Old 05-03-2012, 02:54 AM   #1
h1gh
Member#: 283363
07 STi
Default does the dealership use gate's timing belts?
my dealership is having a timing belt change special but im wondering if they use gates belts and give you new thremo stats and adjusters? Id rather get it done at my indep shop but the difference is 400 bucks where the dealership is cheaper just wondering what the difference is
h1gh is offline   Reply With Quote
Old 05-03-2012, 10:12 AM   #2
scarney1988
Member#: 317760
Call them and ask specifically what is included (ad should stipulate that if there is one). Also, when you sign the work order, make sure it specifically stipulates to replace the parts you want so that you compare apple to apples. And then take a look to make sure the parts were replaced (the ones you can verify). Hope that helps. Good luck.
scarney1988 is offline   Reply With Quote
Old 05-03-2012, 10:18 AM   #3
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
most dealers will use genuine OEM parts unless specified. Call them to find out.
fastnoypi is offline   Reply With Quote
Old 05-03-2012, 02:52 PM   #4
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
When you buy the belt from a Subaru dealership and remove the belt from the Subaru box, it will have the word Gates printed all over it. OEM Subaru = Gates. I know this for fact as that's exactly what I did 2 years ago. If your dealer doesn't use OEM, then who knows, but 99% of them do.
Old 05-03-2012, 04:17 PM   #5
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
The dealer does not replace anything except the belt, unless you ask them to, or a pulley is bad. The other shop might be quoting you to do everything, cam seals, pulleys, etc.
Bacon117 is offline   Reply With Quote
Old 05-04-2012, 12:38 AM   #6
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
When I was working at a dealership we replaced the belt, the cam/crank seals, and anything else that was showing signs of failure (but those would be extra).
CosmoTheCat is offline   Reply With Quote
Old 05-04-2012, 08:52 AM   #7
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
Was that automatic (or automatically offered), or just at customer request? The two dealers near me said they just slap a belt on it and call it good. Unless I specifically ask them to do it.
Anyone used the full Gate's timing belt kit? EPrex Service & Maintenance 4 07-24-2010 11:30 PM
WTB/WTT : used/old timing belt sizzflair Tri-State Area Private Classifieds 6 07-13-2010 10:53 AM
FS : used WRX timing belt/STI pistons ice.xiv Engine/Power/Exhaust 1 06-20-2010 03:52 PM
used oem timing belt with less than 5k miles on it TopEndPull Engine/Power/Exhaust 2 08-11-2009 01:40 PM
Does a sticker on a timing belt cover mean it has been changed? kumanchu Service & Maintenance 4 04-28-2007 09:31 AM
