Welcome to the North American Subaru Impreza Owners Club Saturday January 31, 2015
Old 04-24-2012, 06:19 PM   #1
wrxcaptian
Member#: 86041
2003 Impreza WRX
Default Fuel smell in cabin while hot outside
Its in the 90's today and this afternoon a raw fuel smell is strong in cabin. I have read about the hose and clamp repair that seems to be the fix, but most notice the odor when it is cold, Is there something else I should check. I am many miles from a dealership and if I can check a few things first that would be great. Raw fuel smell and 100 miles to dealership makes for a very long drive. thanks
wrxcaptian is offline   Reply With Quote
Old 04-24-2012, 06:31 PM   #2
EdHilario
Member#: 137398
2004 Impreza 2.5RS
Platinum Silver Metallic
Try replacing the rubber hoses for the fuel lines first. If that doesn't work, then it's the hard lines.
EdHilario is offline   Reply With Quote
Old 04-24-2012, 06:41 PM   #3
wrxcaptian
Member#: 86041
2003 Impreza WRX
are referring to the hoses from the filter to the hard lines?
Old 04-25-2012, 10:49 AM   #4
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
I would call the dealer and explain to them the issue. If you are smelling it while it's hot out, it means it's leaking really bad. Tell them you are afraid to drive the car, and see if they will pick up the tab for hauling your car the 100miles to the shop. After all, it's not your fault the car has a defect.
Also, attempting to fix it yourself MIGHT cause the dealer to deny the recall claim (I don't know if they can, but dealers can be sneaky). If they will pick up the car, why not let them do it?
Bacon117 is offline   Reply With Quote
Old 04-25-2012, 12:06 PM   #5
wrxcaptian
Member#: 86041
2003 Impreza WRX
Just to update, I started the car today and no odor as of yet. Took it to the local mechanic and he thinks it may be in the emission system since I sometimes smell gas when filling up the car.
Old 04-25-2012, 02:45 PM   #6
joebobanaught
Member#: 43566
2002 WRX Sedan
Have you modded the fuel pump at all? When my pump got changed, the mechanic didn't put the gasket down perfectly on the tank access hatch in the trunk and fuel smell would slowly seep into the cabin on very hot days.
joebobanaught is offline   Reply With Quote
Old 04-25-2012, 07:45 PM   #7
silverstreak02
Member#: 316307
2002 Impreza WRX
If you're smelling the fuel really bad at fill-ups, I would check the hoses at the charcoal canister. I had an emissions leak caused by a cracked hose on the canister vent valve allowing the vapors to leak out and sometimes cause the fuel smell at fill up or on cold starts.
silverstreak02 is offline   Reply With Quote
Need Help For Raw Fuel Smell in Cabin roburXunitas South East Region Forum 6 01-04-2008 06:43 PM
Raw fuel smell in cabin Wade-O Normally Aspirated Powertrain 16 03-10-2007 04:26 PM
Fuel smell in cabin...... WRBlueMeanie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-05-2006 04:36 PM
Fuel Smell In Cabin (02 Wrx) WrexFactor36 Southern California Impreza Club Forum -- SCIC 14 02-21-2006 02:48 AM
need help - fuel smell in cabin and engine bay nhluhr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-06-2002 08:38 PM
