTWRX New England Impreza Club Forum -- NESIC 30 09-22-2009 11:50 PM
