Welcome to the North American Subaru Impreza Owners Club Tuesday January 27, 2015
Old 04-26-2012, 10:01 PM   #1
dnorton
Member#: 218997
07 WRX Mikey Tuned
JE/FSR built,35r 1300c
Default Smoke ?
Well Guys I've finally got her running and on somewhat of a tune. The tune is OK but not a 100% but at least it doesn't have any knock. She has 2,200 miles on her and I have one issue.
The heads have new valve guides along with a mild port job. Motor was making a lot of noise last time I wrote inside the cabin but not outside. What I found to be the cause was when I put on the intercooler I smashed the aftermarket fuel lines onto the dog bone which transmitted the sound into the frame of the car and into the passenger cabin. Pull off the intercooler and wrapped the lines in a heat blanket and noise went away.
Back to the issue, Here's the deal. When I drive her around town and crank her I see no smoke, none not even in the morning. But I've noticed a couple of times out of no where a puff of smoke at start up. It lonely happens after I get on it real hard with a full amount of boost thru every gear. I'm running 24lbs of boost and was wanting to know could there be a reason she smokes at start up after she's ran hard ? I've only noticed it twice but then again I've only got on her a couple of times hard.
I thought maybe it's pushing oil at high boost into somewhere it's not suppose to be ?
dnorton is offline   Reply With Quote
Old 04-26-2012, 11:21 PM   #2
jdmforlife123
Member#: 298072
04 STI
GRey
Default Engine Promblems
can someone help? i just did a rebuild on my 2004 STI and worked fine for a few days until a week ago white smoke and gasoline started coming out of the exhaust, so i started checking took 3 of my spark plugs out and on the 4th which was cylinder 1 a lot of gasoline came out. So i check if the spark plugs and they were good, check the coil and they also were good have no idea what to do next any help would be greatly appreciated.
jdmforlife123 is offline   Reply With Quote
Old 04-26-2012, 11:40 PM   #3
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Phatron tuned
Condensation
wrxsubiemod is offline   Reply With Quote
Old 04-27-2012, 02:47 AM   #4
jdmforlife123
Member#: 298072
04 STI
GRey
Originally Posted by wrxsubiemod View Post
Condensation
Thats what i thought also, but my car is working horrible
Old 04-27-2012, 08:10 AM   #5
dnorton
Member#: 218997
07 WRX Mikey Tuned
Smoke after being ran hard at start up ?
Old 04-27-2012, 09:57 AM   #6
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
Can you say thread jack?!
What color smoke?
binjoau is offline   Reply With Quote
Old 04-27-2012, 11:11 AM   #7
biodude
Member#: 271720
Dnorton, glad you found your noise. I dont know about your issue, but I personally wouldnt be overly concerned about a puff of smoke after a day of hard running. If it was all the time, I'd be concerned. If it persists maybe you should run a catch can vs. the AOS. (apologies if you have one too and I didnt see it in the pic)
jdmforlife, perhaps you have an injector that is stuck open
biodude is offline   Reply With Quote
Old 04-27-2012, 11:48 AM   #8
noside
Member#: 241254
2010 GR STI
I'd say its the grimmspeed aos not being worth a damn. There is not enough space to allow for proper speration to occur. I had a mild puff after running my car hard one day and I found a kinked line coming off of the turbo inlet to my aos. trimmed the extra slack that originally pinched the line and I have nothing anymore.
noside is offline   Reply With Quote
Old 04-27-2012, 04:43 PM   #9
jdmforlife123
Member#: 298072
04 STI
GRey
is it possible to fix an injector that is stuck open
Old 04-27-2012, 05:22 PM   #10
eNx
Member#: 268580
To keep a clean thread, you should start your own.
eNx is offline   Reply With Quote
Old 04-27-2012, 06:19 PM   #11
dnorton
Member#: 218997
07 WRX Mikey Tuned
What color smoke?
White and I can smell a hint of oil. It's wired that it doesn't happen all the time. They only thing that seems to be common was I've noticed it after hard driving, But not always.
