Old 12-22-2012, 03:55 PM   #626
dave07
Member#: 291349
2013 Mustang GT
If you change your wheel/tire combo to a smaller setup, doesn't that affect your speedometer readout. Ie: your speedometer is reading high. This may explain the RAV4...
dave07 is offline   Reply With Quote
Old 12-22-2012, 04:01 PM   #627
J_Maher_WRX
Member#: 290307
Originally Posted by xluben View Post
Very interesting to see a cross-platform comparison like that. I think it's crazy that the Rav4 does 50-100mph in the 7 second range, but it only traps 99mph. Seems that some of the Subaru's in the 7 second 50-100mph range are trapping 110mph....
Rav4 video, STEEP downhill video maybe
Nah JK bro, I think it has to do with the wrxs ability to get out of the hole so quickly -- with most 300whp wrxs it's not hard to get a 4.0sec flat 0-60 or even quicker. I am curious as to why the trap speed is so low, though it could be that the higher gears in the rav4 are reallllly geared towards fuel economy? It also looks in the high 7's, closer to 8s from 50-100mph.
I tell you now, I would be PI$$ED if a Rav4 pulled on me from a roll after going stage 2+ in a WRX... Haha imagine the look on a Camaro SS drivers face even!!
Guess it goes to show how important rotating mass can make a difference. I just weighed my 18x8.75 xxr 527's yesterday and they are 19lbs a piece. Not bad for that size a wheel!
J_Maher_WRX is offline   Reply With Quote
Old 12-22-2012, 04:12 PM   #628
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Very good point! Now ya'll thinkin'!
Stock tires are 235/55-18
Current General Grabber is 215/55-16
Start crunching them numbers.....
Kevin Thomas is offline   Reply With Quote
Old 12-22-2012, 04:12 PM   #629
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
I totally got ignored for a RAV4
340Duster is offline   Reply With Quote
Old 12-22-2012, 04:21 PM   #630
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Ah! That makes more sense. According to the online calculators the equivalent 50-100mph readings would be 56-111mph with those wheels/tires.
xluben is offline   Reply With Quote
Old 12-22-2012, 04:52 PM   #631
J_Maher_WRX
Member#: 290307
Makes a LOT more sense haha I eyeball it somewhere in the 9second range according to that speed range, which is correct
Still a good time for a Rav4!!
Old 12-22-2012, 05:04 PM   #632
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
What about Airman he is running bigger wheels and tire?
Old 12-22-2012, 05:07 PM   #633
dmjhockey19
Member#: 258009
04 sti
wrb
Both airmancam and I are tuned by John Visconti of Viscontituning.
dmjhockey19 is offline   Reply With Quote
Old 12-22-2012, 05:12 PM   #634
dmjhockey19
Member#: 258009
04 sti
wrb
Ill let josh say his for sure but I'm running 17x9.5 and 255/40
Old 12-22-2012, 05:13 PM   #635
dmjhockey19
Member#: 258009
04 sti
wrb
I know he's on 18s and 235/40 federals
Old 12-22-2012, 06:24 PM   #636
dave07
Member#: 291349
2013 Mustang GT
If you look at his video again from 56-111, the corrected "50 to 100" is around 10ish seconds which will fall inline with his trap speeds.
Still a freaking fast RAV4, haha.
Old 12-22-2012, 07:02 PM   #637
Ryan23
Member#: 15116
2000 Ver6 STi Type-R
EJ257/GT35R
Just saw this thread; needs more GC love! Looking at the logs from my Link G4 (50hz logging rate), I've got 5 seconds for 80-160km (50-100mph):
http://forums.nasioc.com/forums/show....php?t=2129774
Vehicle: 2000 Impreza STI Version 6 Type R
Motor: Built EJ257 (Cosworth + Manley), Ported 207 AVCS heads, Kelford 272/268 cams, +1mm O/S Supertech valves, Crower springs/retainers, 12mm Leggie oil pump
Transmission: 05' JDM STi 6 speed
Redline: 7500ish
Fuel: 93 pump
Boost: 16.5 psi (logged 1.15 bar)
Upgrades: Link G4 standalone ECU, ATP 35R (stock location), GT Spec equal length header, 100mm FMIC, 80mm ti catback, JDM Spec C intake , ID 1000cc inj, Cusco twin clutch + a bunch of other misc crap
Weight: 2850(?)lbs
I can't wait to get everything swapped over to my US shell and do some high boost runs.
