Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Complete Car Part-Out
Old 04-24-2012, 12:59 PM   #1
Blue Meanie
Member Sales Rating: (16)
Member#: 141648
2002 WRX Wagon
Thumbs up '04 WRB WRX Part Out
Parting out an '04 WRB WRX. She was put into a ditch so the passenger side fender, doors, rear quarter and roof line are dented. <77K Miles, on her, interior is good (dusty) and engine was basically complete minus TMIC and intake.
Everything for sale, or sold, is listed in the following four posts! Updates will be made within 24 hours of changes. Please do not ask if it is sold before reading below. If you don't see it listed at all then please feel free to ask about it.
I would like to trade someone parts for their Borla Hush Axle-Back so let me know what you want / need.
EMAIL IS MUCH PREFERRED OVER THESE TINY PRIVATE MESSAGE BOXES!
(and will get quicker responses)
geoffrey_geist (at) yahoo (dot) com
Much, much, much more to come!
Thanks for looking!
-Geoff
Fine Print: What you see is what you get. Most prices are OBO so make a reasonable offer and let's talk. Trades may also be accepted depending on what you've got and what I need. All Sales Are Final. Local pick up is preferred but shipping is available at your expense (I'm not trying to make money on shipping so rates quoted will be my cost). PayPal is preferred unless local but again, the fees will be at your expense (figure +8% of total cost + shipping). If you are ready to buy please email/PM zip for shipping quotes and your verified PayPal email address for an invoice once agreed.
Blue Meanie is offline   Reply With Quote
Old 04-24-2012, 01:00 PM   #2
Blue Meanie
Member#: 141648
2002 WRX Wagon
Engine / Parts
Intake Manifold - $100
Throttle Body - $80
Top Feed Fuel Rails - $50
Alternator - $65
Radiator Fans (2) - $100
Starter - $45
Engine Mounts - $35
Exhaust Manifold (OEM Header) - $50
Stock Up-Pipe - $30
Coil Packs (x2) - $25 each
Cam Gears / Pulleys (set) - $100
Coolant Lines - $25
Coolant Cross Over - $25
Accessory Brackets - $25
Water Pump - $40
Clutch Slave - $20
Master Cylinder - $30
Brake Master & Booster - $75
MORE! All kinds of lines, brackets and harnesses...
SOLD Radiator - $100
SOLD A/C Condenser - $100
SOLD A/C Aluminum High Pressure Line - $50
SOLD A/C Aluminum Low Pressure Line - $50
SOLD SR*S Cat-Back $150
SOLD Windshield Washer Tank & Pump - $25
SOLD Power Steering Reservoir - $20
SOLD Fuel Controller - $20
SOLD Dash Harness - $200
SOLD Coolant Surge Tank & Cap - $40
SOLD Crank Sensor - $25
SOLD Knock Sensor - $40
SOLD Turbo Brackets - $20
SOLD Spyder Auto Catless Down Pipe - $85
SOLD Top Feed Fuel Injectors "Blue" (440cc) - $110
SOLD Rear O2 Sensor - $40
SOLD A/C Compressor - $150
SOLD TGVs - $50
SOLD Cam Sensor - $40
SOLD Front O2 Sensor - $40
SOLD Power Steering Pump - $95
SOLD Turbo Inlet - $25
SOLD TD04 Turbo - $200
SOLD Block (Crank, Rods, Pistons ETC) & Heads - $1500
Pictures:
Throttle Body - $80
Radiator Fans - $100
Old 04-24-2012, 01:00 PM   #3
Blue Meanie
Member#: 141648
2002 WRX Wagon
Drive Train / Suspension Parts
Transmission - Mine!
Struts with STi Springs (All 4, includes tophats ETC) - $300
Front OEM Springs (2) - $50
Exedy Stage I Clutch - $200
Rear Axles (both) - $100
Drive Shaft - $125
Rear Differential (snapped some bolts trying to remove) - $50
Brake Calipers (all 4) - $100
Hubs Rear (set) - $150
Hubs Front (set) - $150
Control Arm Front (Left) - $50
More...
