Old 04-28-2012, 01:54 PM   #1
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
Default OBX Throttle body spacer
I know that OBX is a knock off brand by trade, but as long as the dimensions on the spacer are correct, what else could be harmful about this? Just looking to rotate throttle body so I can have AC and reversed intake.
layvon
Layvon is offline   Reply With Quote
Old 05-07-2012, 01:27 PM   #2
reid-o
Member#: 103631
2004 STI
Why not just get the Full Race spacer set? I ordered mine from them for a reasonable price. It comes with aluminum TGV and TB spacers.
reid-o is offline   Reply With Quote
Old 05-07-2012, 02:25 PM   #3
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
I had one made actually. I emailed FR and didn't get any response from them. This is the 2nd time I've emailed them with no response.
Old 05-07-2012, 03:16 PM   #4
reid-o
Member#: 103631
2004 STI
That's strange. They're normally very responsive. In fact, I cringe at their response time when asking for prices.
Old 05-07-2012, 05:48 PM   #5
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
Lol ill try PM next time vs email.
Old 05-07-2012, 07:13 PM   #6
Member#: 67
1999 Outlasting
the competition.
Is it just a simple TB spacer? how thick? Seems like a easy part for us to throw in the CNC.
Links to one?
Old 05-07-2012, 07:24 PM   #7
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
tom make some for us brotha!
bue car is offline   Reply With Quote
Old 05-07-2012, 09:43 PM   #8
reid-o
Member#: 103631
2004 STI
I'd take one if it was phenolic. I don't have my car with me. I can go look later.
Old 05-07-2012, 10:00 PM   #9
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
I messaged tom, this is the spacer that I drew up in AutoCAD. Over dimensioned, but the person I had make it wanted as many as possible. This was made by measuring a throttle body gasket.
Old 05-07-2012, 10:05 PM   #10
stephens
Member#: 124581
Holy numbers everywhere batman. Good drawing, but a lot of scattered numbers.
stephens is offline   Reply With Quote
Old 05-08-2012, 05:53 AM   #11
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
Like I said, over dimensioned. When it was for me to take to a local machine shop there were about 1/2 those dimensions. But they wanted $225 to do it so...I didn't
Old 05-08-2012, 05:54 AM   #12
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
Old 05-08-2012, 10:00 AM   #13
Member#: 67
1999 Outlasting
the competition.
225 seems about right for a one off part with coding. That being said, if i were to knock a bunch off out of some drops we have here it would be WAY under 100 bucks. My question is how thick do you guys want/need?
Tom
Old 05-08-2012, 11:50 AM   #14
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
I ended up going with 3/8" which is 9.5mm.
I've seen 8mm work also. Once I get my spacer ill measure clearance to let you.know a bare minimum for rotation on my setup.
I haven't ground anything on alternator bracket and I think it will work right now as is. I have 8mm grimmspeed phenolic spacer on intake with gaskets each side. Stock 04 Sti intake manifold.
Old 11-04-2012, 12:04 AM   #15
Ballistic1350
Member#: 156877
04 sti
Anyone ever make these?
Ballistic1350 is offline   Reply With Quote
Old 11-04-2012, 11:24 AM   #16
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
I have one if you need it.
Old 03-30-2013, 09:34 PM   #17
impreza2.0
Member#: 196374
What became of this? Any reviews after use? Install trouble or info? lol... curious to see what, if any results came from use. This seems like a nice place for a gauge sender, or just something to take the stubbiness out of the IC/TB hose by reducing the gap.
For those of us who have PnP'd our TB and IC necks, I doubt there is gain.
Please post a review!
impreza2.0 is offline   Reply With Quote
Old 04-01-2013, 05:45 AM   #18
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
I didn't end up using it. I was using it to attempt to rotate my intake manifold while keeping the AC.
Old 04-01-2013, 11:34 AM   #19
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
you still have the spacer lying around? are the dimensions the same as you posted above of the gasket?
Old 04-01-2013, 01:48 PM   #20
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
Nope i sold it.
I have it drawn in AutoCAD if you want.it. i had it cnc'd
Old 04-12-2013, 05:37 PM   #21
TickTack
Member#: 100353
I had a handful of these cut on a waterjet a while back. Still have a few. PM me if you're interested.
http://forums.nasioc.com/forums/show....php?t=2488327
TickTack is offline   Reply With Quote
Old 01-05-2014, 12:26 PM   #22
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
Nope i sold it.
I need you to modify that drawing so it can accommodate my iacv, so I can rotate my 2.5i intake rotated and be able yo keep my ac lol. I will have to sketch it up for you and see what we can work out
seanathanq83 is offline   Reply With Quote
Old 03-02-2014, 03:51 AM   #23
BloodLineRacer02WrX
Member#: 373259
2002 wrx
blue
I'm looking for an adapter so I can use my dbc tb on a dbw 2.5i intake manifold. Anyone got something like this?
BloodLineRacer02WrX is offline   Reply With Quote
Old 03-02-2014, 05:11 PM   #24
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
Seanathanq contacted out front I believe.
Old 03-04-2014, 08:25 AM   #25
seanathanq83
Member#: 173241
I did yes but it's not to use a spacer my intake is either there or on the way there after they clean everything off we are going to work with a way of modifying it to fit the DBC, thinking they will weld it up re surface it, re drill and tap the holes and cut a slot for the iacv. I will post info AMD pics as I hear from them
Throttle body spacer PARANOID56 Normally Aspirated Powertrain 13 12-14-2005 08:51 PM
Throttle body spacer for 2.2??? Jaredm82 Normally Aspirated Powertrain 8 07-09-2004 12:58 PM
throttle body spacer Haven Normally Aspirated Powertrain 6 09-30-2001 01:45 AM
Nitrous Throttle Body Spacer Joncas Normally Aspirated Powertrain 5 07-15-2001 04:06 PM
