Old 05-03-2012, 02:41 PM   #1
rsg9115
Member#: 218569
91 leggy sdn turbo
black
Default Four codes
Air flow sensor
Cam angle sensor
knock sensor
iac
Any ideas on my problem ? Just bought the car a week ago
rsg9115 is offline   Reply With Quote
Old 05-03-2012, 03:33 PM   #2
rsg9115
Member#: 218569
91 leggy sdn turbo
black
Cleaned all related sensor plugs except cam angle ( no idea which one) and disconnected batt. Start it check light was instantly on
Old 05-03-2012, 07:59 PM   #3
rsg9115
Member#: 218569
91 leggy sdn turbo
black
Well no one seems to kno I guesss but my abs light was on fixed that by cleaning plugs and I cleaned manyy plugs to the engine and power washed carefully now the lights out flicks on for a few seconds mayb only a couple times so I checked codes still saying the same four so i unhooked the batt again see what happins but I did a pull and it's bogging under boost a few times it was like stuttering idkk
Old 05-04-2012, 01:52 PM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Assuming your older EJ is the same as the newer ones, the cam angle sensor is on the top of the driver side head.
With that many sensors indicating a fault I would be inclined to think there was a ground issue somewhere that was causing the ECU to get bad readings.
Old 05-04-2012, 08:50 PM   #5
rsg9115
Member#: 218569
91 leggy sdn turbo
black
Hmm thats a really good idea I'll check grounding Tom.
Old 05-04-2012, 09:00 PM   #6
rsg9115
Member#: 218569
91 leggy sdn turbo
black
Ya and more random codes have popped up I found a crack in the line off the intake to the bypass valve earlier
Old 05-05-2012, 07:36 PM   #7
rsg9115
Member#: 218569
91 leggy sdn turbo
black
Update like 6 random codes put in a brand new alt has new batt I did some grounds I'll finish then Tom
Old 05-05-2012, 07:38 PM   #8
rsg9115
Member#: 218569
91 leggy sdn turbo
black
I'm planning on also goin vac line crazy and inspect the ecu, btw now it has no power no turbo sounds like it hardly spools
2006-2007 Subaru Wrx Four Pot Brake Calipers, All Four CHEAP!!!! 98SubbyLeg Suspension/Brakes/Handling 4 02-22-2010 08:14 PM
Dear Four x Four Gee Gee Gee psychoskip Off-Topic 17 08-18-2009 09:24 PM
FS set of four ASA AR1 Silver w/Machined Lip 17x7 (+48) and four RE92 tires Piper NWIC Private Classifieds 21 03-04-2009 02:30 AM
codes,codes and more codes grinch77 Newbies & FAQs 8 01-07-2009 05:27 PM
2008 Chevrolet Cobalt SS Faces Four Forced-Induction Fours and a High-RPM Honda AVANTI R5 Non-Subaru News & Rumors 76 06-16-2008 07:06 PM
