Mid Atlantic Impreza Club
View Poll Results: Where should we meet around Glen Burnie?
Marley Station 9 34.62%
Quarterfield Shopping Center 2 7.69%
Mission BBQ 9 34.62%
Other 6 23.08%
Voters: 26. You may not vote on this poll
Old 01-16-2013, 04:45 PM   #1251
scobbie-ts
Member#: 270674
2003 Impreza TS
BRP
Originally Posted by lilblue619 View Post
Why's he selling it?
Says he doesnt need it. Its an extra lol.
scobbie-ts is offline   Reply With Quote
Old 01-16-2013, 04:53 PM   #1252
lilblue619
Member#: 288292
2004 sti
wrb. the blue one.
Sounds like nothing was missed
lilblue619 is offline   Reply With Quote
Old 01-16-2013, 05:06 PM   #1253
scobbie-ts
Member#: 270674
2003 Impreza TS
BRP
yeah I wasn't thinking so either. I'd still need the drivetrain but he said he has all the parts I'll need minus a tranny, wiring harness, and intake manifold lying around. I could pick up those for 1000 I'm thinking. I would like to get the PPG geared wrx tranny, but I don't have enough money for both. Out of the two options I'd rather go with the upgraded engine and maybe find a 6 speed to drop in since it would be cheaper than the ppg geared 5MT. I still have to look into a 6 speed setup though. Which one you think is the better pick?
Old 01-16-2013, 05:13 PM   #1254
03Rextacy
Member#: 239497
2003 Impreza WRX
The Guys that have gone from ppg to 6 speed say they don't regret it. You're in a spot where you have the choice to do it because everything is being changed anyway. Go 6 spd, dccd, the whole nine; you'll need the rear diff as well.
I'm personally going for PPG, just to annoy my neighbors that much more
03Rextacy is offline   Reply With Quote
Old 01-16-2013, 05:30 PM   #1255
lilblue619
Member#: 288292
2004 sti
wrb. the blue one.
I just want some cams. Ill go ppg when that day comes hopefully not soon.
Old 01-16-2013, 05:31 PM   #1256
RossLH
Member#: 147839
2003 WRX
SRP
yeah that's what I hear. That's why I was thinking about getting the PPG tranny. I hear that the STI tranny's are very strong, but because of the gearing and 1 less gear the ppg 5MT will be faster and have a lower idle at cruising speeds(for mpg considerations lol). Plus I read that there's more of a wiring headache with the 6 speed since it has the adjustable gearing thingy where you can change it from S to S# etc. You have any experience doing that kind of work?
I just said 06 because I didn't want to put 04-07. I was lazy lol.
Get a 6-speed, wire in an aftermarket DCCD controller, call it a day. 6-speeds and 5-speeds are entirely different animals, and after dealing with both built 5-speeds and a 6-speed, I will never recommend a built 5-speed again.
RossLH is offline   Reply With Quote
Old 01-16-2013, 05:41 PM   #1257
scobbie-ts
Member#: 270674
2003 Impreza TS
BRP
Lol let em listen to it whine huh?
Old 01-16-2013, 05:48 PM   #1258
scobbie-ts
Member#: 270674
2003 Impreza TS
BRP
Yeah that's what I'm thinking too. Now I just have to find one lol. Still debating whether 7K is too much for his set up or not though. Good thing is I would never have to touch the internals if I bought it. Bad thing is it's 7K lol. And most of the STI tranny swap components are running around 4K altogether. BUT that is a mean setup for 12K. Including FMIC or new hood, new wheels, and a tune. Gahh choices lol.
Old 01-16-2013, 06:10 PM   #1259
scobbie-ts
Member#: 270674
2003 Impreza TS
BRP
go a quote from ECS too. This is what they have in it.
