Old 04-24-2012, 11:15 AM   #1
AsphaltsCry
Member#: 65296
1998 low turbo SF
red / black
Default What spark plugs?
Originally 95 ra swap. Been running pfr6g's, but never changed them when I replaced block with ej257. And later new style coils.
Are these still correct or do I use the longer sti plugs. Forged pistons too, but should match originals. Hmm
Also heads are ej25d
AsphaltsCry is offline   Reply With Quote
Old 04-24-2012, 11:42 AM   #2
suberdave
Member#: 101865
88 GL-10 STi
use the correct plugs for the heads. if you are still using the RA heads, than use the pfr6g's if you want to go one step colder go with the pfr7g's (NGK stock #4644)
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 04-24-2012, 01:34 PM   #3
AsphaltsCry
Member#: 65296
1998 low turbo SF
red / black
Makes sense, match plugs with heads.
however the ej25d heads I am using have smaller combustion chambers due to the ej257 pistons not coming above the deck as in ej20g.
if this it's true then it would seem like another plug would be appropriate. Hmm
Thanks for your thoughts
Old 04-28-2012, 08:17 PM   #4
AsphaltsCry
Member#: 65296
1998 low turbo SF
red / black
Bumpasaurus
Old 04-29-2012, 01:35 AM   #5
suberdave
Member#: 101865
88 GL-10 STi
I dont see why you bumped this. do you still have a question?
if you use the EJ257 plugs they will go right through the top of you piston... they are to long.
use the plugs i posted if you are using any EJ20G EJ20K EJ20H EJ20R EJ25D EJ22T EJ22G EJ205 EJ207 heads.
-=Suberdave=-
What spark plugs, and what gap? kaos200 Factory 2.5L Turbo Powertrain 8 07-07-2004 09:55 PM
What spark plug do you recommend for 2000 RS? Longitude Service & Maintenance 4 04-23-2002 10:04 PM
What spark plugs should I get 2.5rsMI Normally Aspirated Powertrain 19 07-08-2001 10:45 AM
What spark plugs wires do you guys have?? 2.5rsMI General Forum Archive 5 04-01-2001 11:43 AM
What spark plugs does the MY99 RS use, and when should they be changed dandbest Technical Forum Archive 3 08-18-2000 05:59 AM
Message Board Statistics All times are GMT -4. The time now is 08:22 PM.
