Old 05-04-2012, 12:17 PM   #1
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Post NASIOC 50-100mph List
What is this?
This post is meant to contain a list of 50-100mph times posted by NASIOC users. The times should be accompanied by basic info about the vehicle (modifications, fuel, weight, etc). A tandard format will be described below to allow for easy comparison. These times can be used as a benchmark for comparing the impact of modifications, acceleration at given power levels, and/or 1/4 mile times.
Why 50-100mph?
On other forums (namely 6speedonline) the 60-130mph time is used as a benchmark. This range is used instead of 1/4 mile times and speeds because the 1/4 mile is highly dependent on track conditions and launch. 60-130mph is sufficiently fast enough to avoid launch/traction differences in most cases. But, after some consideration it was determined that 60-130mph was not practical for many Subaru's. It was chosen to use the 50-100mph range.
This range is fast enough that traction is not an issue on most AWD cars and the top end is not too difficult to reach (similar to a normal road tuning log or trap speed for a near-stock car). This range should not cause issues (due to traction) on most Subaru's, and the top speed is such that it is accessible for even stock cars quite easily.
Why not post dyno numbers or 1/4 mile times?
We do already have a similar list for "Road Dyno" numbers. This is based on the Airboy spreadsheets and is a valuable resource. This info is still very useful, in fact for many things it is much more useful than 50-100mph times (like looking at powerbands, etc), but it does have a few downfalls. First is that the numbers are highly dependent on user inputs. If you have a highly modified vehicle, this becomes difficult. Even something as simple as entering vehicle weight incorrectly can skew the numbers.
The next main issue is that a dyno number doesn't directly correlate to how quick your car is (as compared to someone else's). Making more power doesn't mean your car will accelerate more quickly. Gearing, weight, aerodynamics, etc all come into play. Having an actual time is much easier to compare, and is more of a "real world" result. This also means that a 50-100mph time is something that can be compared across not only different Subaru models, but across other platforms as well (so feel free to post results from other vehicles!).
What do I need to do?
When you do the run, you can basically do anything you want to get from 50-100mph as fast as possible: use whatever gears you'd like, brake boost, start slower and go WOT through 50mph, etc. As long as you are on a flat surface it is OK. To get on the list, you need some way to confirm the time. The best ways to do this are with a data log, a video of the speedometer, or best yet a VBOX or similar device. Please post one of those things as proof, and then fill out the following information, using the formatting described below. Once all of that is in place, I will update your time onto the master list.
What is the format?
Two sets of info need to be posted. The first is a single line for use in the overall list. The second is a summary of your modifications that will stay in your post and people can review.
Here is the format for the single line of info. You can use the code tags if you want, otherwise just enter the data in a line and I can do the formatting when I update the list. Please write "NA" if you don't have that piece of info. For induction, please list what turbo you are using. (Code tags purposely broken to make it easier to copy/paste.)
[code]Username Year Make Model HP TQ 50-100 1/4 ET 1/4MPH Lbs L Cyl Induction Boost Fuel[code]
Here's an example:
