Old 05-01-2012, 08:47 PM   #1
kyle91
Member#: 287383
2008 WRX
Grey
Default GFB Bov
ok so i installed a full adjustable bov. i tried running full atmso until my car just got a check engine light. does running full hurt my car if so is it just safer to run 50/50? i have an 08 wrx.
kyle91 is offline   Reply With Quote
Old 05-01-2012, 09:00 PM   #2
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Running it anything but full recirc will hurt your car. Why did you replace it? Stock one leaking? Or just to be (c/t)ool? Go back to the stocker if you can, if not, run 50/50 and I'd recommend buying the forge bypass valve.
drewvdw is offline   Reply With Quote
Old 05-01-2012, 09:06 PM   #3
kyle91
Member#: 287383
2008 WRX
Grey
no stock one runs great, im just pushing a little more than stock psi. im at 16psi. but i wanted the sound which was a bad idea lucky it didnt do a lot of harm to my car but thank you for the help, im going to try an sell this one an get the forge.
Old 05-01-2012, 09:07 PM   #4
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
I'm going to take a WILD guess and say you didn't research this product before buying did you?
Full recirculation is the only way to go. No questions about it.
Old 05-01-2012, 09:12 PM   #5
kyle91
Member#: 287383
2008 WRX
Grey
I read the post about BOV on here a few times before i bought it, but i didnt look into the brand so much. the good news is I just ordered the forge bypass valve.
Old 05-01-2012, 09:34 PM   #6
quoiasdaddy
Member#: 147711
2002 WRX/Stg 2
Here it is again ANOTHER BOV problem. The stock one has worked fine for me for 138k, I would never put one on my car simply because they just seem to cause problems for so many people and that sucks. I have seen countless threads just like this.
quoiasdaddy is offline   Reply With Quote
Old 05-01-2012, 10:05 PM   #7
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
That's not good news. Cancel your order. Install OEM valve. Smoke cigarettes. That's exactly what you should do.
Old 05-01-2012, 10:09 PM   #8
liv4psi
Member#: 206505
'04 STI
JBP, 360whp 355tq @18psi
Made me
liv4psi is offline   Reply With Quote
Old 05-01-2012, 10:10 PM   #9
1SloWag
Member#: 256075
2014 SWP WRX Sedan
But my car won't go PSSH like all the cool kids
1SloWag is offline   Reply With Quote
Old 05-01-2012, 10:13 PM   #10
liner
Member#: 303231
2008 WRX
Dark Metallic Grey
If you have 138k miles, I'm willing to bet its pre 08? The 08+ valves are known to leak at boost as little as 18psi. Granted OPs at 16 and is reporting no issues with the stocker, just sayin.
Personally id keep the stock valve until you start having issues, then switch it for the forg e
liner is offline   Reply With Quote
Old 05-01-2012, 10:19 PM   #11
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Its just a matter of time until the plastic piece of **** starts failing anyways, what's wrong with being prepared? Are you forgetting the 08+ WRXs have the leaky plastic bpv's?
Old 05-01-2012, 10:21 PM   #12
liner
Member#: 303231
2008 WRX
Dark Metallic Grey
Old 05-01-2012, 11:18 PM   #13
quoiasdaddy
Member#: 147711
2002 WRX/Stg 2
Yea I have an 02 WRX, I never heard about a leak problem with the 08. Thats unfortunate tho that they have that problem, seems like an issue for the almighty SOA! Why would they make that out of plastic in the first place? It seems like a problem to me but it doesn't suprise me with Subaru, It's like why would you put a cat in the upipe of the older WRXs?
Old 05-01-2012, 11:28 PM   #14
BlackJavaPearl04
Member#: 198522
98 LGT Limited
00 LGT -WRX swap
yes it does...do not run full atmosphere unless your tuned respectively for that setup. You may run at most a 50/50.
Everytime a fully atmospheric BOV dumps on a stock setup...it causes the motor to run extremely rich as your still sucking in air from the turbo and the MAF is measuring that air and thinks it is to be used when its actually being dumped. So now your pissing fuel into the motor that isnt being combusted so it washes down your cylinder bores, chews up the rings and thins out your oil. Whereas a recirculated Bypass valve does just as its name suggests ...recircs the air in a loop until the air is needed again....this way it is not sucking in anymore metered air (or if it is, it is very minimal) through the intake until the throttle is opened again.
BlackJavaPearl04 is offline   Reply With Quote
Old 05-02-2012, 12:07 AM   #15
liner
Member#: 303231
2008 WRX
Dark Metallic Grey
My thoughts exactly!
Old 05-02-2012, 06:30 AM   #16
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Weed will make him smarter.
i_c_the_light is offline   Reply With Quote
Old 05-02-2012, 02:30 PM   #17
brutnus
Member#: 257195
2004 WRX
2.1L
brutnus is offline   Reply With Quote
Old 05-02-2012, 03:16 PM   #18
GFB
Member#: 281725
2006 STI
For a second I thought someone wrote a thread about a BOV that I don't have.
GFB is offline   Reply With Quote
Old 05-02-2012, 03:21 PM   #19
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
You can't tune for an atmo valve.
Old 05-02-2012, 03:24 PM   #20
RoadKillDMD
Member#: 284792
2011 STI
Blurple
RoadKillDMD is offline   Reply With Quote
Old 05-03-2012, 03:45 AM   #21
Rally Snow
Member#: 193614
02 Aspen WRX
need blinker fluid change
Here I saved you some time read it again.........................
http://forums.nasioc.com/forums/show....php?t=1602235
Rally Snow is offline   Reply With Quote
Old 05-03-2012, 04:08 AM   #22
GhostSenshi
Member#: 279449
2004 8.78 E/T WRX
Platinum Silver
just a side note, you really don't need to replace the stocker unless you are pushing more than 20psi... 16psi is pretty much stock.
I'm putting out max of 20, tapper to about 18.7
No leaks, no issue with stock bpv.
GhostSenshi is offline   Reply With Quote
Old 05-03-2012, 08:42 AM   #23
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
^^^not an 08+ plastic pos. they've been known to leak even at stock boost pressures.
Old 05-03-2012, 09:19 AM   #24
Tarpley219
Member#: 297676
2009 360whp WRX
E85
My 09 starting leaking so I just bought a Tial QR, works great. If you want the psshhh noise just get a CAI. It sounds ten time better than a stupid squeaking noise anyway.
Tarpley219 is offline   Reply With Quote
Old 05-03-2012, 09:23 AM   #25
visualsinz
Member#: 160900
2004 WRX STI
JBP
I've ran (and I'm still running) GFB 50/50's for several years on several cars without incident.
visualsinz is offline   Reply With Quote
NJ: HKS BOV & GFB BOV RUBEN Private 'For Sale' Classifieds 0 08-19-2004 12:28 PM
Next to new GFB BOV and Blitz BOV silversubewrx Private 'For Sale' Classifieds 0 02-02-2004 08:28 PM
WTT: my GFB BOV for RFL BOV infinFX Private 'For Sale' Classifieds 0 12-01-2003 02:26 AM
wtt hks bov for gfb bov blk rix wagon Bay Area Impreza Club Forum -- BAIC 12 08-18-2003 01:37 PM
Want to trade: GFB BOV for TXS RFL BOV whitehill North West Impreza Club Forum -- NWIC 0 05-02-2003 03:21 AM
