Old 04-28-2012, 09:00 AM   #1
k mier
Member#: 98000
05 sti [email protected]
Default 550+whp for DD, what's next to go boom???
Heads are ported, +1mm valves, GSC2's, good to go 55o+. Block will be Wisecos, I-beams, 12mm oil pump, etc. should be able to handle 550+ too. Exedy triple disk and the fuel system, good to go also.
This will be my daily driver. If I dot all my i's and cross all my t's on the motor/fuel/ecu side of things what will be the next thing to go boom? At 550+ will axles start dropping like flies, gear sets, dccd, etc.? How hard is it going to be to keep this thing reliable at that hp level?
Sure, I want the power, but this will be my DD, would it better to stick with something like the hta green and trade some of that power for reliability?
k mier is offline   Reply With Quote
Old 04-28-2012, 09:45 AM   #2
Layvon
Member#: 195711
STi 04/05/06/07
Ditch the wisecos.
Layvon is offline   Reply With Quote
Old 04-28-2012, 02:59 PM   #3
pheonix991
Member#: 154173
2006 STI
If you launch it, you could be blowing rear axels. There is a vendor on here, I think it's "driveshaftshop", or something along the lines of that name that has beefy rear axels you can get.
When I was talking with the guys at Surgeline, they said once you get a build block, next thing to go will most likely be axels.
This is assuming you get good internals.
pheonix991 is offline   Reply With Quote
Old 04-28-2012, 03:54 PM   #4
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
I don't believe its the rear axles but the rear diff will be the first to go then there is something in the trans that will go next once the diff has bin done not sure what its called will have to look it up
trev762 is offline   Reply With Quote
Old 04-28-2012, 04:23 PM   #5
RIPNBST
Member#: 314403
2007 STi
Drivetrain will result in a financial beating until you get it up to par. Axles, diffs, trans rebuild.
Having something built that will make 550 whp doesnt break parts, using that power frequently does. If you don't drive it like you stole it, which might be hard at first I understand, you could make the drivetrain last long enough to build it to catch up with your power.
RIPNBST is offline   Reply With Quote
Old 04-28-2012, 10:15 PM   #6
k mier
Member#: 98000
Was afraid the rear axles would be at their limit. What about the rear diff, what does it need to handle the power?
Old 04-28-2012, 10:43 PM   #7
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Quaffy rear diffs r one of the best money can buy for durability
Old 04-29-2012, 03:13 AM   #8
shirokuma
Member#: 5489
2013 FR-S
AVO Orange
Given the cost to get it to do 550whp, why not just get a second car as a cheap DD so you don't have to worry about blowing everything up while sitting in traffic?
shirokuma is offline   Reply With Quote
Old 04-29-2012, 01:51 PM   #9
dillonlightman88
Member#: 287889
2008 Wrx
^^^^^^this. Often when an individual is in a financial position to do a build that produces 550+, there is no need to drive it to the dentist. If you've got that kind of cash flow do yourself a favor and buy a second vehicle.
dillonlightman88 is offline   Reply With Quote
Old 04-29-2012, 02:25 PM   #10
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
^^^^^ yap, that what I'm doing right now. i feel sorry for my baby, beating on here day after day. she's all black and blue.
BlackFighter is offline   Reply With Quote
Old 04-29-2012, 04:35 PM   #11
k mier
Member#: 98000
Had a backup before the first mods hit. That car will soon go to boy as he is now 16.
Not driving the backup longer than necessary while making payments on the suby. The suby will be a reliable daily driver, either it will be built to hold 550+, or hp goals will be lowered. Did NOT buy this car for an expensive yard ornament.
What exactly needs to go into the rear diff and tranny?
Old 04-29-2012, 05:00 PM   #12
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
[quote="k mier"]
What exactly needs to go into the rear diff and tranny?[/QUOT
Like your logic with the suby its there to be driven regardless of what mods but for the diff would do all the internals and as far as the tranny alot of guys will put chrome-ally gears 1 through 3rd.
Old 04-29-2012, 05:06 PM   #13
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
But on the other hand just like the old saying "got pay to play" so expect the worst when heavily Modding cars. If its reliability u r looking for don't go past stg 2 good luck
Old 04-29-2012, 05:31 PM   #14
jamal
Member#: 71875
98 Legacy GT
my wheels fit
not really anything. new rear axles is all you really need. An exedy triple is kind of overkill though and probably won't be fun to drive. The act xtss clutch can put up with a lot and is pretty smooth.
cooling is going to be your biggest issue if you drive the car hard/track it.
jamal is offline   Reply With Quote
Old 04-29-2012, 06:04 PM   #15
k mier
Member#: 98000
I was under the impression the triple, or double disk, engaged smooth, more like stock but with a large increase in noise.?