[code]xluben 2011 Subaru WRX 462 492 4.5 NA NA 3400 2.5 F4 20G XTR [code]
And this is the format for the summary of modifications on the car:
Motor:
Turbo:
Boost:
Transmission:
Redline:
Upgrades:
Weight:
50-100MPH:
Example:
Vehicle: 2011 WRX
Motor: 2.5L Forged Pistons
Turbo: Blouch 20G XTR
Boost: 27psi
Transmission: Stock 5 Speed
Redline: 7100rpm
Fuel: E85
Upgrades:
  • Invidia Catless Downpipe
  • Stock Catback Exhaust
  • Tial 44mm EWG
  • FMS FMIC
  • KSTech Intake
  • Five-0 1200cc Injectors
  • Walbro 255 Fuel Pump
  • Mach 5 Awesome 17x9" Wheels
  • Dunlop Star Spec 255/40R17 Tires
Weight: Full Stock Weight + Driver
50-100MPH: 4.4sec
xluben is offline   Reply With Quote
Old 05-04-2012, 12:17 PM   #2
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
NASIOC 50-100mph List:
Code:
AFPSubaru	NA	Subaru	Impreza	1010	NA	1.9	8.4	170	2200	3.3	F6	GT2871 x2	28psi	NA
Bud Moeller	NA	Ferrari	F1	NA	NA	2.0	NA	NA	NA	NA	NA	NA		NA	NA
UndergroundRace	2012	Lambo	LP700-4	1200	NA	2.5	NA	NA	NA	NA	NA	UGR TT		NA	NA
vangstaboi86	2004	Subaru	STI	NA	NA	3.4	10.6	133	NA	2.5	F4	BW		NA	E85
ThatRacingChann	2012	Nissan	GT-R	607	NA	4.0	NA	136	NA	3.8	V6	Twin Turbo	NA	E85
juanmedina	2007	Subaru	WRX	NA	NA	4.1	NA	NA	2970	2.5	F4	FP Black	26psi	E85
Juks 		2005 	Subaru 	STI	500 	420 	4.2	10.8 	129	Stock	2.5 	4 	GT35R 		30psi 	E85
renosubby	2006	Subaru	WRX	NA	NA	4.1	NA	NA	3480	2.5	F4	HTA82		25psi	91
AirManCam	2006	Subaru	STI	NA	NA	4.4	NA	NA	3400	2.5	F4	HTA86		24psi	93
jays05		2005	Subaru	STI	NA	NA	4.5	NA	NA	3300	2.5	F4	GT35R .82	27psi	E85
Moleness	2004	Subaru 	STI	NA	NA	4.5	NA	NA	NA	2.5	F4	BW		NA	E85
xluben		2011	Subaru	WRX	462	492	4.5	NA	NA	3400	2.5	F4	20G XTR		27psi	E85
ThatRacingChann	2012	Nissan	GT-R	511	501	4.6	11	129	NA	3.8	V6	Twin Turbo	NA	93
amalgrover	2002	Subaru	WRX	NA	NA	4.7	NA	NA	3536	2.5	F4	FP Red		NA	E85
GeneralTJI	2002	Subaru	WRX	NA	NA	4.9	NA	NA	NA	2.2	F4	NA		NA	NA
juanmedina	2007	Subaru	WRX	NA	NA	5.0	NA	NA	2970	2.5	F4	FP Black	22psi	E85
whattayad0in	2004	Subaru	STI	NA	NA	5.1	NA	NA	NA	2.5	F4	20G XT		26psi	93
juanmedina	2007	Subaru	WRX	NA	NA	5.2	NA	NA	2970	2.5	F4	FP Black	24psi	E85
gold rush	2004	Subaru	WRX 	NA	NA	5.2	NA	NA	3542	2.5	F4	GT35R .82	22psi	Meth50
alcoolaid	2007	Subaru	STI	490	NA	5.2	NA	NA	NA	2.5	F4	s300sx 83-75	23psi	Meth50
xluben		2011	Subaru	WRX	NA	NA	5.3	NA	NA	3400	2.5	F4	20G XTR		24psi	E85
renosubby	2006	Subaru	WRX	400	342	5.6	NA	NA	3450	2.5	F4	NA		NA	NA
Slimsti		2007	Subaru	STI	380	412	5.6	NA	NA	NA	2.5	F4	FP Green 7cm	25psi	93
STi MAN86	2007	Subaru	STI	NA	NA	5.7	NA	NA	NA	2.5	F4	TD-06 20G 8cm	24psi	Meth50
Dave D.		2006	Subaru	WRX	NA	NA	6.0	NA	NA	3610	2.5	F4	FP HTA68	22psi	92
2006whitesti	2002	Subaru	WRX	NA	NA	6.5	NA	NA	NA	2.5	F4	GT52		19psi	NA
synolimit 	2011	Subaru 	WRX 	310	374	6.6	NA 	NA 	3147	2.5	F4 	VF52 		16psi 	93
Tryptofan	2009	Subaru	STI	342	374	6.8	NA	NA	3600	2.5	F4	VF48		NA	E85
J_Maher_WRX	2011	Subaru	WRX	NA	NA	7.4	NA	NA	3450	2.5	F4	VF52		19psi	91
xluben		2011	Subaru	WRX	340	369	7.5	NA	NA	3600	2.5	F4	VF52		20psi	E85
snake32		NA	Subaru	RS	NA	NA	7.7	NA	NA	NA	2.5	F4	GT30R		NA	NA
silvercookie	2005	Subaru	WRX	250	250	7.9	NA	NA	NA	2.0	F4	VF48		18.5psi	NA
xluben		2011	Mazda	MS3	NA	NA	9.2	NA	NA	3672	2.5	F4	K04		18psi	93
wilde		2005	Subaru	WRX	NA	NA	9.8	NA	NA	NA	2.0	F4	TD04		NA	NA
amp2oo1		2011	Subaru	STI	NA	NA	9.9	NA	NA	NA	2.5	F4	VF48		14.5psi	93
synolimit 	2012	Buick	RegalGS	270	295	10.3	NA	NA	3800	2.0	I4	TD04		20psi	93
Mike Costin 	1995 	Jeep 	XJ $500	190 	220	45.6	NA	NA	3800 	4.0 	L6 	NA 		NA 	85/87
Old 05-04-2012, 12:17 PM   #3
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
What times do other types of cars do?
Here is a list of some cars that I pulled from Road and Track's testing (they are all stock/unmodified). It is sorted by 50-100mph time (fastest to slowest).