You guys have been great helping me with all the hard questions I've had with this build and there's no way I could have done it without a lot of you. I wish there was some way I could repay you guys. I wish you were local so I could buy you a cup of coffee or whatever.
This question I assume is a tough one since it doesn't happen all the time. Tomorrow morning I plan on doing a compression test. That brings up another question, Should I try to warm up the engine a little before talking the readings ? This might be hard to do since my hands are tight as it is when removing the plugs and installing the tester.
Old 04-27-2012, 06:24 PM   #12
dnorton
Member#: 218997
07 WRX Mikey Tuned
I forgot to answer the question about the GrimmSpeed, Yes sir I have one and a chance to buy a Crawford for a good price. Do you guys think it's worth the money to get rid of my GS and purchase the Crawford ?
Old 04-28-2012, 01:14 PM   #13
NW2TONE
Member#: 212509
unde your hood makin
your **** go faster
always do a compression test at full operating temp. remove all spark plugs while testing. unplug the crank sensor. and keep the throttle plate wide open while cranking by holding your foot to the floor. and make sure you do them all even. I count to 5 strokes when i do it.
and yes the crawford is better than that grimmspeed aos thing. seriously who wants to put oil that has mixed with condensation and gotten all nasty back into their oil.
NW2TONE is offline   Reply With Quote
Old 04-28-2012, 02:35 PM   #14
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
Ensure its also an equal amount of cranks per cylinder too
Old 04-28-2012, 02:44 PM   #15
NW2TONE
Member#: 212509
your **** go faster
thats what i meant by count 5 strokes
Old 04-28-2012, 03:16 PM   #16
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
Lol sorry Dave
Old 04-28-2012, 03:56 PM   #17
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
I thought you were supposed to do it on a cold motor........
~Josh~
EDIT: got my answer.....cold motor bad......
Last edited by ballitch; 04-28-2012 at 04:01 PM. Reason: search function works, YAY!!!
Old 04-28-2012, 10:37 PM   #18
dnorton
Member#: 218997
07 WRX Mikey Tuned
Thanks Guys, I guess I'll have to figure how to get it warm but cool enough to remove the spark plugs.
I bought a Crawford AOS today and plan on installing it when I do the compression test.
Old 04-28-2012, 10:46 PM   #19
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Do it on a cold motor. The readings will be different but still uniform if you understand what I'm saying. Also, a leak down test would be good. Smoke is not good in any way. I assume the turbo is fresh so that's probably not the issue. Could he valve guide seal. Is there any oil in the exhaust ports when you remove exhaust manifold? Either way you shouldn't need an aos at that power level and boost to stop smoke.
stretchedk7 is offline   Reply With Quote
Old 04-29-2012, 09:07 AM   #20
dnorton
Member#: 218997
07 WRX Mikey Tuned
^^^^ I feel the issue is what they guys in the thread say it is. I went and did a bunch of researching and if you search Grimm Speed VS Crawford you too will see the very same. My car does the very same thing they are writing about in that thread. Easy enough to find out. I purchased a Crawford yesterday and at the moment I installing it. After a few test I'll know if that was the issue.
The very first thing I though about was valve guides but since I just had then all replaced with seals and since it only puff a little smoke after I drove the crap out of it I dismissed that idea.
Old 04-30-2012, 02:50 PM   #21
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
The Crawford puts everything back into the oil as well. I have a Tigwerks can made in the same style but with a petcock on the bottom, and the crap that I drain out is nasty. Fuel condensation, sludge...
aboothman is offline   Reply With Quote
Old 04-30-2012, 03:38 PM   #22
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
^^^ well said.
Smoke,smoke & more smoke? scottD Subaru Conversions 3 09-17-2006 04:55 AM
smoke .....no smoke... Distinctive Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 05-16-2006 11:19 PM
How many of you smoke? or used to smoke? plunk10 Off-Topic 34 03-26-2006 08:10 AM
Smoked tails, but not intirely smoked? Know what I mean? Pic request 03twrx Interior & Exterior Modification 36 11-24-2005 09:38 PM
Black smoke, BOV smoking, whats wrong!? GimpWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-04-2004 05:20 PM
