Old 05-01-2012, 04:36 AM   #1
lolol
Member#: 311801
Default How are those $10 quick drain valves?
I saw them at O'reilleys. Instead of a an external valve, this one opens by pushing in the spout itself and twisting.
They were $9.99 and came in a few different sizes.
How good are these?
lolol is offline   Reply With Quote
Old 05-01-2012, 02:46 PM   #2
JohnM10
Member#: 244231
2006 Impreza 2.5i 5M
Crystal Grey Metallic
Can you link to a picture or an ad?
JohnM10 is offline   Reply With Quote
Old 05-01-2012, 05:32 PM   #3
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
http://www.fumotousa.com/ has epic win. $10 Chinese one....not on my car. Fumoto Valves rock, I've had one since 1000 miles and now have same one at 153,000 miles. ****'s gangsta son!
Old 05-01-2012, 05:44 PM   #4
gpshumway
Member#: 43950
07 WRX LTD Wagon
Satin White Pearl
+1 on Fumoto valves. Mine is 5 yrs old and 40k miles. No leaks.
Some get worried about a random piece of debris knocking it open. Fumoto recommends using a spring hose clamp (5/8"?) as a safety device to prevent this, which I do. It takes the "quick" out of "quick oil drain valve", but I don't mind. I still get to keep my hands clear of boiling hot oil and it's a lot easier to fill the oil sample jar.
gpshumway is offline   Reply With Quote
Old 05-01-2012, 06:03 PM   #5
n2oiroc
Member#: 141952
15 legacy 16 wrx
not to be an uncle scotty, but is it really that hard to remove the drain plug that you guys would buy these things?
n2oiroc is offline   Reply With Quote
Old 05-01-2012, 06:04 PM   #6
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
I have one of these. It's probably my favorite mod of all time.
On my car, sorta. Once I get my drain pan under there it's kind of annoying to manipulate. But with the valve I don't even have to use ramps or a jack or anything. 1 handed oil changes ftw.
Psychoreo is online now   Reply With Quote
Old 05-01-2012, 10:06 PM   #7
gpshumway
Member#: 43950
07 WRX LTD Wagon
Satin White Pearl
Is using the traditional drain plug hard? No, but the drain valve is neither hard to install nor expensive.
I like it for the reasons I stated above, plus I like not having to replace crush washers.
Old 05-01-2012, 11:46 PM   #8
n2oiroc
Member#: 141952
15 legacy 16 wrx
maybe im paranoid (actually i know i am) but i see it as a potential failure point. id be worried about it leaking or some road debris snagging it open.
Old 05-02-2012, 12:05 AM   #9
Psychoreo
Member#: 79643
2015 WRX STI
The only way this thing is getting snagged open is if you hit something hard enough that would've put a hole in your pan anyway.
You have to lift up and rotate the lever to open the valve.
Old 05-02-2012, 09:10 AM   #10
gpshumway
Member#: 43950
07 WRX LTD Wagon
Satin White Pearl
While very rare, it does happen. I believe it happened to Uncle Scotty, he just caught it before the engine was toast.
Like I said above, Fumoto recommends using a hose clip as an additional retainer "For users under extreme conditions", like off road use.
It's right on their front page:
User experience says they're less likely to leak than a crush washer compromised by debris.
I do not have the Fumoto valve on my Honda, which requires an extension for the valve to fit. It sticks out too far from the pan for my comfort. Too easy for some debris to knock the valve and crack the aluminum pan.
Old 05-02-2012, 10:02 AM   #11
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
fumoto valve on mine for about 10 years now, no problems at all. If you get one, just dont get the one with the extra nipple extension for risk of catching something.
There are some other options that don't use levers to consider that have gotten some favorable reviews on the other boards. dorman ez valve and the fram sure drain are popular.
fastnoypi is offline   Reply With Quote
Old 05-02-2012, 10:15 AM   #12
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
Well, if the ****'s gangsta, I guess I have to get one!