Ryan
Ryan23 is offline   Reply With Quote
Old 12-24-2012, 02:07 AM   #638
1QUIKV6
Member#: 9427
2006 WRX STi
[code]1QUIKV6 2006 Subaru STI NA NA 4.7 12.1 120 3468 2.5 F4 Dom3.0XTR 26psi E85[code]
Vehicle: 2006 STI
Motor: Stock EJ257
Turbo: Blouch Dominator 3.0XT-R w/10cm2 T-Housing
Boost: 26.0 psi
Transmission: Stock 6-Speed
Redline: 7500
Upgrades:
  • KSTech 83mm CAI
  • Perrin 2.4" Turbo Inlet
  • ETS TMIC
  • Walbro 430 LPH E85 Pump
  • FueLab E85 Filter
  • Five-O Motorsports 1185cc Injectors
  • Kamak ELH
  • Kinugawa Downpipe
  • M2 Performance Exhaust
  • Cobb AP w/AccessTUNER Race
Weight: 3303 lbs+165 lbs for me = 3468 lbs
50-100MPH: 4.71 - 4.72 - 4.73 - 4.75 (4 different runs taken with AP logging only vehicle speed to get max res - 15Hz)
1QUIKV6 is offline   Reply With Quote
Old 12-24-2012, 02:22 AM   #639
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Skinny
wrxsubiemod is offline   Reply With Quote
Old 12-24-2012, 08:27 AM   #640
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
If that is his tire and wheel size, then he is maybe a little faster from 50-100mph than has been calculated. that tire and wheel setup would hit 100mph when his speedometer says 98.3mph. The proper reading would be from about 49.3-98.3mph...as fast as his car is, i think an error of 1-2mph is only going to cost maybe a couple 10ths at the most, but still awesome to be able to say that he could be even faster.
amalgrover is offline   Reply With Quote
Old 01-01-2013, 07:21 PM   #641
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
Well I finally got the txs fmic installed, along with a omni 4 bar map sensor and switched from open-source to ap speed density. Went from 370/350 on the dom 3xtr to 415/405. Will edit this post with a new tomorrow. Should be 5 or below, makes the power at 4100 and holds over 400/400 till redline.
https://www.youtube.com/watch?v=Vyob...e_gdata_player
Slimsti is offline   Reply With Quote
Old 02-28-2013, 12:57 AM   #642
snake32
Member#: 167338
02 Silver dollar
stock 2004 sti long block
perrin rotated 30r .63
stock header
02-03 wrx ecu and manifold
swapped in a 2 door 2.5rs
380whp at 20 psi on 93
snake32 is offline   Reply With Quote
Old 02-28-2013, 08:16 AM   #643
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Thanks for the posts. I need to get caught back up here....
Old 02-28-2013, 04:08 PM   #644
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
2.5 hybrid 367whp/363wtq
Hybrid, 6spd, stock 2.0 heads Dom 1.5xtr 10^cm2 21psi 367/363 at IAG
shadowmd is offline   Reply With Quote
Old 02-28-2013, 08:40 PM   #645
Slimsti
Member#: 155696
stock header
Video Link: http://www.youtube.com/watch?v=2EN3aYbXnS0
Wow dude that's fast. You gotto precision? Car sounds familar.
Old 02-28-2013, 09:47 PM   #646
snake32
Member#: 167338
02 Silver dollar
^ yeah, Precision FTW! they have been more than awesome to me every time!
Old 03-13-2013, 07:12 PM   #647
Slimsti
Member#: 155696
Looking forward to the updated times.
Old 03-13-2013, 08:54 PM   #648
breaksOFTEN
Member#: 260549
'69 Camaro '76XS750
'77CB750
Dang I blew my built motor before I could get a real time, and all I could afford to replace it with was a used 2011 shortblock. Needless to say I turned the boost down a bit. I'll still see what it does though.
breaksOFTEN is offline   Reply With Quote
Old 03-14-2013, 11:32 AM   #649
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I think that's a hint that I'm way behind. Lol. I'll work on it!
What's the setup?
Old 03-14-2013, 12:34 PM   #650
CatfaceType-R
Member#: 81102
Step away from the subaru.
Oh, your username, carry on.
CatfaceType-R is offline   Reply With Quote
NASIOCers!! Starter mods list Daniel son Legacy Forum 4 11-21-2006 03:56 PM
50 cent listings on eBay motors plunk10 Off-Topic 7 10-17-2006 12:15 PM
Official NASIOC OT C List dr_wheel Off-Topic 25 02-22-2006 05:41 PM
NASIOC GMail Invite List AVATAR-X Off-Topic 458 05-21-2005 10:04 AM
Japan's Top 50 car list Tragedy Off-Topic 5 07-29-2003 11:49 PM