Code:
Year	Make		Model		Price		LBS	HP	TQ	50-100	0-100	0-60	1/4 ET	1/4MPH	L	Cylinders
2014	McLaren		P1 		$1,150,000	3303	903	664	2.7	4.7	2.6	9.8	148.9	3.8	V8
2011	Bugatti		Veyron 16.4 SS	$2,765,840	4545	1200	1106	2.8	4.9	2.5	9.9	145.8	8.0	W16
2013	AMS		Alpha 12 GT-R	$200,000	3715	1100	770	3.0	5.2	2.7	10.0	146.7	3.8	V6
2006	Bugatti		Veyron 16.4 SS	$1,482,700	4655	1001	922	3.4	5.5	2.6	10.2	142.9	8.0	W16
2012	Lamborghini	AventadorLP7004	$387,000	3795	691	509	3.7	5.8	2.7	10.4	136.0	6.5	V12
2010	Ferarri		458 Italia	$280,572	3650	570	398	4.3	6.7	3.0	11.0	128.5	4.5	V8
2010	Chevrolet	Corvette ZR1	$121,425	3530	638	604	4.4	7.3	3.5	11.5	128.7	6.2	V8
2011	Porsche		911 Turbo S	$162,460	3770	530	516	4.4	6.3	2.6	10.7	128.9	3.8	F6
2011	Lamborghini	GallardoLP570-4	$282,180	3630	562	398	4.5	6.8	3.0	11.0	128.9	5.2	V10
2005	Mercedes	SLR McLaren	$450,000	4040	617	575	4.7	7.5	3.5	11.5	126.1	5.4	V8
2013	Nissan		GT-R Premium	$95,280		4090	545	463	4.8	7.1	3.0	11.2	125.0	3.8	V6
2011	Mercedes	SLS AMG		$183,000	3970	563	479	4.8	7.7	3.6	11.6	124.3	6.2	V8
2010	Porsche		911 Turbo	$149,370	3700	500	480	5.1	7.9	3.5	11.7	121.8	3.8	F6
2011	Chevrolet	Corvette Z06	$98,010		3485	505	470	5.2	8.2	3.6	11.9	123.5	7.0	V8
2008	Porsche		911 Turbo	$135,470	3710	480	457	5.2	7.9	3.4	11.7	121.2	3.6	F6
2008	Chevrolet	Corvette Z06	$79,595		3350	505	470	5.3	8.0	3.4	11.7	123.7	7.0	V8
2010	Audi		R8 5.2 FSI	$170,350	3905	525	391	5.4	8.4	3.7	11.9	118.7	5.2	V10
2008	Dodge		Viper SRT10 	$91,995		3630	600	560	5.4	8.4	3.7	11.9	124.4	8.4	V10
2011	Nissan		GT-R Premium	$85,340		4085	485	434	5.5	8.0	3.3	11.6	120.4	3.8	V6
2009	Cadillac	CTS-V		$66,835		4300	556	551	5.5	8.8	4.1	12.3	118.8	6.2	V8
2011	Astin Martin	V12 Vantage	$193,755	3980	510	420	5.8	9.3	4.3	12.5	116.8	5.9	V12
2011	Ford		Shelby GT350	$82,658		4155	624	540	6.0	9.2	4.2	12.4	116.7	5.0	V8
2009	Nissan		GT-R		$72,880		3960	480	434	6.0	8.6	3.4	11.8	116.5	3.8	V6
2010	Jaguar		XFR		$80,000		4575	510	461	6.2	9.6	4.3	12.6	115.3	5.0	V8
2012	Chevrolet	Camaro ZL1	$54,995		4280	580	556	6.4	10.2	4.7	12.9	113.1	6.2	V8
2009	Mercedes	C63 AMG		$63,930		4100	451	443	6.5	9.7	4.1	12.5	114.4	6.2	V8
2010	Rolls-Royce	Ghost		$308,350	5675	563	575	6.5	10.2	4.7	12.9	114.3	6.6	V12
2008	Lexus		IS-F		$64,205		3985	416	371	6.6	9.9	4.7	12.6	113.8	5.0	V8
2008	BMW		M3		$59,050		3765	414	295	6.9	10.5	0.6	13.0	110.4	4.0	V8
2010	Chevrolet	Camaro SS	$32,390		4045	426	420	7.1	10.5	4.6	12.9	110.2	6.2	V8
2012	Chrysler	300C SRT-8	$57,725		4630	470	470	7.1	10.6	4.5	12.9	111.6	6.4	V8
2010	Chevrolet	Camaro SS	$36,265		4035	426	420	7.2	10.6	4.6	13.0	110.7	6.2	V8
2011	Dodge		Challenger SRT8	$44,380		4555	470	470	7.2	10.8	4.6	13.0	109.8	6.4	V8
2010	Audi		S4 Quattro	$58,675		4185	333	325	7.6	11.0	4.5	12.9	108.6	3.0	V6
2010	Bentley		Continental	$226,485	5755	600	553	7.6	11.0	4.3	12.9	108.5	6.0	W12
2011	Ford		Mustang GT	$39,680		3830	412	390	7.6	11.3	4.6	13.2	109.3	5.0	V8
2008	Audi		RS4		$70,785		3965	420	317	7.7	11.2	4.5	13.0	108.1	4.2	V8
2005	Chrysler	300C SRT-8	$45,295		4390	425	420	7.7	11.5	4.9	13.3	108.2	6.1	V8
2010	BMW		335i		$47,625		3745	300	300	8.0	11.7	4.7	13.3	105.7	3.0	I6
2009	BMW		135i		$38,175		3545	300	300	8.0	11.7	4.7	13.3	105.3	3.0	I6
2009	Audi		TTS		$52,075		3405	265	258	8.3	11.8	4.6	13.2	105.2	2.0	I4
2009	Chevrolet	Cobalt SS	$23,510		3155	260	260	8.4	12.8	5.4	13.9	104.0	2.0	I4
2010	Infiniti	G37S Sport	$40,085		3840	328	269	8.4	12.3	5.1	13.6	105.6	3.7	V6
2010	Ford		Mustang GT	$34,130		3755	315	325	8.5	12.7	5.3	13.8	104.0	4.6	V8
2008	Mazda		Speed3		$26,640		3305	263	280	8.5	12.8	5.7	14.1	101.3	2.3	I4
2010	Acura		TL SH-AWD	$44,195		4035	305	273	9.1	13.1	5.2	13.7	102.3	3.7	V6
2005	Chrysler	300C		$37,310		4330	340	390	9.5	13.8	5.6	14.1	101.0	5.7	V8
2009	Dodge		Callenger RT	$38,170		4305	376	410	9.5	13.8	5.8	14.1	101.2	5.7	V8
2009	Subaru		WRX		$28,660		3390	265	244	9.5	13.5	5.1	13.8	101.0	2.5	F4
2009	Mitsubishi	Lancer Ralliart	$29,915		3700	237	253	11.1	15.1	5.4	14.1	97.2	2.0	I4
2001	Caterham	Super Seven	$39,757		1510	147	140	13.2	17.6	5.8	14.5	92.2	2.0	I4
Old 05-04-2012, 12:18 PM   #4
