Old 05-02-2012, 10:04 PM   #1
sedonarex13
Member#: 313573
06 wrx
Default 03 wrx fans not kicking on
03 wrx just did timing belt, water pump install put in new thermostat.... dont think the fans have kicked on since install and top radiator hose is realy hard like full of pressure when warm.. should it have that much pressure build up. the temp gauge stays at normal reading but ap says temp is around 185
sedonarex13 is offline   Reply With Quote
Old 05-02-2012, 10:16 PM   #2
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
185 is actually running cool for coolant temp. I don't think anything is wrong, because if the fans weren't working/system not working you would be over heating. Did you make sure to plug in the plugs completely?
Old 05-02-2012, 10:26 PM   #3
Thunderpaw
Member#: 242205
2009 wrx
blue
Run the car at idle for a while and monitor the temp gauge. If they aren't working temp gauge will creep to red. Pop the hood and see if they turn on. They will run then turn off. I believe they'll also turn on when a/c is on. Check fan fuse and connections
Thunderpaw is offline   Reply With Quote
Old 05-02-2012, 10:28 PM   #4
ThaGriff
Member#: 306534
2003 WRX
Kick the AC on, if the fans still don't spin then you may have an issue. I replaced a radiator and had the same thing, no fans but I wasn't running hot. Thumbed through the manual and found that the fans will not spin (under normal conditions) without the AC on.
ThaGriff is offline   Reply With Quote
Old 05-02-2012, 10:43 PM   #5
Thunderpaw
Member#: 242205
2009 wrx
blue
Not sure this is possible in a wrx but can you replace thermostat upside down? I know in older cars it was possible. In such case the themo wouldn't open up
Old 05-02-2012, 10:44 PM   #6
sedonarex13
Member#: 313573
06 wrx
yea the fans are plugged up it was a 170 thermostat that i put in
Old 05-02-2012, 10:46 PM   #7
sedonarex13
Member#: 313573
06 wrx
pretty sure it will only go in one way i mad sure it was in there right tho
Old 05-02-2012, 10:51 PM   #8
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
There is a small relief on the top of the thermostat that should be positioned at 12 o clock in case of a fail. But that won't affect the car during normal operation.
Old 05-03-2012, 01:15 PM   #9
snobordboi
Member#: 149130
2002 WRB WRX
VF39 Brembos etc
If the thermostat is a 170, the car may be cooling itself well enough without the fans running, so that the fan switch never sees temps high enough to turn them on.
Usually I would suggest to make sure the system is well bled, but if there are air bubbles it would usually get to a high temp quickyl, and then if the fans weren't coming on it would be a concern.
Since this isn't an old V8 that will make some more power when cooler, why did you go a lower temp thermostat? On a modern fuel injection car like this, you may not even be running in the right temp range for the ecu to be truely happy, and if the car still thinks that it is warming up, it will be dumping excess fuel in, actually wasting gas and making the car run rich i.e. slower.
snobordboi is offline   Reply With Quote
Old 05-06-2012, 10:20 PM   #10
sedonarex13
Member#: 313573
06 wrx
i honestly just went to a parts store and got the first thermostat they gave me but after letting the car sit for 2 days i pulled the radiator cap off and quite a bit of coolant came out
Old 05-06-2012, 10:25 PM   #11
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
Thats more of a sign of overfilling the system. A themrostat shouldn't make more coolant come out of anything.
Old 05-06-2012, 10:51 PM   #12
sedonarex13
Member#: 313573
06 wrx
your right but an air pocket would make it do that could it not?
Old 05-06-2012, 10:53 PM   #13
sedonarex13
Member#: 313573
06 wrx
i have no a/c it has been deleted
Old 04-23-2013, 12:08 PM   #14
ilgdrummer
Member#: 28364
2004 Wagon STI
Java Black
Bumping an old thread.
Sedonarex13 did you ever resolve this issue? I'm having the exact same problem. I've recently replaced the same parts. Fan's won't kick on and I have deleted the A/C system as well. Please update.
ilgdrummer is offline   Reply With Quote
Old 04-23-2013, 10:51 PM   #15
sedonarex13
Member#: 313573
06 wrx
The car was just never getting hot enough for them to come on i put a oem thermostat in and all was good. The fans would kick on around 208 be sure and check your fuses there should be one for each fan.
Old 04-23-2013, 11:02 PM   #16
ronnyyun
Member#: 354403
ronnyyun is offline   Reply With Quote
Old 04-24-2013, 05:54 AM   #17
Nikryj
Member#: 346659
2003 WRX
Hell, my car runs at 195-205. The fans only kick on around 198-200.
Nikryj is offline   Reply With Quote
Old 04-24-2013, 07:54 AM   #18
sedonarex13
Member#: 313573
06 wrx
Thats about right
Old 04-24-2013, 12:59 PM   #19
ilgdrummer
Member#: 28364
2004 Wagon STI
Java Black
Thanks, I'll go with an OEM thermostat then. I have one from Autozone...
Old 04-24-2013, 02:06 PM   #20
575rider
Member#: 112024
03 hybrid 6spd wgn
Santa Cruz Bronson-Carbon
That will be enjoyable for summer in NC, hope the 06 is your dd.
575rider is offline   Reply With Quote
Old 04-25-2013, 06:45 PM   #21
sedonarex13
Member#: 313573
06 wrx
Yea haha i sold that car my 06 is my only suby, hell it dosnt get that hot were im from, plus im used to it ive only owned one car that had ac
A/C compressor and fan not kicking on after engine rebuild/install dictoresno Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-05-2012 08:27 PM
06 wrx - fans should kick on at what temp? aerosaaber Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 10-12-2011 09:58 PM
AC condenser fan not kicking on. :mad: Strider Off-Topic 108 09-01-2010 04:58 PM
fans dont kick on DUFFMANAUDIO Service & Maintenance 2 06-05-2007 01:51 PM
Radiator fans wont kick on chokin Service & Maintenance 8 04-08-2007 12:58 AM