ECS Performance 2.5L STi Motor Swap 12,000.00
-Parts Included:
- ENGINE
* Complete Motor
* Complete Electrical Harness
* Engine Control Unit (ECU)
* Fuel Pump Sending Unit
* Engine Cradle with Power Steering Rack
* OEM Front Sway Bar (while supplies last)
* OEM Exhaust with Oxygen Sensor (while supplies last)
- TRANSMISSION
* Complete Transmission
* Drive Shaft
* Trans mount w/ Sub Frame
* Shifter Linkage
* Front Axles
* Fly Wheel w/ Clutch
* DCCD Parts
- REAR END
* Complete Rear Sub Frame
* Rear Diff w/ Axles
* Rear Spindles
* All Arms (Lateral & trailing)
* ABS/ E Brake Cables
* Sway Bar w/ Links
- BRAKES
* Sti Brembo Calipers
* Brake Rotors (USED)
* Brake Pads (USED)
* Brackets
* Brake Lines
* Hardware
- FRONT SUSPENSION
* Front Lower Arms
* Both Front Spindles w/ Hubs
ECS Motor Swap / Flat-Rate Labor Service 3,550.00
* Electrical Wiring Harness Merge
* Removal of the Original Motor and Installation of new Powerplant
DCCD-Pro DCCD Control Kit 325.00
ACT Street Performance Clutch Kit 650.00
Subcontracted Service 325.00
* Air Conditioning Recharge
* Suspension Alignment
* Flywheel Resurfacing for Clutch Replacement
Miscellaneous Parts 100.00
* Hardware, Nuts, Bolts, Studs and Screws
* Gaskets and Seals
Fluid Replacement 60.00
* 50/50 Premixed Antifreeze Coolant (2 Gallons)
* 5W30 Conventional Motor Oil (5 qt) w/ Napa Gold Oil Filter
Environmental Waste Disposal Fees 5.00
Shipping Freight Costs 400.00
Sales Tax - State of Connecticut 6.00% 1,020.60
Total $18,435.60
Damn lol. thought ya'll would be interested in that.
Old 01-16-2013, 06:28 PM   #1260
03Rextacy
Member#: 239497
2003 Impreza WRX
Not necessarily true. Keep that in mind. It's built, yes. Meant to sustain a higher horsepower, but, there's still plenty, if not more that can go wrong. At this point, you should know that everything is a gamble when you venture from stock. Sad, but true.
Old 01-16-2013, 08:27 PM   #1261
scobbie-ts
Member#: 270674
2003 Impreza TS
BRP
Yeah that's true. I guess it really depends on the quality of the work. IDK though. the more I think about it the more I think I can't spend 7K on the engine with all the other parts I need to do the swap. I REAAALLLY Want to, but i don't think it's possible to stay in my budget with that engine.
Old 01-16-2013, 10:06 PM   #1262
2.5RyanS
Member#: 288565
1998 WRX Swapped RS
Acadia Green
Well damn i missed alot lol.
ECS is a great swapping company, my friend got his 01 rs wrx swapped there. Had it done within a month, went back and picked it up. He loved it, had slim to none in problems, but hes selling it now
All of these sound good, ECS' price doesnt include the swap just all the parts though right?
If so that sounds really high lol.
2.5RyanS is offline   Reply With Quote
Old 01-16-2013, 10:10 PM   #1263
2.5RyanS
Member#: 288565
1998 WRX Swapped RS
Acadia Green
Also, nothing too new, other than speakers and a wrx steering wheel lol. Looking to get my coilovers this summer though
Old 01-16-2013, 11:11 PM   #1264
scobbie-ts
Member#: 270674
2003 Impreza TS
BRP
ECS's price includes everything. Including all the install, wiring and a tune. For just the parts it's 12,000. The work and fluids and stuff is the extra 6.
oh and WHAT HAPPENED TO YOUR PURPLE RIMS YOU FOOL!!!! IT DOESN't LOOK THE SAME WITHOUT THEM. Just sayin. Can I haz them if you just decided not to put them on????
Old 01-16-2013, 11:52 PM   #1265
2.5RyanS
Member#: 288565
1998 WRX Swapped RS
Acadia Green
Then 18isnt that bad, if they are all low milehe parts that is haha.
Off for winter, dont want the salt to mess em up
Theyll be back on in march though hahaha.
Old 01-17-2013, 07:22 AM   #1266
03Rextacy
Member#: 239497
2003 Impreza WRX
Reading back some... If you went Fmic, you wouldn't need to change your hood. Keep it stealth. But it's personal preference. Just don't go carbon fiber. I think yours is steel though correct? Wrx hoods are aluminum, so there's weight to figure in as well. But there are plenty of guys that have gone front mount and are looking to trade for an RS hood. There's more deals out there than you think. Just finding the right ones at the right time.