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Old 05-04-2012, 12:18 PM   #5
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Amal Grover:
http://forums.nasioc.com/forums/show...7#post36555387
Vehicle: 2002 WRX Wagon
Motor: EJ255 longblock with CP pistons/Element Tuning Rods 9.77:1 CR and completely stock heads, cams, and exhaust manifold
Turbo: FP Red 8cm
Boost:
Transmission: 5 speedPPG straightcut 1-2/helical 3-4 stock subaru 5th
Redline: 7600rpm
Upgrades:
  • TurboXS catless RFL-Ti Turboback
  • SSAC FMIC
  • KSTech Intake
  • FIC 1250cc Low-Z Injectors
  • DW300 Fuel Pump
  • Kenne Bell Boost-A-Pump
  • Perrin 3" Inlet
  • DIY TGV Deletes
  • 06-07 WRX wheels
  • E85
Weight: 3336lbs + Driver
50-100MPH: 4.5sec
Old 05-04-2012, 12:18 PM   #6
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Old 05-04-2012, 12:19 PM   #7
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
xluben MS3:
Vehicle: 2011 MS3
Motor: Stock
Turbo: Stock
Boost: 18psi
Transmission: Stock
Redline: Stock
Fuel: 93
Upgrades:
  • Catted Downpipe
  • COBB SF Intake
  • COBB Turbo Inlet
Weight: Full Stock Weight + Driver + Passenger
50-100MPH: 9.2sec
http://benjohnson.smugmug.com/photos...-bDSvnKN-L.gif
Old 05-04-2012, 12:19 PM   #8
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
xluben E85:
Vehicle: 2011 WRX
Motor: Stock
Turbo: Stock
Boost: 20psi
Transmission: Stock
Redline: Stock
Fuel: E85
Upgrades:
  • Invidia Q300 Exhaust
  • AEM CAI
  • FMS FMIC
50-100MPH: 7.5sec
Old 05-04-2012, 12:19 PM   #9
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
xluben 20G Stock Motor:
Vehicle: 2011 WRX
Motor: Stock
Boost: 23psi
Redline: 6700rpm
Fuel: E85
Upgrades:
  • Tial 44mm EWG
  • FMS FMIC
  • KSTech Intake
  • Steelies and Winter Tires
50-100MPH: 5.3sec
Old 05-04-2012, 12:19 PM   #10
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
xluben 20G Built Motor:
Vehicle: 2011 WRX
Boost: 27psi
Redline: 7100rpm
Fuel: E85
Upgrades:
  • Tial 44mm EWG
  • FMS FMIC
  • KSTech Intake
50-100MPH: 4.5sec
Old 05-04-2012, 01:31 PM   #11
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
very nice I will add my video and log when I get home.
Old 05-04-2012, 01:55 PM   #12
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 427/427 JJtuned
Clearly these are pulls through 50mph, starting for the most part in 2nd gear at about 40mph. I think this is the best way, as it is difficult to obtain accuracy from a "standing" speed.
For instance, I have timed 60-90 on my wrx several times, starting at 60mph, and have obtained times from 3.4 sec to 3.9 seconds in consecutive sets of pulls. Who knows if I was starting right at 60 each time, or if my stopwatch was used accurately?
Pulling through 60 is noticeably faster, although with still inconsistent times due to using a stopwatch. Just wanted to clarify the rules here before I add my data.
Dave D. is offline   Reply With Quote
Old 05-04-2012, 02:49 PM   #13
CatfaceType-R
Member#: 81102
We need vboxes and the vbox data for this to be legitimately competitive and to obtain true "bragging" rights. Or at least we all need a gtech or all use cobbs accessport if it supports that(not positive, but I think it does...)
Also, we need a to say on our posts if this was on flat ground, incline, or decline.
Carmi
CatfaceType-R is offline   Reply With Quote
Old 05-04-2012, 03:03 PM   #14
dux10
Member#: 235338
2002 Faggin Wagon
srp
So what do we need to do? floor it at 50mph or start lower and run the stopwatch from 50-100?
20g on a 2 liter with 6spd doesn't like being floored from 50... lol
dux10 is offline   Reply With Quote
Old 05-04-2012, 03:10 PM   #15
juanmedina
Member#: 133146
Carmi
I think a log and video will suffice, not everyone has a Vbox. The inclination will introduce some error but it shouldn't be huge.
From my understanding floor it when ever you want. The point of this list is to see who is faster from 50-100mph; there fore who has the better power to weight ratio/ who is the fastest .
Old 05-04-2012, 03:12 PM   #16
Dave D.
