Old 04-30-2012, 04:00 PM   #1
Decade
Member#: 285526
2012 WRX 5-door
ISM
Default All good for first wash?
So I picked up my ISM wrx this weekend and am about to order the cleaning supplies so I will have them ready once I wash the car for the first time. I have gathered most of, if not all, of these products through research on nasioc and want to see if I am wrong with anything I have chosen. Tire dressing I am still looking into after reading about how some can stain the car's paint.
*Soap-still looking
*2 5gallon buckets(prob just get a couple from Lowes)
*Meguiars Clay Bar kit with spray
*Meguiars super degreaser 4 to 1
*Meguiars All season engine dressing
*Cobra Delux 600 Microbifber towels for drying, waxing/polish(when needed)
*Foam Gun
*2 Grit Guards for the buckets
*Collinite 845
I am still looking for what mits to get and also looking for what sealant/polish is recommened along with what applicator to use for waxing.
Decade is offline   Reply With Quote
Old 04-30-2012, 04:27 PM   #2
brett192
Member#: 274252
2002 WRX Sedan PSM
VF39, EWG & 6 speed
Someone correct me if I'm wrong, but isn't dish soap really, really bad to use as a car wash?
I use armorall wash & wax because it was only $6 for a gallon, and meguiars claybar, quick detailing spray and wax. Gets this 10 year old paint looking as good as it will ever look.
brett192 is offline   Reply With Quote
Old 04-30-2012, 04:31 PM   #3
Decade
Member#: 285526
2012 WRX 5-door
ISM
I use armorall wash & wax because it was only $6 for a gallon, and meguiars detailing products. Gets this 10 year old paint looking as good as it will ever look.
See I have always thought that too. I read it going both ways. I would feel way more comfortable using an actual car soap so I will change that. Thanks, I will do more research on what soap to use.
Old 04-30-2012, 04:36 PM   #4
YCT
Member#: 122167
2008 Mazda CX-9 GT
Liquid Platinum Metallic
I believe dawn is only used if you are looking to remove wax and reapply after a wash.
YCT is offline   Reply With Quote
Old 04-30-2012, 04:37 PM   #5
Decade
Member#: 285526
2012 WRX 5-door
ISM
Thanks to you both. I just remember when I owned by RX8 those guys swore by Dawn. I have usually used one of the turtle wax soaps. Thanks again.
Old 04-30-2012, 04:39 PM   #6
xlr8onu
Member#: 36015
2014 Grand Cherokee
as I understand it dawn cuts grease, or petroleum based products so it strips the wax off the car. Its fine before waxing but not after. I always use it prior to the seasonal wax session.
EDIT: Too slow on response
xlr8onu is offline   Reply With Quote
Old 04-30-2012, 04:40 PM   #7
Amnizu
Member#: 178854
2008 WRX, '11 BMW 1M
Red, AW
Don't use Dawn. Your super degreaser will strip wax and wont dry out your plastic non painted parts.
You'll want to get a high quality auto shampoo as well. Meguiars makes a few, Chemical guys stuff is also very good.
Are you planning on claying and sealing as well or just washing?
As far as applying wax / sealant if you have a DA get some lake country CCS gray pads. If your doing it by hand get a couple of their red hand pads.
As for wax / sealant what are your goals? Colonite 845 and FK1000p will last a really long time, Menzerna Powerlock sealant not quite as long but will look better those are the sealants I would recommend.
Amnizu is offline   Reply With Quote
Old 04-30-2012, 04:43 PM   #8
Decade
Member#: 285526
2012 WRX 5-door
ISM
I will be waxing by hand. Ill check into those applicators, thanks. I plan to wash, clay, and wax then I have read to use sealant after every few months?
Should I not use the meguiars super degreaser??
Old 04-30-2012, 05:03 PM   #9
Amnizu
Member#: 178854
Red, AW
The Meguiars is good for stripping wax but you don't really want to use it for your maintenance washes. I recommend something more mild for your maintenance washes.
Your mileage may vary on how often you need to wash, clay and wax. I personally do a full detail on both my cars twice a year which will include a polish back to 90 or 95% correction.