Old 01-17-2013, 07:33 AM   #1267
scobbie-ts
Member#: 270674
2003 Impreza TS
BRP
Darn I really wanted to give em a shot too lol.Good that you didn't get rid of them though. I would have been upset.
Yeah that's what I was thinking. I was thinking of swapping to the wrx hood because of the weight difference, but I'm not making it a race car anytime soon(eventually this car will become my second car though which is when I'll really start dropping money on high end parts like Big A$$ turbo's lol). I want a good strong engine that can take a beating and a handle any power I decide to put in it in future years which is why I like the sound of going ahead and buying the built long block, but I'm not worried about shedding 75 pounds that much. Plus if I get a wrx hood I'll have to paint it to match which is another cost and time thing that I don't really want to worry about.
I just have to find the right front mount. the DR525 looks good and fits into the power band I want to be in, but I don't know where to get one around here. I'm just going to keep an eye on the parts for sale thread and hope one pops up or something else that's in the price range. And then I need to find a intake manifold that will fit his engine. He said mine will fit so I may just do that if he's correct??? Then all I should need is a wiring harness and the 6 speed swap components.
When I looked at the ECS breakdown they're wanting 12K for just the parts for the swap. So I think if I use that number as my budget number I'll be good to go. I can get the built engine, a wiring harness/ECU, an intake manifold, a FMIC, and the tranny swap stuff for about 12K if it works out right. And that's better than a standard STI engine tranny swap in my books.
Old 01-17-2013, 08:34 AM   #1268
FlySense88
Member#: 327665
When do you guys meet up in glen burnie?
FlySense88 is offline   Reply With Quote
Old 01-17-2013, 08:40 AM   #1269
scobbie-ts
Member#: 270674
2003 Impreza TS
BRP
currently we're not. But we are going to start it back up in the spring time. A specific date will depend on the level of interest and the weather. the OP will be updated once it's been decided though.
Old 01-17-2013, 08:45 AM   #1270
FlySense88
Member#: 327665
Ok I will stick around.
Old 01-17-2013, 08:55 AM   #1271
scobbie-ts
Member#: 270674
2003 Impreza TS
BRP
Cool beans. What do you drive by the way? we have a varied crowd. Also, if you're wanting to go to a meet happening now I believe the Wednsday meets at Waugh Chapel are still happening. Although the crowd will be smaller lol.
Old 01-17-2013, 08:55 AM   #1272
lilblue619
Member#: 288292
2004 sti
wrb. the blue one.
Someone should join me this Saturday morning to go to cars and coffee in Fulton.
Old 01-17-2013, 08:57 AM   #1273
scobbie-ts
Member#: 270674
2003 Impreza TS
BRP
Fulton as in near laurel? If so I'd be down for that. There's an amazing Cars and Coffee in Great Falls VA too. In case you felt like driving an hour to see a bunch of ferraris and exotics lol
Old 01-17-2013, 09:03 AM   #1274
lilblue619
Member#: 288292
2004 sti
wrb. the blue one.
This one has some nice exotics also they have a thread on here but yeah I got a go pro n wanna cruise with some people
Old 01-17-2013, 09:11 AM   #1275
FlySense88
Member#: 327665
12 wrx, I usually roll w/my bro he has an Evo x.
Wednesdays aren't good for me. I usually look for things on Fridays & Saturdays.
Weekend Sightings Hanover Glen Burnie area plunk10 Mid Atlantic Impreza Club -- MAIC 1 08-19-2003 09:18 PM
anybody up for glen burnie meet on sunday Varanont Mid Atlantic Impreza Club -- MAIC 18 05-05-2003 09:37 AM
Glen Burnie meet this weekend? Jabzilla Mid Atlantic Impreza Club -- MAIC 16 04-13-2003 09:34 PM
what happened to the Glen Burnie Meet? Varanont Mid Atlantic Impreza Club -- MAIC 28 04-08-2003 05:16 PM
glen burnie meet this weekend bluespeed Mid Atlantic Impreza Club -- MAIC 100 03-22-2003 05:24 PM
