Old 04-28-2012, 08:01 PM   #1
impboi76
Member#: 134218
2005 2.5RS wagon
Regal Blue Pearl
Exclamation Please help: engine won't turn over...
I just got a bunch of LEDs (tails-brake, license plate, front corner-parking, & dome light) from superbrightleds.com and now I can't get the engine to turn over.
After finding out that if the bulbs are installed backwards -> leads to a blown fuse, I replaced all of the blown fuses.
Has anyone else had this problem? Does anyone know what else I can check? Or am I stuck with going to a dealer/repair place?
impboi76 is offline   Reply With Quote
Old 04-28-2012, 08:04 PM   #2
Thunderpaw
Member#: 242205
2009 wrx
blue
Check battery. Still charged?
Thunderpaw is offline   Reply With Quote
Old 04-28-2012, 08:06 PM   #3
impboi76
Member#: 134218
2005 2.5RS wagon
Regal Blue Pearl
Thank you. Yes. I have a brand new battery, purchased & installed by a Subaru dealer. I had the volts checked. Everything else works, its just that the engine doesn't turn over.
Old 04-28-2012, 08:10 PM   #4
Web Foot STi
Member#: 39086
2004 STi
Now old is your battery?
It could be an old school problem.
If you were poping fuses there is a good chance that the other screw ups drained the battery.
Edit: Amazing what 6 minutes can say.
Web Foot STi is offline   Reply With Quote
Old 04-28-2012, 08:14 PM   #5
impboi76
Member#: 134218
2005 2.5RS wagon
Regal Blue Pearl
Thanks! The battery is at least 1 year old. I have never had any battery problems before. My first battery lasted 7 years & 82,000 miles.
Old 04-28-2012, 08:16 PM   #6
burkart
Member#: 305000
2005 Legacy GT 5MT
Bright Silver Metallic
try a hard reboot of the BIU computer: unhook the negative battery terminal for at least 60 seconds
burkart is offline   Reply With Quote
Old 04-29-2012, 09:40 AM   #7
EVL RS-T
Member#: 30071
2001 RS-T
2015 XT
When you blow fuses, sometimes the main fuse on the ECU gets blown. Check the location where the ECU is to see if the fuse on it is blown... that'll prevent the car from starting.
EVL RS-T is offline   Reply With Quote
Old 04-29-2012, 04:58 PM   #8
impboi76
Member#: 134218
2005 2.5RS wagon
Regal Blue Pearl
@burkart: I tried disconnecting the battery & I still have the same problem. Thanks for your suggestion!
@EVL RS-T: not sure if I have access or know where the main ECU relay/fuse is.
Bottom line, I'm going to the dealer to see if they can find out what happened. Ugh - please be careful when changing to LEDs!!! The bulbs are polarized & when installed backwards, many things can happen.
Finished Swap, Motor won't turn over. Please help :) snowcrzy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 32 07-23-2007 09:59 PM
Engine won't turn over?? stealthscoob Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-31-2006 11:48 PM
Help: DRLs won't turn off! AutoXJunkie Electrical & Lighting 2 09-10-2005 12:45 PM
Engine won't Turn over or start !!!! burrito007 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-20-2005 01:20 PM
Do I have a bad unichip?? (Vishnu) Car won't turn over wayoutwest Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 07-22-2002 04:57 PM
