Old 04-24-2012, 08:32 PM   #1
tenchu
Member#: 64147
1993 STi RA V LTD
Green
Default EJ20G timing belt replacement .. Does this look right?
Changing my timing belt assy, and have some concerns. First old timing belt setup had 2 different looking smooth pulleys, like so:
This is what the new setup looks like (both smooth pulleys the same):
Also, i'm not sure if all the notches are lined up correctly. I can't get the mark on the belt anywhere close to the crank gear, and the right (facing engine) gears don't look like they're lined up perfectly at the double notches, but seem to line up on the side notches of timing cover. Like so:
::Continue to post #2 due to image limit::
tenchu is offline   Reply With Quote
Old 04-24-2012, 08:36 PM   #2
tenchu
Member#: 64147
1993 STi RA V LTD
Green
Any input? I haven't pulled the tensioner pin yet (still need to pull the belt back off and replace water pump) but I wanted to see if i'm doing something wrong here. Thanks.
Old 04-25-2012, 01:37 PM   #3
kheff46
Member#: 66739
2002 WRX wagon
sometimes belt marks aren't spot on with pulley marks. but from your pics, you are there. make sure to put full tension on the idler pulley when you do let it out. then start it to see if you are indeed aligned properly. you will know if it's a tooth off, and will be able to redo it easily if so.
--keith
kheff46 is offline   Reply With Quote
Old 04-25-2012, 02:38 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Maybe it's the angle of the picture, but the crank pulley in picture #3 looks off a tooth. It's not fully rotated to align with the mark on the block.
Old 04-25-2012, 04:25 PM   #5
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
i think you have the wrong belt or youve installed it wrong. the mark at the crank gear should be a thicker line or possibly a series of dots instead of a line. then the other 2 marks in either direction should be a line at the top of each intake cam gear. be sure you compress the tensioner slowly, stick a pin in it, line everything up and when you think you have it lined up, press on the belt where the tensioner will be applying pressure, so you get an idea of where the belt will go once you release the tensioner, and see if the belt goes the right way. sometimes you have to set it up slightly out of time on the left-hand side, so when the tensioner is applied, it all goes into time perfectly.
elislider is online now   Reply With Quote
Old 04-25-2012, 11:45 PM   #6
tenchu
Member#: 64147
1993 STi RA V LTD
Green
I think I actually had the bed on backwards. Its also not an OE belt, so the lines i'm sure are a bit different. I ended up getting everything lined up, pulled the tensioner, did 2 full rotations, and all the pulleys lined up perfect, so i'm content.
Old 04-26-2012, 01:25 PM   #7
tairyhesticles
Member#: 311614
1995 WRX
Tell us how things go!
tairyhesticles is offline   Reply With Quote
Old 04-27-2012, 01:11 PM   #8
kheff46
Member#: 66739
2002 WRX wagon
its easy to leave the crank pulley bolt out, for picture verification(next time?) fyi! i had a belt that looked "wrong" like that, but it was lined up properly and ran fine. it's all in the pulley timing marks, the belt marks are irrelevent @ that point.
also waiting on the end result
--keith
Greddy Evo2. Does this look right? the_owl Interior & Exterior Modification 29 01-11-2005 12:19 PM
Does this look right to you? Jitenshakun Factory 2.5L Turbo Powertrain 15 12-19-2004 08:12 PM
Got my B&B, does this look right? Optimus Prime Factory 2.0L Turbo Powertrain 9 12-03-2004 10:48 AM
Rear Sway Bar Installed... Does this look right? CattyGirl Brakes, Steering & Suspension 28 03-24-2004 11:00 AM
kyb/agx on eibach springs...does this look right? littleblue Brakes, Steering & Suspension 58 03-25-2002 05:13 PM
Message Board Statistics All times are GMT -4. The time now is 03:57 PM.
