Old 04-30-2012, 01:52 PM   #1
WRXineohP
Member#: 305447
Default Compression test results
Hey!
I have a 2010used WRX and I had it compression tested and wanted to know what you guys thought of the result.
Cylinder 1: 138
Cylinder 2: 132
Cylinder 3: 138
Cylinder 4: 132
33000 miles on the car
Thanks!
WRXineohP is offline   Reply With Quote
Old 04-30-2012, 02:07 PM   #2
Brock31
Member#: 128115
2004 4EAT Wagon PSM
enginuity is cool
They look consistent, which is the important thing.
Brock31 is offline   Reply With Quote
Old 04-30-2012, 03:50 PM   #3
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
Originally Posted by WRXineohP View Post
Hey!
Cylinder 1: 138
Cylinder 2: 132
Cylinder 3: 138
Cylinder 4: 132
Thanks!
Being consistent is important to knowing if anything is wrong with a particular cylinder. If they are low overall, it means that the engine is worn. I don't know the spec, you will have to look it up in an FSM.
Bacon117 is offline   Reply With Quote
Old 05-01-2012, 08:52 AM   #4
rkramer
Member#: 118209
2015 WRX Limitec
138 is the bottom of normal on a warm engine, but there are so many variables. A cold engine at high altitude would high much lower numbers.
Compression test results TyranosaurusWRX Newbies & FAQs 0 03-13-2004 10:32 PM
Compression Test Results subachad Normally Aspirated with bolt-on Forced Induction Powertrain 4 11-29-2003 07:08 PM
Compression Test Results @ 55,650k PaulRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-12-2003 02:59 PM
EJ25 Compression Test Results at 50,000 miles latinskllz Normally Aspirated Powertrain 4 11-11-2002 02:46 PM
Compression test results numbers Imprezer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 09-12-2001 01:08 AM