SOLD Rack & Pinion w/ Lines - $100
SOLD Control Arm Front (Right) - $50
SOLD Front Sway Bar - $50
SOLD Rear Sway Bar - $50
SOLD Front Axles (both) - $100
SOLD Transverse Links - $30
SOLD Front & Rear Speed Sensor - $50
Pictures:
Old 04-24-2012, 01:00 PM   #4
Blue Meanie
Member#: 141648
2002 WRX Wagon
Body / Exterior Parts
Fender Liners - Gone
Front Bumper - $75
Rear Bumper - $75
Carbon Fiber Hood & Scoop w/ Hood Pins (Needs new clear coat) - $300
Head Lights (HID) Plug & Play! - $400
Grille - $50
Driver Rear Door - $100
Door Windows - $40 each
SOLD Driver Front Door - $100
SOLD Driver's Door Window - $40
SOLD Tail Lights - $200
SOLD Front Driver Fender - $100
SOLD Trunk - FREE
SOLD Side Skirts - $100
SOLD BBS Wheels 5x100 (rubber's shot) - $800
SOLD WRB STi Spoiler / Wing - $200
Pictures:
Front Bumper - $75
Rear Bumper - $75
Old 04-24-2012, 01:00 PM   #5
Blue Meanie
Member#: 141648
2002 WRX Wagon
Interior / Parts
All Black Door Cards (set) - $175
Head Liner - $50
Complete Dash (Includes Airbag) - $150
Center Console - $80
Steering Wheel (Includes Airbag) - $100
Clock Pod w/ Clock - $30
Boost Gauge (PSI) - $25
Boost Gauge (BAR) - $20
Spare Tire (Donut) - $30
Rear Deck - $30
Third Brake Light - $20
"B" Pillar Moldings (pair) - $25
"C" Pillar Moldings (pair) - $25
Front Seat Belts (set) - $60
Rear Seat belts (set) - $60
Emergency Brake Assembly - $25
Alarm Module - $20
Airbag Module - $40
Rear Seat Backing, Bar, Child Safety Seat Bars (set) - $20
Keyless Entry Unit - $20
SRS Aibag Module - $45
Cruise Control Unit - $40
More...
SOLD OEM Door Tweeters $10
SOLD OEM Jack & Crank - $20
SOLD Radio/HVAC Bezel - $20
SOLD Greddy Turbo Timer - $60
SOLD Clock Spring - $30
SOLD Front Seats (Black) - $400
SOLD Window/Door Moldings (any) - $10 ea.
SOLD HVAC Controls - $30
SOLD "A" Pillar Moldings (pair) - $25
SOLD Rear Seats (Black) - $150
SOLD Trunk Deck Liner & Spare cover - $25
SOLD Trunk Side Liners (set) - $40
SOLD Gauge Cluster - $100
SOLD Carpet - $50
Pictures:
Old 04-24-2012, 04:48 PM   #6
25rsti
Member Sales Rating: (130)
Member#: 166324
PM'd about harness'.
Old 04-24-2012, 06:48 PM   #7
Jet Slicker
Member Sales Rating: (25)
Member#: 305360
2004 WRX APS SR/40
World Rally Blue
Pm'd for rear bumper cover.
Jet Slicker is offline   Reply With Quote
Old 04-24-2012, 07:21 PM   #8
Blue Meanie
Member#: 141648
2002 WRX Wagon
PM's Replied
Old 04-24-2012, 09:29 PM   #9
ryanr
Member Sales Rating: (5)
Member#: 203498
2000 Impreza 2.5RS
PM me a price on the transverse links. Thanks!
ryanr is offline   Reply With Quote
Old 04-24-2012, 10:16 PM   #10
Blue Meanie
Member#: 141648
2002 WRX Wagon
Are you looking for just the links or the whole control arms? Also, please give zip so I can figure shipping too.
Thanks,
Geoff
Old 04-24-2012, 10:42 PM   #11
ryanr
Member#: 203498
2000 Impreza 2.5RS
Just the links to 63129
Old 04-24-2012, 11:20 PM   #12
Blue Meanie
Member#: 141648
2002 WRX Wagon
PM'd....
