#1 |
Member#: 316120
Vehicle:2006 STI Blue |
How can I clear my headlight I tried turtle wax and it nearly worked.
#2 |
Member#: 44618
Vehicle:2004 |
They sell this rain-x kit at pep boys for 20 bucks. Real easy to use and works great for the price. I used it on my 04 forester and it worked wonders.
#3 |
Member#: 316120
I bought the one that looks like it and it didn't work
#4 |
Member#: 194213
NWIC
Vehicle:2005 WRX World Rally Blue |
Turtle wax is nothing like the rain-x headlight restoration kit that hes talking about. The rain-x kit looks like this:
http://www.rainx.com/products/Plasti...Headlight.aspx you can also use the 3m product found here: http://solutions.3m.com/wps/portal/3...g_a_Headlight/ This can be purchased at any auto store. Good luck! |
#5 |
Member#: 176408
SCIC
Vehicle:2006 Acura TSX Black |
If you can get your hands on a "buffer", try wet sanding the headlights and using Meguiar's ScratchX. It's a step up from the kits out there.
Or, Orbital/Rotary Polisher with the right products and pads will yield the best results. |
#6 |
Member#: 316120
I used turtle headlight restoration kit. It got a little better but still foggy. Rain x will do it?
#7 | |
Member#: 217405
Vehicle:2006 WRX |
Most of these kits offer less than stellar results. 3m is good and Megs heavy duty kit is probably the best over the counter system I have used. |
#8 |
Member#: 204121
TXIC
Vehicle:2005 WRX Wagon CGM |
I use plasti-x followed by either cleaner wax or just any old wax. This is not a once-and-done procedure, you will have to repeat it about every other wash. Since the original haze protection layer has been removed over time, it will keep getting hazed unless you buy new ones. I think there might be a clear liquid solution I saw somewhere a while ago that is supposed to replensih this lost layer but I can't recall what it was.
#9 |
Member#: 309342
South East
Vehicle:2004 Forester xt Java Black Pearl |
I've used the mother headlight restoration kit with good results. You just need a drill to put the attachment on and buff it with the provided liquid then wipe it off with the microfiber towel. If it still needs serious restoration it comes with 4 sandpaper pads that you use in steps and each one is a finer grit. I used it on my moms cr-v and it came out pretty well. Its only like 20 bucks at wal mart IIRC.
#10 |
Member#: 171758
NESIC
Vehicle:2006 WRX Ltd Stg m@! Blk&Grn / 08 Daytona 675 |
^ a buddy just used this kit over the weekend on his headlights. he tried just buffing, that didn't work. so we did the full wetsand procedure until it was really hazy but glass smooth, and then the buffer didn't do crap to get rid of the haziness. I don't know if we didn't buff long enough, but we went at it for a few minutes using various speeds and amounts of polish...
#11 |
Member#: 131379
Vehicle:2003 354 ftlb@3k rpm justablue hatch |
i used the 3m kit on my subie, worked great. year later re-buffed with meguirs scratch x, worked great. looked like new.
also did wifes highlander and different plastic quality meant results were not as good. |
#12 |
Member#: 119934
TXIC
Vehicle:2013 Legacy Sport SWP |
I use a DA polisher and maguiar's compound. This was on my sister in law's civic.
Before ![]() After ![]() |
#13 |
Member#: 171758
NESIC
i'm going to attempt wet sanding from like 1000 to 3000, and then polishing. i have some scratches on my headlight from where someone hit me, and my detail shop didn't want to risk doing more damage
#14 |
Member#: 319210
South East
Vehicle:2012 Impreza Limited Dark Gray Metallic |
The Mothers polish system is okay, but the power ball is not the best tool for the job. I've used it. If I didn't have a buffer, I'd rather apply and buff by-hand.
