Old 04-30-2012, 09:02 PM   #1
stsdude2
Member#: 307161
2008 wrx
Default Ac compressor gone bad, should i not drive like this?
My AC compressor blew yesterday, the clutch appears to be screwed up in someway and there's a pretty awful but not unbearable whine and occasionally the smell of freon under the hood.
. I think the clutch is bad, I am going to the dealer in the morning but I have things to do tonight that require a car, would it be bad to drive with the AC compressor being junk? My engine and whatnot is under warranty but I'd rather not have it blow up anyway.
It's on an 08 wrx
stsdude2 is offline   Reply With Quote
Old 04-30-2012, 11:00 PM   #2
Thunderpaw
Member#: 242205
2009 wrx
blue
Start your car turn ac on and see what happens when the compressor cycles. Is the belt slipping? You can drive it but that smell is probably the belt burning up and soon to bust. If you're sure that's the problem then cut the belt off and drive it to the dealership. It'll cost you an extra belt. Could take it off but might as well replace it.
Thunderpaw is offline   Reply With Quote
Old 05-01-2012, 05:43 AM   #3
lolol
Member#: 311801
Freon doesn't have smell unless you're sniffing it straight out of the can. Then, it has a weak sweet smell to it.
lolol is offline   Reply With Quote
Old 05-01-2012, 09:50 AM   #4
rkramer
Member#: 118209
2015 WRX Limitec
Cut the belt... You are going to have to replace it anyway, and its a $15 part.
Old 05-01-2012, 10:46 AM   #5
stsdude2
Member#: 307161
2008 wrx
well its going in for a new AC compressor today anyway, I don't know if it would be a good idea to cut the belt I'm pretty sure its belted together with my crankshaft and an idler pulley.
Old 05-01-2012, 10:50 AM   #6
z
Member#: 41762
04 STi
in ur Floriduh
your crankshaft drives it (and in turn spins the compressor) but it's fine to remove. You just won't have working a/c.
Although it may help them in diagnosing that the compressor is indeed bad. Did you determine it was a bad compressor or are you just going in saying "please replace my a/c compressor."?
*i would say it's just as likely it's the idler pulley (tensioner)
z is offline   Reply With Quote
Old 05-01-2012, 12:58 PM   #7
stsdude2
Member#: 307161
2008 wrx
Nah I know its the AC compressor, it's currently being repaired right now, : )
Old 05-25-2012, 05:19 PM   #8
jyoung
Member#: 308554
2005 WRX
Unplug The Compressor
jyoung is offline   Reply With Quote
Old 05-29-2012, 03:11 PM   #9
rkramer
Member#: 118209
2015 WRX Limitec
yep, for future reference though, you can safely cut that belt without issue. In fact you can safely run without ANY of the belts (other than timing belt), for as long as your battery holds out at least. (on a fully charged battery you will get roughly 30 miles or so without an alternator if you conserve electrical power) That is useful to know when you are at the side of the road and you have bearing that went out.
Old 05-31-2012, 09:13 AM   #10
katie785
Member#: 321782
2005 STI
Murdered outttt
good tips, thanks!
katie785 is offline   Reply With Quote
Old 05-31-2012, 10:03 PM   #11
John_The_Ripper
Member#: 321870
2003 Impreza WRX
Platium Silver Metallic
I wouldnt drive it. Dont wanna risk something else breaking until u get the first problem fixed.
John_The_Ripper is offline   Reply With Quote
Old 07-10-2012, 10:54 AM   #12
03STAGE2
Member#: 59465
2003 Bugeye
G8RH8R
If you cut the ac belt the only thing you are going to break is a sweat.
rkramer is correct.
03STAGE2 is offline   Reply With Quote
AC Compressor going bad? Ammata Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-07-2010 07:09 AM
2008 WRX ac compressor goes bad fober Newbies & FAQs 2 05-16-2009 10:40 AM
AC Compressor going bad, I got a ? jpbpro Texas Impreza Club Forum -- TXIC 9 05-28-2006 06:40 AM
should i-club do something like this for the STi? pio!pio! News & Rumors 3 03-18-2002 12:35 PM
Thanks for not driving like crazy people! mad-dog999 New England Impreza Club Forum -- NESIC 2 04-05-2001 11:08 AM