Member#: 130990
06 Red Ltd.Wagon
You didn't read post #12, did you?
Old 05-04-2012, 03:18 PM   #17
dux10
Member#: 235338
2002 Faggin Wagon
srp
Actually I did. I was assuming starting at 50 was the way to do it until you mentioned pulling through 50. I just wanted to clarify before attempting it... lol
Old 05-04-2012, 03:30 PM   #18
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Carmi
I agree. A video or log isn't going to be perfect. VBOX would be ideal. BUT I wanted to make this as accessible as possible, so I'm fine with accepting videos and logs. If anything, they aren't any less accurate than all the Airboy/Virtual Dyno posts out there, because that is based off log data as well.
All runs should be done on flat ground. If you want to cheat and do it down a hill I guess no one will be able to stop you, but that's not really the point.
Here's what I posted when I originally did this.
I did it from a 30mph roll so my turbo was spooled up when I hit 50mph. Some might not agree with this, but I think it's the most consistent way. Basically just get from 50-100mph as fast as possible: use whatever gears you'd like, brake boost, start slower and go WOT through 50mph, etc. Just keep it to a flat surface and you're good.
I'll add a comment about this to the original post. Can't wait to see some more results!
Old 05-04-2012, 04:16 PM   #19
Big_DeWeY
Member#: 37078
95 L
Blue-ish
This looks fun. Might have to hop in the ring for this one.
Big_DeWeY is offline   Reply With Quote
Old 05-04-2012, 11:42 PM   #20
Dipp
Member#: 127907
99RS 9.54 @ 146
2.65L & FOBIA fab & S374
Not trying to be a downer but this seems like more of a FWD car thing. As most Subarus don't struggle with traction issues. It will be fun to see where they rank against RWD & FWD though.
Dipp is offline   Reply With Quote
Old 05-05-2012, 12:39 AM   #21
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
I will vbox the XTi tomorrow and log it so we can see the difference. I think it will be pretty off from other small comparisons I have done.
Junior2JZ is offline   Reply With Quote
Old 05-05-2012, 08:33 AM   #22
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
^^^ I feel looking at most of those times that they are easily doable . Specially with fuel cut raised a bit and 500 plus whp. Post a vid jr for pee pee touch.
stretchedk7 is offline   Reply With Quote
Old 05-05-2012, 08:56 AM   #23
CatfaceType-R
Member#: 81102
How is your car doing?
Old 05-05-2012, 11:00 AM   #24
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Traction from a roll usually isn't a problem but launching is a big variable that can throw off 1/4 mile times. I see 60' times that are 1.6 or better and some that are over 2 seconds. That difference would result in over a second difference in 1/4 mile. Another purpose was to make it quick and easy to do. For some people getting a 1/4 mile run can be a bit of a hassle.
Looking forward to seeing how it looks. I sure it will be fast!
I think so too. Video would be fun.
This might not be perfect but I think it could be interesting and is hopefully easy enough that many people will try it.
Old 05-05-2012, 11:17 AM   #25
juanmedina
Member#: 133146
Not everyone likes to go to the track or can afford breaking stuff all the time. This is a perfect way to you who has the best power to weight ratio AKA who is the fastest.
IMO a video is better than the log. The logging rate is not perfect plus fast polling introduces a lot of error.