If you've got a decent buffer, you can even just use a clear-coat-safe rubbing compound. Mask-off the painted surfaces and buff until it's clear. Start with a light-cutting pad then move to something finer that you'd otherwise use for removing swirl-marks. I like the Novus 3-step plastic polish process - a coarse grit compound, then a fine grit compound, then a clear sealant. The idea is just to polish-off the oxidized plastic for clarity, then protect it. Can be applied by hand or by machine. |
#15 |
Member#: 319210
South East
Recently I saw a kit in Autozone with instructions, paper, buffing compounds, and clear-coat for around $20. Worth looking-into before you go nuts on your own.
#16 |
Member#: 171758
NESIC
yea, but i figure i can just buy the supplies separately for about the same price... i'll check out the off-the-shelf products first though. i just think i'm going to need to combine a wide range of products for what i'm trying to accomplish
#17 |
Member#: 319548
Vehicle:2004 Subaru WRX STi World Rally Blue |
I reccommend the meguiars Headlight resoration kit. Works wonders and is about 20 dollars at your local advance auto parts.
#18 |
Member#: 279870
HIIC
Vehicle:2005 WRX Wagon Black |
lol do what I did. Took a buffer ball and zip tied a microfiber cloth to it. Sprayed light with Simple Green. Spun my drill up and moved all around. Then sprayed with simple green again and used a damp cloth to clean it all up. Took rag off buffer ball and went to town with Cleaner Wax. I was surprised at the results. Again as noted by someone before. This doesnt protect it so you gotta get some kinda sealer or something but my lights were back to clear and lasted about 2 weeks before I am noticing it happening again :0
#19 |
Member#: 279533
My headlights and fog lights are super cloudy after a decade of constant daily use. I'm going to have to research all the brands mentioned in this thread to see which has been the most effective. Results will be posted (hopefully with pictures).
#20 |
Member#: 119934
TXIC
Here's another result from using just a rubbing compound with da polisher.
#21 |
Member#: 275346
Vehicle:05 FXT |
+1 for meguires or mothers. Can't remember which I used, but its probably the easist detail job I've done (short of a standard car wash). Take your time, and use blue tape to save the paint
#22 |
Member#: 25187
Vehicle:'08 Foz Prem TGM '10 Challenger R/T Blk |
....since we're posting progress shots, here are some pictures of a Honda Civic Si I did for an "in-law" relative. I was in my garage and noticed how hazy his headlamps were. After a closer inspection I noticed it would likely buff out fairly well by hand. I thought this would be a nice demonstration what folks could do (in some cases) simply by using a product like Plast-X by hand:
BEFORE: ![]() AFTER: ![]() 50/50 ![]() The ripple in the drivers side headlamp is actually a reflection of the roof line (spanish tiles) on my house. |
#23 |
Member#: 300496
I use 500, 800, 1000, 1500, then 2000 grit and follow with meguires polish. works great
#24 |
Member#: 171758
NESIC
^ good to know, b/c that's probably what it's gonna take to remove the scratches on my headlight.
when you guys polish by hand, do you just use a microfiber cloth? how long does it take to polish smooth? and how often do you reapply the polish? i've always been terrible at anything sanding/detailing, so any specifics would be much appreciated! |
#25 |
Member#: 319803
Honestly, the best way to make sure it won't come back is to wetsand it, and clear it. You'll be surprised how effective it just is.
| Thread Tools | |
| Display Modes | |
| WTT : 04-05 Morette Headlights for OEM WRX Headlights or STi Headlights | Gray_Scale | NWIC Private Classifieds | 10 | 03-27-2011 08:27 PM |
| Help: Can't figure out how to install headlight bulb and harness back into headlight | Gypsum2 | Interior & Exterior Modification | 2 | 07-29-2002 12:25 PM |
| steamed up headlights from doing headlight painting mod....help? | aphex twin | Interior & Exterior Modification | 6 | 12-04-2001 10:43 AM |
| Are RS headlights the same as L headlights? | slim speedy | General Forum Archive | 4 | 03-01-2001 12:42 AM |