Bacon117 is offline   Reply With Quote
Old 05-02-2012, 05:07 PM   #13
billzebub
Member#: 40248
2003 WRX
Midnight Pearl (black)
Time is money. the Fumoto valve + the proper filter wrench have shortened my oil changing time from 30 minutes to ~12.
billzebub is offline   Reply With Quote
Old 05-02-2012, 06:30 PM   #14
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
i love my fumoto. no more oil on hands and the splash that covers my driveway like before. gotta get one for my wifes 2011 forester now. the new fb25 engine takes a f108 fumoto. ours are a f105.
424wrx is offline   Reply With Quote
Old 05-02-2012, 09:44 PM   #15
scarney1988
Member#: 317760
I havent seen this fumoto valve until just a minute ago, and I am going to get one.
scarney1988 is offline   Reply With Quote
Old 05-03-2012, 10:27 AM   #16
JohnM10
Member#: 244231
I have a Fumoto one on my Impreza and one on my wife's Altima. They work great and as I am doing an oil change on my car about every 2 months, it has saved me a lot of time and hassle.
Old 05-03-2012, 11:05 AM   #17
Rodwrx23
Member#: 170948
I've had my fumoto on for about 70K miles without a single problem. Mine has the external valve and I've autocrossed countless times (killed a few cones) without any adverse effects.
Rodwrx23 is offline   Reply With Quote
Old 05-04-2012, 09:45 AM   #18
billzebub
Member#: 40248
2003 WRX
For those that worry over a fumoto valve, I'd warrant that any incident that would bust a fumoto valve would also bust an oil pan.
Old 05-05-2012, 12:56 PM   #19
Ralph47
Member#: 214774
2009 Impreza 2.5i
Dark Grey
Agreed! A bunch of the guys on one of my dodge forums use em and they all love them!
Most are stock height Cummins but there are a few that are off road toys or low riders.
I will be ordering one today if I remember to when I get home
Ralph47 is offline   Reply With Quote
Old 05-05-2012, 01:25 PM   #20
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
If they could only make a fumoto valve for the filter, lol. The filter is the really messy part. Even with the newspaper bag trick, I still hate it. Poking a hole in it can be messy as well.
I've had the fumoto for about ten years with no issues.
garface is offline   Reply With Quote
Old 05-09-2012, 02:13 AM   #21
EdHilario
Member#: 137398
2004 Impreza 2.5RS
I <3 my Fumoto valve!
EdHilario is offline   Reply With Quote
Old 05-09-2012, 01:52 PM   #22
Haunty
Member#: 319378
2012 2.0i Sport Ltd.
Satin White Pearl
Interesting, I might get me one. Is there a possibility of it voiding warranty? Maybe in a specific case where the oil drains out while driving...
Haunty is offline   Reply With Quote
Old 05-09-2012, 01:58 PM   #23
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
If there is any doubt in your mind, don't do it. It's not really THAT much easier than pulling the drain plug. Less likely to make a mess, but that's it.
Old 05-09-2012, 02:17 PM   #24
Ralph47
Member#: 214774
2009 Impreza 2.5i
Dark Grey
As stated above they offer an option to make it more "secure" so there is no way the valve can open accidentally while you drive. It makes it a little longer to do the oil change BUT it is still cleaner and easier than the drain plug.
Old 05-09-2012, 08:52 PM   #25
scarney1988
Member#: 317760
You guys order your qwik valve direct or buy in a store?
FS : Socal F-108 Fumoto quick drain valve OMG AWD Engine/Power/Exhaust 3 01-24-2011 11:20 PM
FS : F-108 Fumoto quick drain valve OMG AWD SCIC Private Classifieds 4 01-24-2011 11:20 PM
Radiator quick drain valve? Thug Nasty Built Motor Discussion 11 11-07-2009 02:24 PM
3 day sale: JDM Fumoto Engine Oil Drain Valves for QUICK oil changes King Of Imports Engine/Power/Exhaust 15 05-31-2005 10:43 AM
so how are the top 10 posters on nabisco wrxtuner02 Off-Topic 33 08-07-2004 03:07 PM
