Old 05-02-2012, 11:37 AM   #1
Donzo
Member#: 95337
2012 Jeep Overland
Default Reverse lockout rattle after sts install
I installed a Kartboy 6MT short throw shifter in my 2008 Spec.B over the weekend and now I have a very annoying rattle from the reverse lockout.
I saw a thread where someone used Dynamat to stop the rattling but I don't have any of that. I'm thinking I could use electrical tape but read another thread where someone claimed to use that and it didn't help.
Has anyone else fixed this issue?
Donzo is offline   Reply With Quote
Old 05-02-2012, 12:01 PM   #2
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Did adjust the cable. The adjuster screw is mounted to the bracket at the front of the linkage and also there is a metal tab on the linkage which holds the cable in place just might need some adjusting
trev762 is offline   Reply With Quote
Old 05-02-2012, 05:08 PM   #3
Member#: 67
1999 Outlasting
the competition.
This
Also make sure you swapped over the rubber donut on the bottom of the OE shifter. Along with a nice coating of grease on the shaft
Old 06-26-2013, 12:43 AM   #4
gregnauman
Member#: 97453
2005 Outback XT
Atlantic Blue
gregnauman is offline   Reply With Quote
Rattling after Strut install? MorallyBass Brakes, Steering & Suspension 7 02-24-2013 07:09 PM
Rattling After Up-pipe Install kfckrew Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-24-2008 03:05 PM
Rattle after DP install (Video) djburn1200 Texas Impreza Club Forum -- TXIC 8 05-10-2008 07:59 PM
Buzz/Slight Rattle after TBE installed ajshades Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-02-2008 01:20 PM
