Old 04-25-2012, 12:09 PM   #1
kerdos
Member#: 318073
Default Helpp! cobb AP and failed emmsions
Hey everyone, i just took my 06 wrx for emmisions...and it failed. I have Cobb Accessport 2. It failed emmisions because the obd2 had no connection to the emmisions computer. The connector voltage was 0 and the communication status failed. Could anyone help me out here? when i plug in the accessport, it turns on and reads fine so i dont think it would be a fuse? i was reading around and someone said that cobb confuses the CT emmisions testing computer or something? I dono i have a little less then a month to get these emmisions done, any help would be greatt
Heres a pic of the sheet:
kerdos is offline   Reply With Quote
Old 04-25-2012, 12:22 PM   #2
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Does your power outlet work?
Black94Snake is offline   Reply With Quote
Old 04-25-2012, 12:50 PM   #3
kerdos
Member#: 318073
ill have to check that, ill get back to you on that
Old 04-25-2012, 05:24 PM   #4
kerdos
Member#: 318073
my power outlet did have power, infact i had this little usb thing plugged in there, could something being pluged in effect this at all?
Old 04-25-2012, 05:32 PM   #5
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
no, you have a wiring or some other type of electrical problem. what you should do, is checking every fuse in your fuse box and make sure they are all good. your cobb accessport is not the source of this problem.
Old 04-25-2012, 08:51 PM   #6
kerdos
Member#: 318073
alright, i just didnt understand how the accessport could work when i plugged it in but the emmisions testing plug didnt have connectivity, but ill chek all fuses and try a different testing station
Old 04-25-2012, 09:00 PM   #7
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
i'm not sure how the emissions testing goes out in CT, but here in RI, if you go to another inspection station, you will have to pay again. What you should do is check all of your fuses, and contact a "state referee" there may be something else that can be done, that wont cost you additional money.
Old 04-25-2012, 09:15 PM   #8
ragejed
Member#: 76817
2005 WRX
I have the Cobb AP2, running stage 2 and passed twice so far in CT. So the AP is not the cause of the issue.
ragejed is offline   Reply With Quote
Old 04-26-2012, 01:50 PM   #9
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
When was the last time you unplugged your battery? If it has been somewhat recently, you may need to wait for more cycles to pass, before things will be kosher. This of course would be second to the suggestion of checking the fuse. Isn't there some type of modification you need to do.
Perhaps take it for a decent drive (over 100 miles), check the fuses, and go to Advanced Auto to "check" for CEL. It'll throw an error to them, and you'll save yourself some money by not bombing out at the DMV or whatever.
BeastianSTI is offline   Reply With Quote
Old 04-28-2012, 08:46 AM   #10
kerdos
Member#: 318073
ok ill do that first, thank you
Old 04-29-2012, 11:01 PM   #11
leecea
Member#: 37359
2003 WRX
You're thinking his monitors are not ready, but the sheet he posted shows they can't even connect to the OBD-II port to get any type of reading. The port is dead according to them. Trying AutoZone is a good idea - see if they can connect.
There's a post by someone else with a similar issue and he's looking to see of any pins are damaged on his connector. Just an idea.
leecea is offline   Reply With Quote
HELPP cobb ap RJ2120 Newbies & FAQs 7 08-16-2011 08:51 PM
Performance and Looks! Cobb AP and 04-05 or 06-07 BlackTop Aero CF lip for under $1k RavSpec Engine Management 6 02-01-2010 09:34 PM
FS: COBB AP and Stock 03 WRX parts ProSTI Private 'For Sale' Classifieds 4 12-28-2004 09:11 PM
Cobb AP and NE winter conditions question Jduke Engine Management & Tuning 6 12-08-2004 05:57 PM
Cobb AP and HKS TT DOHCammin Engine Management & Tuning 4 10-02-2004 02:57 AM
