Old 05-02-2012, 11:21 PM   #1
WRXineohP
Member#: 305447
Default Rotella T6...what is the fuss about?
So I was thinking of doing an oil change tomorrow after my car gets tuned.
I have a 2010 WRX with:
Invidia Turbo Back exhaust
Grimmspeed Up-pipe with 38mm Tial EWG
Grimmspeed EBCS
AVO TMIC Intercooler
Cobb SF Ram Intake
One Step Colder plugs
I have always ran Mobil One Synthetic but almost killed the motor when it sucked all my oil dry in one month...
Since then I have had the car in and out of the garage fixing things and finally...fingers crossed... might have it running again...
So whats the fuss with Rotella T6? I thought it was for diesel cars? and what thickness would you run? and I ran 138 and 132 across the boards on a compression test...might this improve the next compression test I do?
WRXineohP is offline   Reply With Quote
Old 05-02-2012, 11:39 PM   #2
jrodm12
Member#: 296705
05 STI
Mobil 1 sheers down pretty quick. The t6 has good uoa and doesnt sheer down nearly as fast as mobil1.
jrodm12 is offline   Reply With Quote
Old 05-02-2012, 11:41 PM   #3
Zaider
Member#: 154281
2002 V7 EJ207 Dom1.5
MBP
Rotella has proven time and time again that it does the job at a lower cost. Thats why
Zaider is offline   Reply With Quote
Old 05-02-2012, 11:54 PM   #4
kingme
Member#: 280943
'11 WRX
M1 0W-40 is a good choice. M1 5W-30 is the problem child in the EJ motor.
Oh and, ib4 d00000000d
kingme is offline   Reply With Quote
Old 05-03-2012, 12:03 AM   #5
C4pt Insano
Member#: 290990
2011 WRX Sedan
I've heard sooo many different opinions and recommendations on oil my head hurts trying to think of what to use on my next oil change. I've decided on the normal subaru filter and am up in the air on whether or not to use one of those quick drain plugs. Beyond that I've just been using subaru 5w-30 synthetic until I figure it out, changing every 4 months/3000 miles in case it sheers quickly. Is rotella really the only go to? Does using the 5w-40 have any negatives as oppose to 5w-30? What makes it made for diesels but everyone uses it for our gas engines? I plan on using it from now on but I just dont exactly know why its best exactly, other than people say it is. Thanks
C4pt Insano is offline   Reply With Quote
Old 05-03-2012, 12:27 AM   #6
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
T6 or german castrol 0w40. That's what I've always heard as best for our engines.
drewvdw is offline   Reply With Quote
Old 05-03-2012, 12:50 AM   #7
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Dude there are threads everywhere about it. Here, IWSTI, bobistheoilguy.com/forums
aboothman is offline   Reply With Quote
Old 05-03-2012, 07:37 AM   #8
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
T6 is cheap for what it does and u can find it pretty much everywhere. But on the other hand it is designed for diesel engines so with high solvents not sure what the long term effects will be on the Subaru motors that's why I use motul 5/40 which is a group 5 motor oil
trev762 is offline   Reply With Quote
Old 05-03-2012, 08:05 AM   #9
bluesubie
Member#: 767
04 FXT
All you have to do is go to the Service and Maintenance forum and look at the good used oil analyses on it. Some up to around 7k miles on the oil. If there's a negative on about any diesel oil, it's that they do not have as high as a level of Friction Modifiers (good for turbo spool, engine response, and better mpg's). Although, I do not know what the actual difference is.
It is a mixed fleet gas/diesel oil and meets API SM specs so it is fine for cars. MOST Energy/Resource Conserving oils will shear out of grade as they are pretty much designed to do for fuel economy. There are a few exceptions, like driving mainly highway miles, easy driving, etc. There's a recent analysis on Pennzoil Platinum in the Service forum where it stayed in grade. It may be the easy conditions or it could also be that the new GF5 oils are improving with respect to shear stability, although that is not a requirement for GF5.
The only Motul that uses Group V base stocks is the 300V line and Grouo IV PAO's are mixed in as well.
