Old 05-02-2012, 12:28 PM   #1
leftwing12
Member#: 308723
06 impreza
black
Exclamation AC Discharge hose help ASAP
I just had my new discharge hose shipped, but debating on bringing it to the shop to get (if needed) excess air, debris that may have gone into the broken hose...
Can i do this myself and then recharge the freon? Cause when I had the shop recharge it about a month ago, the freon ran out in about 4 days. Now its blowing hot/ warm.
leftwing12 is offline   Reply With Quote
Old 05-04-2012, 09:48 AM   #2
billzebub
Member#: 40248
2003 WRX
Midnight Pearl (black)
If you replace the O-rings and recharge it should be good unless there's crap in the system.
I swapped a compressor a few years ago, changed out the o-rings, and charged with the gas that has oil in it just to be safe. Cold air for teh last 2 Summers!
billzebub is offline   Reply With Quote
Old 05-05-2012, 08:36 PM   #3
Elbert Bass
Member#: 283429
You need to have the system evacuated (have a vacuum pulled) before you charge it. Air mixed with refrigerant condenses moisture and decreases the ability of the refrigerant to do it's job. That moisture over time will damage the system.
I would suggest replacing the the suction line O ring at the compressor as well - both the compressor O rings harden and seep with time. Your hose should come with new O rings so you shouldn't need the high side ring.
Elbert Bass is offline   Reply With Quote
WTB : Discharge Hose 02/04 WRX 2xJeff NWIC Private Classifieds 2 08-05-2010 01:24 PM
WTB: APS Turbo Compressor Discharge Hose 1gcrazy Private 'Wanted' Classifieds 11 02-20-2010 11:34 PM
A/C discharge hose thinger deebo General Community 2 06-17-2004 07:16 PM
AC Discharge AK'S REX Service & Maintenance 2 02-16-2004 01:17 AM
BOV discharge hose dunk Mid Atlantic Impreza Club -- MAIC 16 02-12-2004 03:09 PM
