Old 05-03-2012, 08:19 PM   #1
skubaru
Member#: 318273
Default Clutch getting stuck, even after bleeding.
So here the thing, the clutch gets stuck about an inch from fully being disengaged and I have to pull it up back with my foot, or it bounces back really hard. I have bled the clutch and it worked like butter for a day or so and now here it is again. Could it be the slave cylinder? From what I can tell it's not leaking anywhere, and brake fluid is filled up. Even though when I first bled the clutch, there was a lot of air in it and it was a bit low on brake fluid. My car is an 02 2.5rs. Thanks a lot !
skubaru is offline   Reply With Quote
Old 05-03-2012, 10:42 PM   #2
skubaru
Member#: 318273
Anyone? Ordering a slave cylinder tmrw, would like to know if that's most likely the problem!
Old 05-04-2012, 12:06 AM   #3
recce02
Member#: 13815
02 GCRally prepped
277TQ 281HP 19PSI
Definitely sounds like slave cylinder or even the line from it. Inspect the soft line as well.
O also check the bleed port. Sometimes they get gummed up and may not allow the bleed port to properly tighten up, therefore allowing some air to get back in.
Make to get new o rings/seal for the reservoir to cylinder.
recce02 is offline   Reply With Quote
Old 05-04-2012, 12:14 AM   #4
skubaru
Member#: 318273
For some reason, my local o'reileys have the slave cylinder for only $23. Should I just order a whole slave cylinder and see what happens? They will also allow me to return it if that wasn't the problem so no risk taken here. Thanks a bunch for ur info!
Old 05-04-2012, 12:23 AM   #5
recce02
Member#: 13815
02 GCRally prepped
277TQ 281HP 19PSI
Check to see if that slave comes with a seal or o ring for the reservoir. If it does just replace it. If not see if you can get it. No reason to buy a whole new one if the reservoir isn't damaged.
Old 05-04-2012, 09:44 AM   #6
billzebub
Member#: 40248
2003 WRX
Midnight Pearl (black)
I had a similar issue except mine would go all the way to the floor and not come back. I changed the slave and that didn't help. Turned out to need a master. I did the ol' cluth delay valve-ectomy while in there and replaced the clutch line with a SS one. All is good.
billzebub is offline   Reply With Quote
Old 05-04-2012, 09:24 PM   #7
skubaru
Member#: 318273
I ordered the slave cylinder, how do I go about replacing it? Do i have to flush out all of the fluid? If so, do i do it with the bleed screw?
Old 05-04-2012, 10:05 PM   #8
recce02
Member#: 13815
02 GCRally prepped
277TQ 281HP 19PSI
Just unhook all of the lines to and from it, your gonna have to bleed it after install anyways.
Old 05-05-2012, 02:33 PM   #9
skubaru
Member#: 318273
Put in the new slave cylinder, we will see in a day or two if that was the problem. Also, I used a week old brake fluid, should I flush it all out and put in a new one or is it fine? If so, is there an easier way to flush it all out or pump-unscrew the bleed port a bunch of times? Appreciate all the help!
Old 05-07-2012, 03:57 AM   #10
recce02
Member#: 13815
02 GCRally prepped
277TQ 281HP 19PSI
Fluid should be fine. An easier way to bleed is by using a vacuum pump. Either a hand pump or compressor driven pump.
Old 05-09-2012, 10:10 PM   #11
billzebub
Member#: 40248
2003 WRX
$15 at harbour freight for the vacuum pump.
Still getting P0325 CE even after replacing knock sensor. What next? Sean Normally Aspirated Powertrain 21 02-11-2012 03:05 PM
softer clutch pedal after bleed SleepyWeasel Transmission (AT/MT) & Driveline 1 12-04-2010 09:04 PM
stuck on 9 PSI even after stg 2 reflash!!! mtxfrk2k1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 02-07-2010 03:03 AM
Clutch pedal gets stuck after pressing in... jakeachy Transmission (AT/MT) & Driveline 1 12-22-2007 01:57 PM
Brake pedal to floor even after flush and bleed chimchimm5 Service & Maintenance 13 05-01-2007 12:23 PM
