Old 04-30-2012, 12:54 PM   #1
REX8
Member#: 24038
Default Lower Ball Joint Thread Size?
Size and pitch of the thread on the front lower ball joint for a Impreza/WRX?
Thank you!
John
Old 06-07-2012, 01:51 PM   #2
Fourteen Alpha
Member#: 300460
1972 Jensen-Healey
British Racing Green
I need to know this right now
Fourteen Alpha is offline   Reply With Quote
Old 06-09-2012, 03:30 AM   #3
Fourteen Alpha
Member#: 300460
1972 Jensen-Healey
ok, ill just throw this out there for anyone that might need it down the line
its 1.25 pitch but i do not know the diameter.
Old 06-10-2012, 03:47 PM   #4
jeschulz
Member#: 81959
2001 outback 2.5L
12mm 1.25. Actually found it at Lowes.
jeschulz is offline   Reply With Quote
Old 08-12-2012, 11:29 AM   #5
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
It's the same as the wheel studs and a lugnut will screw on.
Superorb is offline   Reply With Quote
Old 08-15-2012, 06:19 AM   #6
mhoerath
Member#: 131379
2003 354 [email protected] rpm
justablue hatch
ball joint nut is a castle nut...allows a cotter pin (goes thru hole in ball joint stud) to hold the nut on.
mhoerath is offline   Reply With Quote
Old 08-15-2012, 12:28 PM   #7
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
What's your point?
Lower ball joint bad 06SilverWRX Newbies & FAQs 2 06-15-2009 09:23 PM
Lower Ball Joint csugden Brakes, Steering & Suspension 3 01-28-2009 10:19 AM
Odd request - used lower ball joint AugustusMaximus Tri-State Area Private Classifieds 2 11-12-2007 09:44 PM
tore rubber on lower ball joint!! boltonak Brakes, Steering & Suspension 2 10-01-2007 07:53 PM
Removing Lower Ball Joint?? DanBelford Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-31-2006 02:56 PM