-Dennis
Old 05-03-2012, 08:43 AM   #10
jay25RS
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
I've had great UOA's on T6 in my 2006 WRX, 2010 WRX, and now in my STI. Although, with that being said, I am going to be switching to ENEOS 5w-30 and giving that a try. Seems to hold up very well from seeing other UOA's and cost only a $1 or $2 more per 4 quart bottle. Readily available at NAPA too!
jay25RS is offline   Reply With Quote
Old 05-03-2012, 09:01 AM   #11
skep18
Member#: 214971
2014 WRX
Been running T6 on my car for years. No issues. Just as a testimonial.
skep18 is offline   Reply With Quote
Old 05-03-2012, 09:09 AM   #12
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
GC is 0w30, however, it is very thick w30, almost w40. But on the bottle, its w30
Old 05-03-2012, 10:03 AM   #13
CobbsSTI
Member#: 245242
2005 STI
E85 Power
I've been running castrol edge 5-30 in my STI with no problems at all, it retains horse power 60% longer than other synthetics and I've noticed far less oil consuming hardly any at all and I'm running the Crawford AOS that seems as well. But pretty much all oils you will see some consuming of oil.
CobbsSTI is offline   Reply With Quote
Old 05-03-2012, 10:25 AM   #14
b1aze
Member#: 284003
2010 Alpine 135i
wuddafuk?
b1aze is offline   Reply With Quote
Old 05-03-2012, 10:33 AM   #15
WRXLTD
Member#: 136314
2014 Grand Cherokee
I've been running castrol edge 5-30 in my STI with no problems at all, it retains horse power 60% longer than other synthetics...
Do you mean the castrol stays at 30w 60% longer than other "Energy Conservation" oils?
WRXLTD is offline   Reply With Quote
Old 05-03-2012, 10:50 AM   #16
WMCCook29
Member#: 152685
2016 Forester XT
T6 only comes in 5w40.
Are you asking if changing oil brand/weight will improve your compression results? If so, oil has nothing to do with compression results.
WMCCook29 is offline   Reply With Quote
Old 05-03-2012, 03:03 PM   #17
s2ktosti
Member#: 70151
2011 WRX Limited
This statement makes no sense.
s2ktosti is offline   Reply With Quote
Old 05-03-2012, 05:52 PM   #18
bluesubie
Member#: 767
04 FXT
Possibly not in the OP's 2010, but thicker oils can improve compression in worn engines.
Certainly engines that have experienced significant ring and liner wear benefit from thicker oils. Thicker oil use results in compression increases, performance improvements and reduced oil consumption.
http://www.machinerylubrication.com/Read/518/motor-oils
-Dennis
Old 05-03-2012, 06:04 PM   #19
sc00ter
Member#: 117767
2015 WRX
CWP
Originally Posted by b1aze View Post
wuddafuk?
This made me LOL at work. Thanks ***hole.
sc00ter is offline   Reply With Quote
Old 05-04-2012, 08:02 AM   #20
WMCCook29
Member#: 152685
2016 Forester XT
-Dennis
Thanks for the clarification.
Old 05-04-2012, 02:22 PM   #21
my name is joe
Member#: 171412
I'm glad someone knows how to read a label on the bottle
my name is joe is offline   Reply With Quote
Old 05-04-2012, 02:34 PM   #22
ManualOverAuto
Member#: 304662
2001 Impreza L coupe
Sedona red Pearl
For ****s and giggles I'm going to put some in my old yahama ttr 90 bike today. People say 10w40 is good weight, so t6 will be sufficient.
I do like telling people that I put diesel truck oil in my little 4 cylinder car, just to see their reaction, which is usually confusion.
ManualOverAuto is offline   Reply With Quote
Old 05-04-2012, 02:48 PM   #23
ChopstickHero
Member#: 191525
2003 WRX Wagon
I've been reading up on oil threads and wanted to try the RT6 b/c of all the good things I hear. however, regular price RT6 in Toronto is unfortunately $43+tax for a 5L jug (unless it's on sale at about $30). I was about to pick some up to try, but couldn't ignore the Pennzoil Platinum which was selling at 50% off (5L for only $23) and picked up two jugs. I'll try Rotella another time when it's on sale.
ChopstickHero is offline   Reply With Quote
Old 05-04-2012, 03:39 PM   #24
ManualOverAuto
Member#: 304662
Sedona red Pearl
That's crazy expensive! I got a gallon jug of T6 for $21 at Walmart.
Old 05-04-2012, 05:43 PM   #25
bluesubie
Member#: 767
04 FXT
But how much do you spend on one tank of gas and how many miles does it last?
-Dennis
Now I know what all the fuss is about. NWWagon Off-Topic 16 06-30-2006 01:10 AM
steering rack bushing install...whats the fuss about beauhawk Brakes, Steering & Suspension 18 07-25-2005 08:31 AM
Dunno what all the fuss is about DDMan Car Part Reviews 5 03-01-2002 10:53 AM
What's the fuss about Prodrive P7s?? Ginseng Brakes, Steering & Suspension 25 08-11-2001 12:50 PM