As far as wash media, I prefer a MF wash mitt like this:
http://www.autogeek.net/super-plush-wash-mitt.html
Old 05-05-2012, 02:47 PM   #10
V4NCITYRIDER
Member#: 307939
2012 WRX Base Sedan
Hi I'm new to detailing - Does anyone know if a factory ordered car would come with sealant and waxing? Or is that something the dealership takes care of ?
Edit: sorry I guess my question is really: how do I know if I need to strip the wax on a car or not?
V4NCITYRIDER is offline   Reply With Quote
Old 05-05-2012, 02:59 PM   #11
XERO287
Member#: 253541
2011 WRX 5DR Premium
Guaranteed it'll come with some of the best swirls you've ever seen.
XERO287 is offline   Reply With Quote
Old 05-05-2012, 05:13 PM   #12
RedStripe
Member#: 319210
2012 Impreza Limited
Dark Gray Metallic
I like to use 1-2 ounces of DP Rinseless Auto Wash in the wash bucket instead of soap - with a microfiber cloth or microfiber mitt. Dirt/dust/grit stick to the DP wash, gently lifting it off your paint. Works really well. Then rinse with the hose.
Dealers don't usually apply a high-quality wax. When you're ready to detail, use a good/gentle cleaner-polish; then a high-quality wax. Optional: apply a paint sealant between cleaner-polish and wax. You'll get a lot more durability and protection with a sealant; the wax only gives a high-gloss shine. I don't usually have to apply sealant more than twice a year -- I use my garage at night, but daily it's out in the NC sunshine on a 100+ F parking lot. I like the Klasse cleaner polish and Klasse high-gloss sealant, but there are other good products doing similar stuff.
RedStripe is offline   Reply With Quote
Old 05-05-2012, 05:18 PM   #13
RedStripe
Member#: 319210
Dark Gray Metallic
The factory applies a mild adhesive, then covers the large surfaces in plastic. The dealer has to remove the plastic, strip the adhesive, then detail before delivery.
Some dealers offer a sealant option, but it will be expensive. If you don't buy one or they don't offer, it will only have a cheap coat of wax -- you'll have to strip that anyway.
So start with a clay-bar, then a really gentle cleaner-polish or all-in-one, then a sealant or quality wax.
Last edited by RedStripe; 05-05-2012 at 05:24 PM. Reason: incorrectly read the original post
Old 05-05-2012, 06:59 PM   #14
V4NCITYRIDER
Member#: 307939
2012 WRX Base Sedan
Thanks guys. I'm planning to ask the dealership to skip the wash/ detail to avoid swirls and scratches... in that case there wouldn't be anything to strip would there?
If that's the case I'm planning on following these steps:
Wash
Claybar
Polish
Sealant
Wax
Would that be correct ?
Old 05-05-2012, 08:16 PM   #15
sizemic1
Member#: 270669
2011 WRX Sedan
Stg 2 Phatbotti e-tuned
Looks like a reasonable plan to me.
I'd probably use some dish soap for the initial wash, but it's use is subject to debate.
sizemic1 is offline   Reply With Quote
Old 05-08-2012, 08:06 PM   #16
RedStripe
Member#: 319210
Dark Gray Metallic
Wash
Claybar
Polish
Sealant
Wax
You've got it. But you might want to talk to the dealer about the detail you're ready to skip - you want to be sure they remove any adhesive after pulling the plastic sheeting. It might even make sense to talk to their detailer and kick him $50 to hand-wax before delivery. That ought to avoid swirl marks and still get you the clean/pristine surface you want.
Detail or Somewhere to go for a reall good interior/exterior wash? lazybummm Southern California Impreza Club Forum -- SCIC 8 04-17-2009 06:04 PM
Good day for a wash xBLURRx Member's Car Gallery 6 01-07-2008 07:35 PM
First wash and wax of the toys this year... allsubaru83 Member's Car Gallery 25 05-03-2005 07:25 PM
First wash in months + digi cam for xmas = new pics! porque Member's Car Gallery 2 12-30-2004 05:22 PM
First wash since winter weather chrislehr New England Impreza Club Forum -- NESIC 3 02-23-2003 01:45 AM
