Welcome to the North American Subaru Impreza Owners Club Saturday August 29, 2015
Old 04-26-2012, 01:08 AM   #1
Bigga66
Member#: 318042
2007 WRX TR
Satin White Pearl
Default Random misfire codes
So i have an 07 wrx and i get random misfire codes. I bought an accessport and slapped a front mount and cobb staged 2d it for me, however cobb never dyno or tuned it. I am now running the stage three map from cobb and the car is running ok. so i took it to a subaru dealership had them do a compression test and switch plugs they said the engine looked fine. Now the codes are come and go and its for random cylinders. I have seen 1 and 4, 2 and 4, and right now is shoowing misfire in 1 and 3 with PFFFE code. I have read that it could be coils, wiring, plugs, running rich etc. Im kind of a new guy to the subaru scene and hoping someone could help me out. For the record probably ssticking to subaru for a while love that car!
Thanks for your time.
Bigga66 is offline   Reply With Quote
Old 04-26-2012, 01:14 PM   #2
Bigga66
Member#: 318042
2007 WRX TR
Satin White Pearl
Bringing my car to cobb on saturday to have them diag the problem. Before i spend anymore money does anyone have any suggestions on what could be causing the random misfire in random cylinders?
Old 04-28-2012, 01:38 AM   #3
Bigga66
Member#: 318042
2007 WRX TR
Satin White Pearl
well thanks for the help everyone apreciate the feed back........
Old 04-28-2012, 10:33 PM   #4
J-horn92
Member#: 314815
2007 Wrx
I would like to know what they say also, as I have the same year car stage 2 Cobb tune and random misfire as well.
J-horn92 is offline   Reply With Quote
Old 04-28-2012, 11:40 PM   #5
uaoSTI
Member#: 175957
2005 Subaru STI
My 06 outback xt Cobb stage 2 has been having cyl 1 misfire fits for 2 weeks. It only happens at idle and drives fine otherwise until you get to a red light. New plugs, injectors, swapped coil packs, even replaced tmic as it seemed to be leaking. Runs great with new parts but p0301 still is alive and well! Any ideas? Please let me know what Cobb says.
uaoSTI is offline   Reply With Quote
Old 04-28-2012, 11:51 PM   #6
Bigga66
Member#: 318042
2007 WRX TR
Satin White Pearl
Took the car to Cobb today, and they said it was more than likely bad spark plugs or injectors. They wanted to smoke the engine to check for leaks but did not have time. I called my Subaru dealership and found out the guy before me had Subaru "performed tear down of engine found rings correction replaced short block" in june 2011. Then i found in july 2001 "verified concern found fuel injectors #1 and #3 erratic operation. Causing misfire on 1&3 with a count of 50+". replaced them and non mor misfire but its back so i have no idea.
Old 04-29-2012, 07:01 PM   #7
Bigga66
Member#: 318042
2007 WRX TR
Satin White Pearl
I personally just check coils and plugs and everything looked fine. Still trying to find out what's going on. Any ideas at all? Maybe ecu?
Old 04-29-2012, 07:18 PM   #8
quazimoto
Member#: 70395
You should be more helpless. Read the links.....
http://forums.nasioc.com/forums/show....php?p=8961877
http://forums.nasioc.com/forums/show...light=misfires
quazimoto is offline   Reply With Quote
Old 05-01-2012, 03:28 PM   #9
SubaruTech84
Member#: 301472
Sounds like you have might possible have burnt valves to me. Pull a vacuum line off and check vacuum. Should hold rock steady at idle. If the needle fluctuates or jumps around, I'd be taking heads off and sending them to get checked.
SubaruTech84 is offline   Reply With Quote
Old 06-02-2012, 04:10 PM   #10
XLR8T
Member#: 266684
Have you checked to see that the engine is grounded well to the frame?
XLR8T is offline   Reply With Quote
Do those of you who have gotten a misfire code actually feel the misfire? lotarg Newbies & FAQs 22 04-26-2012 03:11 PM
Random misfire codes when idling soukihei Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-11-2009 07:01 PM
TGV codes and misfire code upon start up eliezerrosario Service & Maintenance 3 07-03-2009 05:27 PM
Random misfires, all cylinders stevepius Engine Management & Tuning 2 01-26-2005 04:58 PM
random misfire code #4/cel 0304 harvey oh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-29-2004 07:23 PM