Been wondering about cooling. Looking at an awic setup that may leave more of the radiator surface are open. Stock radiator tank is leaking anyway, time to replace.
Old 04-29-2012, 06:34 PM   #16
purplewrx
Member#: 315291
2012 WRX
PBP
I had no idea you needed 500hp so your car wouldn't be a yard ornament.
Let me guess your going to do NOTHING but go to work and back with all this power :roll eyes:
Might as well leave it stock and track the car. Use it like a real man.
purplewrx is offline   Reply With Quote
Old 04-29-2012, 09:35 PM   #17
timeXlost
Member#: 113924
2005 STI....SOLD!
93 RX7...Not Broken
there is seriously so much bad info in the thread.
the weiscos will be fine
the transmission and rear diff will be fine
the axles might...need attention
the triple is a good clutch, but id look into a act sprung 6 puck. the act xtss will not support that power.
upgrade the rad with a good one...no crap rebadged ebay garbage.
timeXlost is offline   Reply With Quote
Old 04-29-2012, 10:09 PM   #18
jays05
Member#: 78165
05 STI 35r + e85
Your driver's license might go boom
Your axles will probably be fine unless you launch it a lot and try to ride out wheelhop.
IMO, anybody who says you can make big power "reliably" with these cars is trying to make money off you. I didn't see any mention of what turbo you'll be running. Your motor looks like it will flow a lot of air, so if you have a turbo big enough to hit your 550whp goal without being on the ragged edge, it should last a while.
jays05 is offline   Reply With Quote
Old 04-29-2012, 10:37 PM   #19
jamal
Member#: 71875
98 Legacy GT
my wheels fit
Every multi-plate clutch I have driven (at least 5-6) has sucked. Although come to think of it I think the exedy triple was one of the better ones. The thing I don't like about them is how harshly they engage which shocks the drivetrain. A single disc with a sprung hub absorbs some of that shock loading and I like to think it helps a bit in not breaking stuff.
If you have access to e85 (you're not making 550whp on pump gas anyway), keeping the car cool is a little easier. A hood with vents and no scoop is very helpful in getting air through the coolers and out of the engine bay.
Old 04-30-2012, 04:33 AM   #20
k mier
Member#: 98000
timeXlost
Going to check into some axles.
jays05
bw sx300, .88 single scroll, think this is the correct part # from the AirWerks catalog 177511.
jamal
I'll have to stick with the triple, if for no other reason that the amount of $ it cost.
Been running e85 in the dd for the last few years, plans are to keep running it.
As far as getting cool air through the engine bay, what about turning the oem hood scoop around?
Old 04-30-2012, 05:53 AM   #21
Layvon
Member#: 195711
STi 04/05/06/07
For a build of 550 WHP I wouldn't trust weiscos. I stand by my word.
JE and CP offer a much higher quality piston and don't cost too much more.
Old 04-30-2012, 06:26 AM   #22
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Are you serious? Why?
Crystal and i run wisecos and we make over 500whp
Old 04-30-2012, 12:41 PM   #23
oceanwater48
Member#: 315882
V8 U make
Baby Poop
Everyone has their opinion juanmedina. No need to drag queen out of it.
Just like my opinion, aftermarket clutch and flywheel are ****. They are just expensive, wear your tranny out faster.
oceanwater48 is offline   Reply With Quote
Old 04-30-2012, 11:27 PM   #24
jamal
Member#: 71875
98 Legacy GT
my wheels fit
doesn't really work that way. the back of the scoop is getting into the high pressure area at the base of the windshield so air is still actually flowing back into the scoop when you do that. The vents need to be toward the front of the hood. Kaminari has one of the better ones out there.
Old 05-01-2012, 03:21 AM   #25
NoGraffix
Member#: 276209
I am Rub
Function>Form
I feel like a 500whp car as a daily would just not be fun to drive. It's too quick for the streets, the peak torque is going to be so far to the right of the powerband, the cost of maintaining the car to simply get to work, grocery store, ect, seems like a waste of money.
NoGraffix is offline   Reply With Quote
is my car goin to go boom? Subie-Do000 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 03-18-2009 05:01 AM
what's supposed to go/attach here (missing bolts in engine bay) wangless Newbies & FAQs 13 02-28-2008 07:30 AM
What's required to go to Nationals? Patrick Olsen Motorsports 6 05-19-2004 01:58 PM
What's needed to go offroad? Tas Motorsports 12 11-19-2001 01:11 PM
What's next to upgrade....seats! What are people using? gtguy Legacy Forum 7 01-08-2001 09:02 AM
