Old 05-03-2012, 01:50 PM   #1
tenchu
Member#: 64147
1993 STi RA V LTD
Green
Default CEL check w/o cluster... LED? Please help
So I got my rhd converted ej20g swapped gc running. But rough. And my cluster seems to be dead. I was wondering I there was any way to wire an led for the cel function. Just as a temporary solution so I can get the car running right while I wait for a cluster
tenchu is online now   Reply With Quote
Old 05-03-2012, 04:33 PM   #2
kellygnsd
Member#: 32669
2007 FR TS EFR 7670
LINK G4 hybrid STi
Laptop and cable
kellygnsd is online now   Reply With Quote
Old 05-03-2012, 04:36 PM   #3
tenchu
Member#: 64147
1993 STi RA V LTD
Green
I don't have a obd1 Subaru cable
Old 05-03-2012, 08:43 PM   #4
suberdave
Member#: 101865
88 GL-10 STi
you can find the CEL wire coming out of the ECU, the ECU toggles the Ground. so you have to use a small bulb or LED (i have an LED testlight that i have used many times) connect the testlight to power and touch the other end to the CEL wire from the ECU.
connect your test connectors and read the flashes...
Dont use a large testlight. it may pull more current that the ECU wants to give out.
an LED is best.
-=Suberdave=-
www.suberdave.com
suberdave is offline   Reply With Quote
Old 05-03-2012, 09:02 PM   #5
tenchu
Member#: 64147
1993 STi RA V LTD
Green
Thank you sir. I figured it would be you or Rob to chime in
'02 miss and CEL - With NO CODE! - please help Woodenhorse Factory 2.0L Turbo Powertrain 15 09-24-2011 08:17 PM
A lot of CEL codes on my ej20g swap... Please help.. FATgc8 Pre-2002 Factory Turbo Powertrain 6 05-08-2010 03:10 AM
Cluster problem...please HELP!! sc00ter Interior & Exterior Modification 3 12-13-2006 12:06 AM
2002 WRX -- Failed Parking Lights/Instrument Cluster -- PLEASE help. . . ImTooRexy Electrical & Lighting 6 08-02-2005 11:29 PM
check out my utec logs, please help! datdudedennis Engine Management & Tuning 31 05-01-2003 07:21 PM
Message Board Statistics All times are GMT -4. The time now is 12:14 PM.