Here is my vid and my log. The video has one run starting from 3rd and the other one starting from second. I short shifted 3rd on the first run. My log is from my second run, you can see that I am only running 22psi and I am running rich.
Code:
Time (msec)	Coolant Temperature (F)	Engine Load (Calculated) (g/rev)	Engine Speed (rpm)	Feedback Knock Correction (4-byte)* (degrees)	Fine Learning Knock Correction (degrees)	IAM (multiplier)	Ignition Total Timing (degrees)	Injector Duty Cycle (%)	Intake Air Temperature (F)	Manifold Relative Pressure (4-byte)* (psi relative)	Manifold Relative Pressure (Corrected) (psi)	Mass Airflow (g/s)	Mass Airflow Sensor Voltage (V)	Throttle Opening Angle (%)	Vehicle Speed (mph)	Innovate Wideband AFR (AFR Gasoline)
1402	190	1.19	3851	0	0	1	33	18.58	93	0	-0.15	71.4	2.84	100	37	14.2
1470	190	1.28	3824	0	0	1	25.5	21.21	93	0.35	0.29	79.96	2.88	100	37	14.86
1550	190	1.28	3890	0	0	1	25	21.58	93	0.77	0.58	78.72	2.9	100	37	13.96
1628	190	1.3	3956	0	0	1	25	23.63	93	1.18	1.02	87.13	2.96	100	37	13.08
1692	190	1.42	3960	0	0	1	24.5	24.5	93	1.74	1.6	90.58	2.94	100	37	12.52
1773	190	1.43	4069	0	0	1	24	24.78	93	2.27	2.18	92.43	3.06	100	37	12
1852	190	1.54	4063	0	0	1	24	26.87	93	2.97	2.76	101.93	3.18	100	37	11.77
1932	190	1.53	4118	0	0	1	24	27.23	93	3.64	3.48	99.69	3.1	100	37	11.79
2012	190	1.74	4248	0	0	1	23.5	31.24	93	4.44	4.21	120.09	3.28	100	37	11.72
2093	190	1.76	4243	0	0	1	23	33.49	93	5.42	5.22	124.71	3.34	100	37	11.66
2157	190	1.83	4373	0	0	1	22	34.93	93	6.43	6.09	126.25	3.36	100	37	11.66
2235	190	1.99	4408	0	0	1	21.5	39.12	93	7.55	7.25	143.62	3.48	100	39	11.33
2315	190	2.08	4494	0	0	1	21	40.63	93	8.97	8.56	148.65	3.52	100	39	11.29
2396	190	2.14	4630	0	0	1	20.5	45.78	93	10.49	10.01	167.42	3.62	100	39	11.29
2474	190	2.42	4695	0	0	1	20	49.4	93	12.23	11.61	181.01	3.68	100	39	11.3
2539	190	2.49	4814	0	0	1	19	53.71	93	14.1	13.49	193.02	3.8	100	39	11.32
2619	190	2.94	4893	0	0	1	18.5	64.5	93	16.21	15.38	227.05	3.96	100	39	11.13
2699	190	3.12	5017	0	0	1	17	70.64	93	18.29	17.7	240.28	4	100	42	11.22
2781	190	3.25	5132	0	0	1	16	78.92	93	20.46	19.73	278.47	4.16	100	42	11.08
2858	190	3.43	5268	0	0	1	16	85.48	93	22.03	21.62	297.97	4.16	100	42	11.02
2938	190	3.29	5408	0	0	1	16	86.53	93	22.81	22.64	295.65	4.24	100	42	11.04
3003	190	3.5	5540	0	0	1	16.5	94.56	93	23.21	22.78	329.14	4.32	100	42	11.08
3081	190	3.59	5679	0	0	1	17	89.84	93	23.3	22.78	315.03	4.26	100	42	11.29
3162	190	3.32	5740	0	0	1	17.5	95.52	93	23.55	22.78	336.23	4.32	100	48	11.39
3243	190	3.51	5922	0	0	1	18.5	97.28	93	23.22	22.78	337.02	4.34	100	48	11.52
3323	190	3.26	5982	0	0	1	19	93.16	93	23.13	22.78	331.47	4.34	100	48	11.5
3386	190	3.34	6092	0	0	1	19.5	97.47	93	22.81	22.78	347.35	4.36	100	48	11.5
3466	190	3.36	6225	0	0	1	20	94.63	93	22.69	22.78	333.05	4.32	100	48	11.61
3546	190	3.17	6338	0	0	1	21	93.7	93	22.41	22.49	355.41	4.42	100	48	11.52
3626	190	3.35	6536	0	0	1	21.5	99.41	93	22.35	22.35	360.27	4.42	100	53	11.57
3706	190	3.18	6594	0	0	1	21.5	91.95	93	22.28	22.35	341.79	4.38	100	53	11.69
3786	190	3.12	6768	0	0	1	22.5	101.07	93	22.26	22.35	358.72	4.42	100	53	11.69
3866	190	3.11	6792	0	0	1	23	96.17	93	21.54	21.91	342.58	4.34	100	53	11.66
3928	190	2.92	6892	0	0	1	23.5	92.62	93	21.3	21.33	349.73	4.4	100	53	11.83
4010	190	2.92	6985	0	0	1	24	90.06	93	20.36	20.46	335.44	4.38	100	53	11.58
4090	190	2.83	7061	0	0	1	24	88.88	93	19.93	20.02	324.38	4.32	100	61	11.6
4170	190	2.7	7248	0	0	1	24	92.78	93	19.81	19.88	333.05	4.34	100	61	11.47
4249	190	2.75	7337	0	0	1	24	92.35	93	19.37	19.59	325.15	4.32	100	61	11.36
4314	190	2.66	7348	0	0	1	24	79.95	93	19.17	19.59	304.93	4.34	90.2	61	11.27
4393	190	0.93	7624	0	0	1	33	4.84	91	2.42	7.4	323.58	4.4	20	61	12.32
