Old 04-28-2012, 01:34 PM   #1
Ostrowrx
Member#: 141342
2010 WRX STI
Default Can A Cam bearing take out a rod bearing.
So I had a 2.5 non avcs wrx motor built with 04 sti heads, and sadly it devoured a rod last week after 3500 miles. So I went to take it apart and when I removed the cam cover on the passenger side I discovered that the rear cam bearings were not tightened down as seen in the pic. Now I'm no enine expert so I'm looking for an opinion on whether or not the cam bearings not being tightened could have created enough metal to take out the rod to crank bearings? Let me know wht you think! I know one bolt looks tightened but its not.
Ostrowrx is offline   Reply With Quote
Old 04-28-2012, 01:51 PM   #2
AREA1320
Member#: 112508
Actually you don't have cam bearings.. But it's possible that with the cam caps not being tq'd to spec that material could have made its way to the rods.. But unlikely that that's the root cause. It was most likely something else... And judging by the over use of sealant on the valve cover contact points they most likely over used it somewhere else starving the motor
AREA1320 is offline   Reply With Quote
Old 04-28-2012, 02:17 PM   #3
timeXlost
Member#: 113924
2005 STI....SOLD!
93 RX7...Not Broken
Yeah, way too much silicone on that thing. All it takes is a tiny piece to break off and clog an oil passage.
Between the overuse of rtv and the loose cam cap, I'd be leaning toward something else being over looked, incorrectly installed, or improperly measured causing the issue.
timeXlost is offline   Reply With Quote
Old 04-28-2012, 04:37 PM   #4
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
I would have to say that the rod brg failure was due to overuse of rtv,he has it globbed all over the upper end,can only guess how much was used assembling the bottom end.
john 1badSTI is offline   Reply With Quote
Old 04-28-2012, 06:28 PM   #5
Ostrowrx
Member#: 141342
2010 WRX STI
I even found some stuck to the cam shaft. Only a tiny piece but it ws def there
Old 04-28-2012, 10:22 PM   #6
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
who assembled that motor?
Old 04-28-2012, 11:18 PM   #7
2milehi
Member#: 81633
'98 RS-T
So what you are saying is that a piece of silicone dislodged, got past the screen of the oil pickup, then got past the 40 micron oil filter and then lodged itself into a crank bearing.
OP thanks for the clear photos. Most people take a crappy phone pics and think that is sufficient.
2milehi is offline   Reply With Quote
Old 04-28-2012, 11:25 PM   #8
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
The builder obviously missed a few steps. Got crazy with silicon and probably didn't check the bearing clearances.
Engine build fail 101
wrxsubiemod is offline   Reply With Quote
Old 04-29-2012, 12:11 AM   #9
jesterjames
Member#: 252663
Chapter/Region: HIIC
I think he's saying that who ever assembled the motor went to ****in town with silicone. If. He used a ton on the case halves the excess could judd into the oil passages for the bearings
jesterjames is offline   Reply With Quote
Old 04-29-2012, 12:13 PM   #10
oldandslowjim
Member#: 259570
Default cam
you COULD have a lub. prob. as oil would flow from the loose caps droping flow and pressure to the other bearings plus the extra oil then has to drain back to the pan lowering the level in the pan
oldandslowjim is offline   Reply With Quote
Old 04-29-2012, 01:00 PM   #11
3barboost
Member#: 73609
2002 wrx
which cylinder knocked a bearing ? if the cam was that loose -
a) you would of heard a problem in the head
b) the motor would probably had a misfire as those valves were never going to operate correctly
c) I am surprised it lasted 3500 miles like that
it musta sounded like a bucket of bolts
are you sure it knocked a bearing and its not just the loose cam journal you were hearing ?
3barboost is offline   Reply With Quote
Old 04-29-2012, 05:28 PM   #12
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
Not sure if it could cause a rod bearing failure, but that is completely un-friggin-acceptable. Whoever built that engine needs to be fired from life, or at least lay off the booze while building. I can't believe they put sealant around the spark plug hole gaskets. Complete and utter fail.
Zackbo is offline   Reply With Quote
Old 04-29-2012, 07:09 PM   #13
john 1badSTI
Member#: 77470
NO if too much was used on the case halves it could have squeezed out and got in an oil passage that feeds oil to the mains after the filter.
Old 04-29-2012, 09:11 PM   #14
timeXlost
Member#: 113924
2005 STI....SOLD!
93 RX7...Not Broken
this.
Old 04-29-2012, 10:27 PM   #15
2milehi
Member#: 81633
'98 RS-T
A lot of assumptions - let us ask the OP.
So does it appear that there was excessive amount of sealant used around the block halves?
What makes you suspect a rod knock? Is there a bunch of bearing material in the engine oil (oil pan area)?
Can low boost lead to a spun rod bearing? AnthonyA182 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 03-31-2010 10:36 AM
Can you always 'feel' a spun rod bearing? Zackbo Built Motor Discussion 3 10-25-2009 08:21 AM
WTP CP Pistons, Rods, Bearings, Cams, Valve Springs & Retainers Ensi Private 'Wanted' Classifieds 3 06-09-2009 12:01 PM
If I spun a rod bearing on hybrid setup - buy upgraded rod bearings? MarylandEcstasy Built Motor Discussion 4 05-20-2007 12:54 PM
Bear takes our cell site, cell site takes out bear. Pics included. Beer:30 Off-Topic 111 03-06-2007 05:47 PM
