Old 04-30-2012, 01:20 AM   #1
RallyBugeye
Member#: 318555
2002 Impreza WRX
Default 02 WRX Clunking Noise Problem
So i have a 2002 Impreza WRX sedan with 115k miles. Recently it has been making a weird clunking noise but only at low speeds when turning, whenever i hit the brakes and then when i hit bumps. Its really annoying and just seems to be getting worse. It seems to be coming from the front end. Im worried to drive it cause i don't want to make it any worse. Im thinking its the struts or wheel bearings. Any ideas of what it could be or how to diagnose it? Thanks.
RallyBugeye is offline   Reply With Quote
Old 04-30-2012, 01:25 AM   #2
truetotexas
Member#: 228295
2013 WRX
Satin White Pearl
i would say struts if its clunking. but to test the bearings up front i would jack up the car and try and shake the wheel. if theres any play then theres a good chance that it could be the bearing. but ive never heard a bearing selectively clunk, its usually a constant humm type noise.
heres what i mean by shake the wheel:
truetotexas is offline   Reply With Quote
Old 04-30-2012, 01:26 AM   #3
truetotexas
Member#: 228295
2013 WRX
Satin White Pearl
edit: not sure why it posted more than once.
Old 04-30-2012, 03:27 AM   #4
sogah87
Member#: 286573
2016 WRX STi limited
Crystal White Pearl
i was just doing some reading, and it sounds like it might be the center differential... Try looking into this on the forums.
sogah87 is offline   Reply With Quote
04 wrx clunk noise please help! accordboost Brakes, Steering & Suspension 22 02-18-2012 04:30 PM
02 wrx/ clunking noise from rear diff area riderome Service & Maintenance 1 09-07-2010 11:39 AM
[06 WRX] Clunking noise coming out of first... ControlFreak Brakes, Steering & Suspension 3 06-29-2006 01:12 PM
help with 02 wrx wagon noises ekoh81 Brakes, Steering & Suspension 14 08-16-2005 12:03 PM
02 wrx making noise rkratt007 Transmission (AT/MT) & Driveline 1 01-23-2005 06:30 PM