4473	190	0.23	7339	0	0	1	26	14.21	91	-5.47	-3.92	39.12	2.4	12.94	61	20.33
4552	190	0.15	7102	0	0	1	26	4.59	91	-8.01	-7.55	23.49	2.16	12.55	67	20.33
4632	190	0.18	6861	0	0	1	26	4.39	91	-8.7	-8.56	19.55	1.84	12.55	67	20.33
4713	190	0.42	6622	0	0	1	45	8.48	91	-5.25	-9.14	17.85	2	26.27	67	20.33
4776	190	1.61	5838	0	0	1	48	33.09	91	4.57	3.92	135.2	3.34	98.43	67	20.33
4858	190	1.84	5026	0	0	1	25.5	40.74	91	6.83	5.95	151.21	3.5	100	67	20.33
4937	190	1.85	5424	0	0	1	24	48.03	91	7.97	7.55	168.15	3.62	100	67	20.33
5015	190	2.13	5244	0	0	1	23	50.35	91	10.2	9.29	177.48	3.7	100	72	11.77
5096	190	2.4	5431	0	0	1	22	56.77	91	12.08	11.32	193.88	3.88	100	72	10.91
5176	190	2.64	5344	0	0	1	21	65.76	91	14.39	13.78	234.22	3.96	100	72	10.73
5240	190	2.92	5447	0	0	1	20	70.89	91	16.7	16.11	242.27	4	100	72	10.83
5320	190	2.95	5460	0	0	1	18.5	82.48	91	18.92	18.43	280.62	4.18	100	72	10.75
5399	190	3.19	5612	0	0	1	18	82.62	91	20.46	20.02	278.36	4.16	100	72	10.58
5479	190	3.16	5620	0	0	1	17.5	87.52	91	21.42	21.18	300.29	4.24	100	75	10.6
5559	190	3.24	5718	0	0	1	18.5	89.26	91	21.88	21.76	311.89	4.22	100	75	10.61
5623	190	3.36	5711	0	0	1	18	86.74	91	22.27	22.05	301.84	4.26	100	75	10.79
5704	190	3.15	5817	0	0	1	18.5	91.83	91	22.28	22.35	318.17	4.32	100	75	11.04
5783	190	3.29	5840	0	0	1	19	90.96	91	22.47	22.35	309.57	4.28	100	75	11.04
5864	190	3.19	5914	0	0	1	19	87.36	91	22.24	22.49	314.99	4.3	100	75	11.07
5943	190	3.28	6016	0	0	1	19.5	92.4	91	22.21	22.35	324.4	4.32	100	75	11.13
6022	190	3.28	6002	0	0	1	20	91.87	91	22.19	22.2	321.24	4.3	100	79	11.08
6102	190	3.04	6050	0	0	1	20	92.94	91	21.99	22.05	329.93	4.32	100	79	11.14
6167	190	3.2	6108	0	0	1	20	92.52	91	21.87	21.91	339.41	4.26	100	79	11.14
6246	190	3.08	6211	0	0	1	20	87.86	91	22	21.91	321.26	4.34	100	79	11.13
6328	190	3.16	6298	0	0	1	20.5	93.1	91	21.94	21.91	337.82	4.36	100	79	11.1
6406	190	3.14	6287	0	0	1	21	88.52	91	21.9	21.91	323.62	4.3	100	79	11.19
6486	190	3.05	6323	0	0	1	21	94.42	91	21.91	21.91	340.2	4.34	100	83	11.2
6567	190	3.24	6456	0	0	1	21.5	95.04	91	21.93	21.91	343.38	4.34	100	83	11.25
6630	190	3.12	6494	0	0	1	21	91.44	91	21.91	21.91	326.76	4.36	100	83	11.23
6709	190	3.16	6484	0	0	1	21.5	96.84	91	21.91	21.91	351.32	4.4	100	83	11.19
6791	190	3.21	6604	0	0	1	22	91.58	91	21.85	21.91	328.37	4.38	100	83	11.16
6869	190	3.03	6690	0	0	1	22	97.54	91	21.93	21.91	352.99	4.42	100	83	11.19
6948	190	3.2	6754	0	0	1	23	97.97	91	21.9	21.91	352.19	4.4	100	88	11.14
7013	190	3.07	6676	0	0	1	22.5	92.57	91	22.12	22.05	341.79	4.4	100	88	11.14
7093	190	3.14	6824	0	0	1	23	98.99	91	22.21	22.05	352.19	4.38	100	88	11.16
7173	190	3.19	6875	0	0	1	23.5	95.34	91	22.22	22.2	344.96	4.38	100	88	11.36
7253	190	3	6836	0	0	1	23	99.17	91	22.27	22.2	357.09	4.38	100	88	11.26
7333	190	3.15	6904	0	0	1	23.5	98.68	91	22.28	22.35	355.41	4.42	100	88	11.48
7414	190	3	6915	0	0	1	23.5	94.41	91	22.36	22.35	343.38	4.4	100	93	11.47
7479	190	3.14	6985	0	0	1	23.5	98.93	91	22.53	22.35	365.21	4.44	100	93	11.47
7556	190	3.04	7025	0	0	1	23.5	97.41	91	22.61	22.49	357.14	4.44	100	93	11.5
7637	190	2.98	7141	0	0	1	23.5	99.65	91	22.62	22.64	362.78	4.44	100	93	11.63
7716	190	3.04	7296	0	0	1	23.5	101.83	91	22.74	22.64	364.37	4.46	100	93	11.45
7797	190	2.93	7136	0	0	1	23.5	97.43	91	22.92	22.78	356.25	4.38	100	93	11.64
7860	190	3.07	7225	0	0	1	23.5	101.73	91	23.01	22.78	365.2	4.46	100	98	12.5
7939	190	3.01	7340	0	0	1	23	101.78	91	23.11	22.78	358.77	4.36	100	98	12.1
8020	190	2.92	7300	0	0	1	23	104.35	91	23.18	22.78	379.61	4.48	100	98	11.97
8100	190	2.95	7442	0	0	1	23.5	96.74	91	20.42	22.78	374.43	4.42	78.04	98	12.69
