Old 04-29-2012, 03:30 PM   #1
Jet130
Member#: 314284
Default Fresh Hybrid knocking/ticking diesel sounding! =Video=
http://www.youtube.com/watch?v=rmy7C...ature=youtu.be
Just had a local shop finish a hybrid build for me. Supposedly theyve done several hybrids.
Wiseco Pistons on new STI block
Stock rods
Sti head gasket
Stock cams / valvetrain on 2.0 heads
New belts, oil pump, water pump
Noise is driving me nuts - no metal flakes in the oil, no oil consumption or smoke. Only driven about 50 miles. Has gotten slightly quieter but still sounds like a diesel!
Jet130 is offline   Reply With Quote
Old 04-29-2012, 03:32 PM   #2
Jet130
Member#: 314284
Besides a no name uppipe - all stock and no tune.
Old 04-29-2012, 03:36 PM   #3
Jet130
Member#: 314284
Old 04-29-2012, 03:38 PM   #4
Jet130
Member#: 314284
Bump!
Old 04-29-2012, 04:00 PM   #5
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
Sounds like a mean case of piston slap. What forge were the pistons, and what was the ptw clearance?
Zackbo is offline   Reply With Quote
Old 04-29-2012, 04:02 PM   #6
25rsti
Member#: 166324
Does it go away after warming up?
Old 04-29-2012, 05:10 PM   #7
Jet130
Member#: 314284
Not sure to be honest.
Old 04-29-2012, 05:10 PM   #8
Jet130
Member#: 314284
Gets quieter but is still there.
Old 04-29-2012, 05:24 PM   #9
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
I have a hybrid build that sounds very similar; not quite as bad, but almost. Piston slap. It doesn't get quiet until the coolant temp gets above 205. I had to put in a higher range thermostat just to get it to shut up
Old 04-29-2012, 06:11 PM   #10
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
Before you go jumping to conclusions check for pre turbo exhaust leaks. They sound similar to what i'm hearing in the video.
2gnt2wrx is offline   Reply With Quote
Old 04-29-2012, 06:17 PM   #11
Jet130
Member#: 314284
Although there maybe a leak - the dominant sound is coming from the center of the block. Sounds like someone knocking on a metal door if you put you ear up to a screwdriver. The sound get slightly quieter after warm-up, but not much.
Old 04-29-2012, 08:25 PM   #12
03SubyWRX
Member#: 200767
2007 OBS 5MT
Lifted
I'd check your builder to see what your PTW clearances are. I vote piston slap...
03SubyWRX is offline   Reply With Quote
Old 04-29-2012, 08:28 PM   #13
ronzogonzo
Member#: 136671
WRX HTA GT3076R
9cm2 eWG'd It's ALIVE!!
loud piston slap, were the skirts on the pistons coated?
Whats the PTW?
They should have given you a build sheet with bearing clearances, Piston specs, ring end gaps, PTW at the least.
ronzogonzo is offline   Reply With Quote
Old 04-29-2012, 08:33 PM   #14
Team Scream
Member#: 121532
2006 FXT/STi 6MT
01 Aerosim GC8 Coupe
If your wiesco pistons have offset pins, they could have been put in backwards.
That would cause what would have been a slight (normal) slap to become magnified and will certainly cause premature skirt wear and the noise will never go away until the pistons are installed correctly.
What does the builder say about the noise?
Team Scream is online now   Reply With Quote
Old 04-29-2012, 09:08 PM   #15
blkwagon
Member#: 102857
RHD sedan sti swap
high on meth
Man that is loud. Sure you don't have any big exhaust leaks?? That is not normal piston slap
blkwagon is offline   Reply With Quote
Old 04-29-2012, 11:43 PM   #16
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
OP... check for leaks. Im serious, i've heard really bad tapping noises that changed with rpm from leaks.
Old 04-30-2012, 12:23 AM   #17
Strider327
Member#: 131280
2004 Impreza WRX
Check for leaks first. If it ain't leaks, be really worried!
Strider327 is offline   Reply With Quote
Old 04-30-2012, 03:19 AM   #18
dinggoo
Member#: 295432
2003 WRX
MBP
valve lash? (clearance)
dinggoo is offline   Reply With Quote
Old 04-30-2012, 09:12 AM   #19
biodude
Member#: 271720
I have some pretty loud slap in my car, but your sounds like something more is going on.
Like others said, check for exhaust leaks first, but if it were me, Id be having a bit of a converstaion with that shop.
biodude is offline   Reply With Quote
Old 04-30-2012, 11:12 AM   #20
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Piston slap. From the way that you worded it I am thinking that the shop did drop in pistons for you. This is where they just remove the stock pistons and drop in forged ones. Sometimes you can get away with that if it's measured and matched at least a bit, sometimes not... like in your case.
As TS said, the wiesco pistons have offset pins, they could have been put in backwards.
mick_the_ginge is offline   Reply With Quote
Old 04-30-2012, 11:19 AM   #21
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Old or new timing belt tensioner? and old or new style?
Old 04-30-2012, 11:20 AM   #22
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Old 04-30-2012, 11:22 AM   #23
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
The thud sure sounds like the tensioner.
Old 04-30-2012, 11:34 AM   #24
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
My #1 vote would be piston slap for sure and really bad case of it. Does your car reach target boost if u get on it? If not you may have a bad up-pipe leak. The weld snapped on my up-pipe and it sounded just like that but it would obvious. It was blowing air like a hair dryer out of the gap.lol
Slimsti is offline   Reply With Quote
Old 04-30-2012, 12:21 PM   #25
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Listening a second time it does have that clunk kinda sound.
Engine knocking sound [video] newera Service & Maintenance 2 03-20-2012 11:00 PM
strange knocking/ticking behind glovebox smidge112 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-17-2012 12:10 PM
Knocking/Ticking sound *video* Shinallsm Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 09-27-2009 05:44 PM
piston slap? tensioner? knock/tick sound smurfwrx Service & Maintenance 14 10-19-2007 07:47 AM
Odd knocking/ticking sound? Deeman81 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 02-23-2003 08:20 PM