Old 04-25-2012, 10:39 AM   #13
westy2005
Member Sales Rating: (13)
Member#: 108791
2000 RS Sedan
PM'd you
westy2005 is offline   Reply With Quote
Old 04-25-2012, 10:24 PM   #14
Blue Meanie
Member#: 141648
2002 WRX Wagon
Originally Posted by westy2005 View Post
PM'd you
PM's replied and pics added. Lots more pics, so if there's something you want to see let me know.
Old 04-26-2012, 06:45 PM   #15
302subie
Member Sales Rating: (9)
Member#: 303018
2005 STI
Fog lights for sale?
302subie is offline   Reply With Quote
Old 04-26-2012, 10:13 PM   #16
Snoopy408
Member Sales Rating: (6)
Member#: 271104
2006 WRX STi
taillights still around?
Snoopy408 is offline   Reply With Quote
Old 04-26-2012, 11:17 PM   #17
Blue Meanie
Member#: 141648
2002 WRX Wagon
Yep, but got a guy sniffing around on my local site so jump on 'em
Old 04-26-2012, 11:56 PM   #18
LiCelsior
Member Sales Rating: (26)
Member#: 182551
2004 STi
your headlights are STi HIDs or PnP HIDs?
LiCelsior is offline   Reply With Quote
Old 04-27-2012, 12:23 AM   #19
Blue Meanie
Member#: 141648
2002 WRX Wagon
I have no idea... how would I tell?
Old 05-02-2012, 11:12 PM   #20
Blue Meanie
Member#: 141648
2002 WRX Wagon
Parts added bump
Old 05-04-2012, 03:05 AM   #21
kaj
Member#: 290109
2005 WRX
hey, everyone. i'm looking for any and all brackets that hold the OEM heat shield on. if i'm not mistaken, part of it mounts to the intercooler bracket? i have that. my heat shield and brackets were missing when i bought the car. i'd like to put it back. if you have the brackets, please PM me ASAP with price shipped to 93703. i'll be putting this post on all part-outs. i'm hoping you have brackets that fit my car! thanks. oh.. and also need a passenger side, front axle for an '05 WRX. LOL - Jason
kaj is offline   Reply With Quote
Old 05-04-2012, 12:36 PM   #22
Blue Meanie
Member#: 141648
2002 WRX Wagon
I'm assuming, since you're talking about the TMIC mount, that you're just asking about the turbo heat shield. I don't have that but am pretty sure you may just be missing one small one by the down-pipe. You likely could make do just fine with bolting it to the TMIC bracket and I think there are some other bolts around/into itself and maybe the down-pipe.
I do have the axle but I'd like to sell both fronts as a set so $100 + shipping and fees.
Old 05-04-2012, 03:33 PM   #23
kaj
Member#: 290109
2005 WRX
I have an after market down pipe. Maybe the bracket can no longer can be used and that's why it was removed? Meh. Thanks, though!
Old 05-04-2012, 03:40 PM   #24
Blue Meanie
Member#: 141648
2002 WRX Wagon
Yep, You'll not get the heat sheild back on an aftermarket Down-pipe without some fabbing. That's why COBB et al make after market ones.
Old 05-04-2012, 03:51 PM   #25
kaj
Member#: 290109
2005 WRX
Glad I found out now. Thanks for the heads up. Guess I'll sell my OEM shield and search for after market ones.
05 wrb wrx part out Jrod0187 Complete Car Part-Out 272 06-18-2009 06:39 AM
02 WRB WRX Part out.. 02blueWRX Exterior/Styling 106 07-11-2007 12:16 PM
02 WRB WRX Part out.. 02blueWRX Interior/Dressup/Audio & Security 81 07-10-2007 12:44 PM
FS NJ: 02' WRB WRX part out 75sausage Tri-State Area Private Classifieds 24 08-27-2006 10:50 AM
2002 WRB WRX part out ... any locals want body components? Si2WRX South East Region Forum 10 10-22-2004 09:03 PM