8181	190	0.96	7442	0	0	1	33	4.76	91	-0.29	5.22	211.37	4.36	15.69	98	11.97
8261	190	0.41	7474	0	0	1	25.5	4.82	91	-6.8	-5.95	75.13	3.1	12.16	98	12.97
8324	190	0.23	7151	0	0	1	26	4.62	91	-8	-7.55	20.24	1.96	12.55	102	17.6
8404	190	0.17	6942	0	0	1	26	4.44	91	-8.8	-8.71	26.8	2.14	12.55	102	13.82
8484	190	0.16	6779	0	0	1	26	4.38	91	-9.14	-9.14	23.17	2.02	12.55	102	20.33
8563	192	1.38	6394	0	0	1	46	19.48	91	4.55	1.02	64.7	2.34	75.69	102	20.33
8644	192	1.86	5009	0	0	1	27	36.33	91	6.51	5.8	144.86	3.56	100	102	20.33
8708	192	2.07	5302	0	0	1	24.5	45.79	91	8.3	7.69	161.46	3.5	100	102	20.33
8788	192	2.08	5230	0	0	1	22.5	51.8	91	10.57	10.01	178.9	3.76	100	104	14.33
8868	192	2.48	5259	0	0	1	22	58.34	91	13.52	12.04	210.44	3.88	100	104	11.54
8946	192	2.93	5286	0	0	1	20.5	65.06	91	15.85	14.95	217.48	3.98	100	104	10.72
9027	192	2.99	5266	0	0	1	18.5	77.52	91	18.82	18.14	272.55	4.06	100	104	10.66
9108	192	3.3	5320	0	0	1	17.5	85.11	91	21.4	20.89	297.2	4.16	100	104	10.7
9171	192	3.29	5338	0	0	1	16.5	89.97	91	23.26	22.78	305.71	4.26	100	104	10.58
9251	192	3.54	5406	0	0	1	16.5	92.32	91	24.48	22.78	317.35	4.26	100	106	10.55
9330	192	3.6	5454	0	0	1	16	89.69	91	25.03	22.78	306.48	4.2	100	106	10.78
9410	192	3.51	5463	0	0	1	16	95.59	91	25.62	22.78	329.1	4.28	100	106	10.85
9490	192	3.59	5488	0	0	1	16.5	94.88	91	25.8	22.78	329.12	4.3	100	106	10.91
9571	192	3.42	5544	0	0	1	16.5	95.86	91	25.94	22.78	334.64	4.3	100	106	11.04
9634	192	3.65	5504	0	0	1	16	95.1	91	26.18	22.78	337.02	4.36	100	106	11.08
9714	192	3.64	5519	0	0	1	16.5	93.01	91	26.09	22.78	329.93	4.34	100	106	11.1
9794	192	3.5	5565	0	0	1	16.5	96.06	91	26.12	22.78	335.44	4.34	100	108	11.16
9874	192	3.65	5574	0	0	1	16.5	95.13	91	26.06	22.78	339.41	4.34	100	108	11.32
9953	192	3.5	5674	0	0	1	16.5	90.78	91	25.99	22.78	336.23	4.4	100	108	11.35
10017	192	3.64	5731	0	0	1	17	96.72	91	25.8	22.78	348.18	4.32	100	108	11.35
10098	192	3.6	5695	0	0	1	17	93.37	91	25.83	22.78	329.1	4.36	100	108	11.47
10177	192	3.52	5743	0	0	1	17	98.01	91	25.69	22.78	346.55	4.38	100	108	11.27
10257	192	3.64	5725	0	0	1	17.5	96.48	91	25.72	22.78	346.55	4.36	100	111	11.32
10337	192	3.65	5752	0	0	1	17.5	94.3	91	25.53	22.78	346.55	4.36	100	111	11.36
10419	192	3.68	5837	0	0	1	17.5	97.3	91	25.56	22.78	352.24	4.42	100	111	11.44
10481	192	3.58	5806	0	0	1	18	97.68	91	25.49	22.78	348.22	4.36	100	111	11.47
10563	192	3.46	5884	0	0	1	18	97.91	91	25.53	22.78	348.18	4.4	100	111	11.39
10642	192	3.66	5870	0	0	1	18.5	97.47	91	25.43	22.78	349.81	4.42	100	111	11.42
10721	192	3.65	5971	0	0	1	18	91.99	91	25.37	22.78	343.38	4.4	100	115	11.42
10800	192	3.66	5985	0	0	1	18.5	100.87	91	25.24	22.78	359.52	4.38	100	115	11.35
10864	192	3.58	5940	0	0	1	19	98.85	91	25.36	22.78	350.69	4.4	100	115	11.2
10944	192	3.48	6023	0	0	1	18.5	97.89	91	25.42	22.78	354.57	4.42	100	115	11.25
11023	192	3.58	6050	0	0	1	19	99.39	91	25.37	22.78	366.05	4.42	100	115	11.29
11103	192	3.6	6039	0	0	1	19	96.35	91	25.25	22.78	350.52	4.42	100	115	11.16
11185	192	3.52	6031	0	0	1	19	99.07	91	25.21	22.78	354.75	4.4	100	118	11.19
11265	192	3.54	6071	0	0	1	19	99.73	91	25.3	22.78	361.95	4.38	100	118	11.1
11328	192	3.41	6132	0	0	1	19	100.96	91	25.15	22.78	360.4	4.44	100	118	11.1
Xluben what is my time so I can posted using the appropriate format?
NASIOCers!! Starter mods list Daniel son Legacy Forum 4 11-21-2006 03:56 PM
50 cent listings on eBay motors plunk10 Off-Topic 7 10-17-2006 12:15 PM
Official NASIOC OT C List dr_wheel Off-Topic 25 02-22-2006 05:41 PM
NASIOC GMail Invite List AVATAR-X Off-Topic 458 05-21-2005 10:04 AM
Japan's Top 50 car list Tragedy Off-Topic 5 07-29-2003 11:49 PM
